Changed log level, output below. Node 12 (FGD212) S2/group 4 controls the Node 26 (AN157). Because of transparancy, i didnt add/remove the other devices. If i interpreted the log, it succesfully removed the node and succesfully add the node after it failed at the first add attempt.
If i press the button nothing is happing to the AN157, i stopped the debug before i did. Does that command/response get into the log at all? Anyway if needed i can add it.
2019-07-19 21:44:42.260 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Configuration update received
2019-07-19 21:44:42.262 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Configuration update set group_4 to [] (EmptyList)
2019-07-19 21:44:42.263 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Association 4 consolidated to []
2019-07-19 21:44:42.264 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Current members before update ZWaveAssociationGroup [index=4, name=On/Off(S2), profile1=32, profile2=2, associations=[node_26_0]]
2019-07-19 21:44:42.265 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Members after config update ZWaveAssociationGroup [index=4, name=null, profile1=null, profile2=null, associations=[]]
2019-07-19 21:44:42.266 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Controller is master - forcing associations
2019-07-19 21:44:42.268 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Members after controller update ZWaveAssociationGroup [index=4, name=null, profile1=null, profile2=null, associations=[]]
2019-07-19 21:44:42.269 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Association group 4 contains no members. Clearing.
2019-07-19 21:44:42.270 [DEBUG] [ss.ZWaveMultiAssociationCommandClass] - NODE 12: Creating new message for command MULTI_ASSOCIATIONCMD_REMOVE node all, endpoint all, group 4
2019-07-19 21:44:42.270 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION
2019-07-19 21:44:42.271 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: Command Class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION is NOT required to be secured
2019-07-19 21:44:42.272 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Adding to device queue
2019-07-19 21:44:42.273 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Added 306 to queue - size 17
2019-07-19 21:44:42.274 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-07-19 21:44:42.275 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 0C 03 8E 04 04 25 E6 A4
2019-07-19 21:44:42.276 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 12: Sending REQUEST Message = 01 0A 00 13 0C 03 8E 04 04 25 E6 A4
2019-07-19 21:44:42.277 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2019-07-19 21:44:42.278 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2019-07-19 21:44:42.278 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 306: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 230
2019-07-19 21:44:42.279 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-07-19 21:44:42.279 [DEBUG] [ss.ZWaveMultiAssociationCommandClass] - NODE 12: Creating new message for command MULTI_ASSOCIATIONCMD_GET group 4
2019-07-19 21:44:42.279 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-07-19 21:44:42.280 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 306: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 230
2019-07-19 21:44:42.280 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION
2019-07-19 21:44:42.280 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2019-07-19 21:44:42.281 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 21:44:42.281 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: Command Class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION is NOT required to be secured
2019-07-19 21:44:42.281 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-07-19 21:44:42.282 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Adding to device queue
2019-07-19 21:44:42.283 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Added 307 to queue - size 17
2019-07-19 21:44:42.284 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-07-19 21:44:42.285 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2019-07-19 21:44:42.285 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-07-19 21:44:42.286 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-07-19 21:44:42.287 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 306: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 230
2019-07-19 21:44:42.287 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-07-19 21:44:42.287 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 306: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 230
2019-07-19 21:44:42.288 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-07-19 21:44:42.289 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 12: sentData successfully placed on stack.
2019-07-19 21:44:42.289 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 306: Advanced to WAIT_REQUEST
2019-07-19 21:44:42.290 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: TID 306: Transaction not completed
2019-07-19 21:44:42.290 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 21:44:42.290 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-07-19 21:44:42.328 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 E6 00 00 05 08
2019-07-19 21:44:42.329 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=230, payload=E6 00 00 05
2019-07-19 21:44:42.330 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=230, payload=E6 00 00 05
2019-07-19 21:44:42.330 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 306: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 230
2019-07-19 21:44:42.331 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-07-19 21:44:42.331 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 306: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 230
2019-07-19 21:44:42.332 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 306: (Callback 230)
2019-07-19 21:44:42.332 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2019-07-19 21:44:42.333 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 306: callback 230
2019-07-19 21:44:42.333 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=230, payload=E6 00 00 05
2019-07-19 21:44:42.334 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 12: SendData Request. CallBack ID = 230, Status = Transmission complete and ACK received(0)
2019-07-19 21:44:42.335 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: resetResendCount initComplete=true isDead=false
2019-07-19 21:44:42.335 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 306: Transaction COMPLETED
2019-07-19 21:44:42.336 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Response processed after 58ms
2019-07-19 21:44:42.336 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: TID 306: Transaction completed
2019-07-19 21:44:42.337 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: notifyTransactionResponse TID:306 DONE
2019-07-19 21:44:42.337 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2019-07-19 21:44:42.338 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 21:44:42.339 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-07-19 21:44:42.339 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 0C 03 8E 02 04 25 E7 A3
2019-07-19 21:44:42.340 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 12: Sending REQUEST Message = 01 0A 00 13 0C 03 8E 02 04 25 E7 A3
2019-07-19 21:44:42.341 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2019-07-19 21:44:42.341 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 307: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 231
2019-07-19 21:44:42.342 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2019-07-19 21:44:42.342 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-07-19 21:44:42.343 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-07-19 21:44:42.344 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 307: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 231
2019-07-19 21:44:42.346 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2019-07-19 21:44:42.347 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 21:44:42.348 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-07-19 21:44:42.348 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2019-07-19 21:44:42.349 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-07-19 21:44:42.350 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-07-19 21:44:42.351 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 307: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 231
2019-07-19 21:44:42.352 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-07-19 21:44:42.353 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 307: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 231
2019-07-19 21:44:42.353 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-07-19 21:44:42.354 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 12: sentData successfully placed on stack.
