Rebuilt the whole system back to 2.4
Tony
Search this forum for recent threads about zwave stick not going online
Search by most recent so you don’t get old stuff
What version of OH are you using?
start a new thread if your issue persists
I believe I’ve figured it out. Something has changed in the usb layer, which is preventing the stick from being allocated properly.
I did some more searching, but what I’m hitting appears to be a linux usb bug, specifically xhci_hcd where the front usb ports (secondary hub) are not registering devices properly.
In syslog I found xhci_hcd messages that indicated the stick could not be allocated.
Jul 28 13:24:24 bernzie kernel: [ 4.149310] xhci_hcd 0000:00:14.0: xHCI Host Controller
Jul 28 13:24:24 bernzie kernel: [ 4.219497] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
Jul 28 13:24:24 bernzie kernel: [ 4.321573] usb usb1-port3: couldn’t allocate usb_device
$ lsusb -tv
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 5000M
ID 1d6b:0003 Linux Foundation 3.0 root hub
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/7p, 480M
ID 1d6b:0002 Linux Foundation 2.0 root hub
Simply moving the stick to the rear USB port allowed it to be found and my system when back to normal.
$ lsusb -tv
|__ Port 2: Dev 3, If 0, Class=Communications, Driver=cdc_acm, 12M
ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB
|__ Port 2: Dev 3, If 1, Class=CDC Data, Driver=cdc_acm, 12M
|__ Port 5: Dev 2, If 0, Class=Wireless, Driver=btusb, 12M
ID 8087:07dc Intel Corp.
|__ Port 5: Dev 2, If 1, Class=Wireless, Driver=btusb, 12M
More research is required, but I’m good for now.
Maybe this will help someone else.
Cheers!