2019-07-19 21:44:42.355 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 307: Advanced to WAIT_REQUEST
2019-07-19 21:44:42.356 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: TID 307: Transaction not completed
2019-07-19 21:44:42.357 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 21:44:42.358 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-07-19 21:44:42.398 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 E7 00 00 06 0A
2019-07-19 21:44:42.399 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=231, payload=E7 00 00 06
2019-07-19 21:44:42.400 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=231, payload=E7 00 00 06
2019-07-19 21:44:42.401 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 307: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 231
2019-07-19 21:44:42.402 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-07-19 21:44:42.403 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 307: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 231
2019-07-19 21:44:42.403 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 307: (Callback 231)
2019-07-19 21:44:42.404 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2019-07-19 21:44:42.405 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 307: callback 231
2019-07-19 21:44:42.406 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=231, payload=E7 00 00 06
2019-07-19 21:44:42.407 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 12: SendData Request. CallBack ID = 231, Status = Transmission complete and ACK received(0)
2019-07-19 21:44:42.408 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: resetResendCount initComplete=true isDead=false
2019-07-19 21:44:42.409 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 307: Advanced to WAIT_DATA
2019-07-19 21:44:42.410 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: TID 307: Transaction not completed
2019-07-19 21:44:42.411 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 21:44:42.411 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-07-19 21:44:42.471 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 0C 05 8E 03 04 08 00 78
2019-07-19 21:44:42.472 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=12, callback=0, payload=00 0C 05 8E 03 04 08 00
2019-07-19 21:44:42.473 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=12, callback=0, payload=00 0C 05 8E 03 04 08 00
2019-07-19 21:44:42.474 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-07-19 21:44:42.475 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Application Command Request (ALIVE:DONE)
2019-07-19 21:44:42.476 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: resetResendCount initComplete=true isDead=false
2019-07-19 21:44:42.477 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: Incoming command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION, endpoint 0
2019-07-19 21:44:42.478 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION
2019-07-19 21:44:42.479 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 12: Received COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION V3 MULTI_ASSOCIATIONCMD_REPORT
2019-07-19 21:44:42.480 [DEBUG] [ss.ZWaveMultiAssociationCommandClass] - NODE 12: association group 4 has max associations 8
2019-07-19 21:44:42.481 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveAssociationEvent
2019-07-19 21:44:42.482 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ASSOCIATION, value=0
2019-07-19 21:44:42.484 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Commands processed 1.
2019-07-19 21:44:42.484 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@717fe364.
2019-07-19 21:44:42.485 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@717fe364.
2019-07-19 21:44:42.486 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: notifyTransactionResponse TID:307 DONE
2019-07-19 21:44:42.487 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2019-07-19 21:44:42.488 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2019-07-19 21:44:42.489 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-07-19 21:44:42.490 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 21:44:42.491 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-07-19 21:44:56.016 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Polling...
2019-07-19 21:44:56.017 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Polling deferred until initialisation complete
2019-07-19 21:45:18.076 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 28 0A 60 0D 01 01 31 05 04 22 00 00 B6
2019-07-19 21:45:18.077 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=40, callback=0, payload=00 28 0A 60 0D 01 01 31 05 04 22 00 00
2019-07-19 21:45:18.078 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=40, callback=0, payload=00 28 0A 60 0D 01 01 31 05 04 22 00 00
2019-07-19 21:45:18.079 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-07-19 21:45:18.079 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 40: Application Command Request (ALIVE:DONE)
2019-07-19 21:45:18.080 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 40: resetResendCount initComplete=true isDead=false
2019-07-19 21:45:18.080 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 40: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2019-07-19 21:45:18.081 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 40: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 1
2019-07-19 21:45:18.081 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 40: SECURITY NOT required on COMMAND_CLASS_SENSOR_MULTILEVEL
2019-07-19 21:45:18.082 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 40: Received COMMAND_CLASS_SENSOR_MULTILEVEL V4 SENSOR_MULTILEVEL_REPORT
2019-07-19 21:45:18.082 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 40: Sensor Type = Power(4), Scale = 0
2019-07-19 21:45:18.083 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 40: Sensor Value = 0E+1
2019-07-19 21:45:18.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 40: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2019-07-19 21:45:18.084 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 40: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_SENSOR_MULTILEVEL, value=0E+1
2019-07-19 21:45:18.085 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 40: Sensor conversion not performed for POWER.
2019-07-19 21:45:18.086 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 40: Updating channel state zwave:device:512:node40:sensor_power1 to 0 [DecimalType]
2019-07-19 21:45:18.087 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 40: Commands processed 1.
2019-07-19 21:45:18.087 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 40: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@2593b413.
2019-07-19 21:45:18.088 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-07-19 21:45:18.089 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 21:45:18.089 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-07-19 21:45:30.622 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Configuration update received
2019-07-19 21:45:30.624 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Configuration update set group_4 to [node_26] (ArrayList)
2019-07-19 21:45:30.624 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Association 4 consolidated to [node_26]
2019-07-19 21:45:30.625 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Current members before update ZWaveAssociationGroup [index=4, name=On/Off(S2), profile1=32, profile2=2, associations=[]]
2019-07-19 21:45:30.626 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Members after config update ZWaveAssociationGroup [index=4, name=null, profile1=null, profile2=null, associations=[node_26]]
2019-07-19 21:45:30.626 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Controller is master - forcing associations
2019-07-19 21:45:30.628 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Members after controller update ZWaveAssociationGroup [index=4, name=null, profile1=null, profile2=null, associations=[node_26]]
2019-07-19 21:45:30.629 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Adding node_26 to association group 4
2019-07-19 21:45:30.629 [DEBUG] [ss.ZWaveMultiAssociationCommandClass] - NODE 12: Creating new message for command MULTI_ASSOCIATIONCMD_SET
2019-07-19 21:45:30.630 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION
2019-07-19 21:45:30.630 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: Command Class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION is NOT required to be secured
2019-07-19 21:45:30.631 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Adding to device queue
2019-07-19 21:45:30.632 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Added 308 to queue - size 17
2019-07-19 21:45:30.632 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-07-19 21:45:30.633 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 13 0C 06 8E 01 04 00 1A 00 25 E8 B7
2019-07-19 21:45:30.634 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 12: Sending REQUEST Message = 01 0D 00 13 0C 06 8E 01 04 00 1A 00 25 E8 B7
2019-07-19 21:45:30.635 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2019-07-19 21:45:30.636 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2019-07-19 21:45:30.636 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 308: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 232
2019-07-19 21:45:30.636 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-07-19 21:45:30.637 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-07-19 21:45:30.637 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 308: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 232
2019-07-19 21:45:30.637 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2019-07-19 21:45:30.638 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 21:45:30.638 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-07-19 21:45:30.638 [DEBUG] [ss.ZWaveMultiAssociationCommandClass] - NODE 12: Creating new message for command MULTI_ASSOCIATIONCMD_GET group 4
2019-07-19 21:45:30.639 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION
2019-07-19 21:45:30.639 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: Command Class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION is NOT required to be secured
2019-07-19 21:45:30.640 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Adding to device queue
2019-07-19 21:45:30.641 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Added 309 to queue - size 17
2019-07-19 21:45:30.641 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-07-19 21:45:30.642 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2019-07-19 21:45:30.643 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-07-19 21:45:30.644 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-07-19 21:45:30.644 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 308: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 232
2019-07-19 21:45:30.644 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-07-19 21:45:30.645 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 308: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 232
2019-07-19 21:45:30.645 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-07-19 21:45:30.645 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 12: sentData successfully placed on stack.
2019-07-19 21:45:30.646 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 308: Advanced to WAIT_REQUEST
2019-07-19 21:45:30.646 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: TID 308: Transaction not completed
2019-07-19 21:45:30.646 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 21:45:30.646 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-07-19 21:45:30.686 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 E8 00 00 05 06
2019-07-19 21:45:30.687 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=232, payload=E8 00 00 05
2019-07-19 21:45:30.687 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=232, payload=E8 00 00 05
2019-07-19 21:45:30.688 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 308: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 232
2019-07-19 21:45:30.688 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-07-19 21:45:30.688 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 308: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 232
2019-07-19 21:45:30.689 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 308: (Callback 232)
2019-07-19 21:45:30.689 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2019-07-19 21:45:30.689 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 308: callback 232
2019-07-19 21:45:30.689 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=232, payload=E8 00 00 05
2019-07-19 21:45:30.690 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 12: SendData Request. CallBack ID = 232, Status = Transmission complete and ACK received(0)
2019-07-19 21:45:30.690 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: resetResendCount initComplete=true isDead=false
2019-07-19 21:45:30.690 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 308: Transaction COMPLETED
2019-07-19 21:45:30.691 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Response processed after 55ms
2019-07-19 21:45:30.691 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: TID 308: Transaction completed
2019-07-19 21:45:30.691 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: notifyTransactionResponse TID:308 DONE
2019-07-19 21:45:30.692 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2019-07-19 21:45:30.692 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 21:45:30.693 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-07-19 21:45:30.693 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 0C 03 8E 02 04 25 E9 AD
2019-07-19 21:45:30.694 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 12: Sending REQUEST Message = 01 0A 00 13 0C 03 8E 02 04 25 E9 AD
2019-07-19 21:45:30.694 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2019-07-19 21:45:30.695 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 309: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 233
2019-07-19 21:45:30.696 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2019-07-19 21:45:30.696 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-07-19 21:45:30.700 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-07-19 21:45:30.700 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 309: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 233
2019-07-19 21:45:30.701 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2019-07-19 21:45:30.702 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2019-07-19 21:45:30.703 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-07-19 21:45:30.701 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 21:45:30.704 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-07-19 21:45:30.704 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-07-19 21:45:30.705 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 309: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 233
2019-07-19 21:45:30.705 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-07-19 21:45:30.706 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 309: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 233
2019-07-19 21:45:30.707 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-07-19 21:45:30.707 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 12: sentData successfully placed on stack.
2019-07-19 21:45:30.708 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 309: Advanced to WAIT_REQUEST
2019-07-19 21:45:30.708 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: TID 309: Transaction not completed
2019-07-19 21:45:30.709 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 21:45:30.709 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-07-19 21:45:30.758 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 E9 00 00 06 04
2019-07-19 21:45:30.759 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=233, payload=E9 00 00 06
2019-07-19 21:45:30.760 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=233, payload=E9 00 00 06
2019-07-19 21:45:30.760 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 309: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 233
2019-07-19 21:45:30.760 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-07-19 21:45:30.761 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 309: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 233
2019-07-19 21:45:30.761 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 309: (Callback 233)
2019-07-19 21:45:30.761 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2019-07-19 21:45:30.761 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 309: callback 233
2019-07-19 21:45:30.762 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=233, payload=E9 00 00 06
2019-07-19 21:45:30.762 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 12: SendData Request. CallBack ID = 233, Status = Transmission complete and ACK received(0)
2019-07-19 21:45:30.763 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: resetResendCount initComplete=true isDead=false
2019-07-19 21:45:30.763 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 309: Advanced to WAIT_DATA
2019-07-19 21:45:30.763 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: TID 309: Transaction not completed
2019-07-19 21:45:30.763 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 21:45:30.764 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-07-19 21:45:30.832 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0E 00 04 00 0C 08 8E 03 04 08 00 00 1A 00 6A
2019-07-19 21:45:30.833 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=12, callback=0, payload=00 0C 08 8E 03 04 08 00 00 1A 00
2019-07-19 21:45:30.834 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=12, callback=0, payload=00 0C 08 8E 03 04 08 00 00 1A 00
2019-07-19 21:45:30.834 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-07-19 21:45:30.835 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Application Command Request (ALIVE:DONE)
2019-07-19 21:45:30.835 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: resetResendCount initComplete=true isDead=false
2019-07-19 21:45:30.835 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: Incoming command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION, endpoint 0
2019-07-19 21:45:30.836 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION
2019-07-19 21:45:30.836 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 12: Received COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION V3 MULTI_ASSOCIATIONCMD_REPORT
2019-07-19 21:45:30.837 [DEBUG] [ss.ZWaveMultiAssociationCommandClass] - NODE 12: association group 4 has max associations 8
2019-07-19 21:45:30.837 [DEBUG] [ss.ZWaveMultiAssociationCommandClass] - NODE 12: Association group 4 includes the following nodes:
2019-07-19 21:45:30.838 [DEBUG] [ss.ZWaveMultiAssociationCommandClass] - NODE 12: Associated with Node 26 endpoint 0 in group
2019-07-19 21:45:30.838 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveAssociationEvent
2019-07-19 21:45:30.839 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ASSOCIATION, value=0
2019-07-19 21:45:30.840 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Commands processed 1.
2019-07-19 21:45:30.840 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@4827c957.
2019-07-19 21:45:30.841 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@4827c957.
2019-07-19 21:45:30.841 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: notifyTransactionResponse TID:309 DONE
2019-07-19 21:45:30.842 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2019-07-19 21:45:30.842 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2019-07-19 21:45:30.843 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-07-19 21:45:30.843 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 21:45:30.843 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
