I am trying to use a 4 button Devolo Home Control remote. I am able to include it, but the device is not recognized. I also do not see any events in the logs and HABmin states that packages have never been send or received. Is this a general compatibility issue or is something wrong with the remote? The manual is just terrible (basically just stating “Our home control system will tell you what to do”).
I think the device should work. You will need to wake it up (hopefully the manual will say how to wake the device) a few times to get it configured.
If there are no packets in the debug log when you wake it up, and the device is reasonably close to the controller, then it might not have included correctly. It can happen that the stick thinks the node number is one value, while the device thinks it’s a different value if something goes wrong during the inclusion process so excluding the device and re-including it would be the first thing to try if there really is no communication.
I’m also not sure that the device is in the database, however I guess from the above that you’re using OH1 so this doesn’t matter for the initial “getting it going” stage.
Ok, the manual did NOT say that (it just said “Our Home Control System will tell you what to do”), but the Support Hotline did after some hesitation (“That depends on the master system …”).
It’s just pressing and holding button 1 when close to the station in include mode. I seem to have it paired now, I have the following in the logs:
I don’t get anything when I press any button, though. Let me add that a Fibaro MeterSwitch is working fine. I am using an Aeotec Z-Stick Gen5 on the OpenHAB side.
Before those lines, I have a lot of exceptions in the log, but I don’t know if they are related:
at org.openhab.binding.zwave.internal.config.ZWaveConfiguration.getConfiguration(ZWaveConfiguration.java:127) ~[bundlefile:na]
at org.openhab.io.habmin.services.zwave.ZWaveConfigResource.getConfig(ZWaveConfigResource.java:73) ~[na:na]
at sun.reflect.GeneratedMethodAccessor49.invoke(Unknown Source) ~[na:na]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_91]
at java.lang.reflect.Method.invoke(Method.java:498) ~[na:1.8.0_91]
at com.sun.jersey.spi.container.JavaMethodInvokerFactory$1.invoke(JavaMethodInvokerFactory.java:60) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.model.method.dispatch.AbstractResourceMethodDispatchProvider$ResponseOutInvoker._dispatch(AbstractResourceMethodDispatchProvider.java:205) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.model.method.dispatch.ResourceJavaMethodDispatcher.dispatch(ResourceJavaMethodDispatcher.java:75) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.uri.rules.HttpMethodRule.accept(HttpMethodRule.java:302) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.uri.rules.RightHandPathRule.accept(RightHandPathRule.java:147) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.uri.rules.ResourceClassRule.accept(ResourceClassRule.java:108) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.uri.rules.RootResourceClassesRule.accept(RootResourceClassesRule.java:84) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.WebApplicationImpl._handleRequest(WebApplicationImpl.java:1542) [jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.WebApplicationImpl._handleRequest(WebApplicationImpl.java:1473) [jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1419) [jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1409) [jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.spi.container.servlet.WebComponent.service(WebComponent.java:409) [jersey-servlet-1.18.1.jar:1.18.1]
at com.sun.jersey.spi.container.servlet.ServletContainer.service(ServletContainer.java:540) [jersey-servlet-1.18.1.jar:1.18.1]
at com.sun.jersey.spi.container.servlet.ServletContainer.service(ServletContainer.java:715) [jersey-servlet-1.18.1.jar:1.18.1]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848) [javax.servlet_3.0.0.v201112011016.jar:na]
at org.atmosphere.util.AtmosphereFilterChain.doFilter(AtmosphereFilterChain.java:135) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.util.AtmosphereFilterChain.invokeFilterChain(AtmosphereFilterChain.java:96) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.handler.ReflectorServletProcessor$FilterChainServletWrapper.service(ReflectorServletProcessor.java:317) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.handler.ReflectorServletProcessor.onRequest(ReflectorServletProcessor.java:160) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AsynchronousProcessor.action(AsynchronousProcessor.java:206) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AsynchronousProcessor.suspended(AsynchronousProcessor.java:105) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.container.Jetty7CometSupport.service(Jetty7CometSupport.java:57) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.container.JettyAsyncSupportWithWebSocket.service(JettyAsyncSupportWithWebSocket.java:67) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AtmosphereFramework.doCometSupport(AtmosphereFramework.java:2076) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AtmosphereServlet.doPost(AtmosphereServlet.java:211) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AtmosphereServlet.doGet(AtmosphereServlet.java:197) [atmosphere-runtime-2.2.5.jar:2.2.5]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:735) [javax.servlet_3.0.0.v201112011016.jar:na]
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61) [org.eclipse.equinox.http.servlet_1.1.300.v20120522-1841.jar:na]
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128) [org.eclipse.equinox.http.servlet_1.1.300.v20120522-1841.jar:na]
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:68) [org.eclipse.equinox.http.servlet_1.1.300.v20120522-1841.jar:na]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598) [org.eclipse.jetty.servlet_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486) [org.eclipse.jetty.servlet_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413) [org.eclipse.jetty.servlet_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:250) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:149) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.Server.handle(Server.java:350) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:890) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:944) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:630) [org.eclipse.jetty.http_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230) [org.eclipse.jetty.http_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:77) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:606) [org.eclipse.jetty.io_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:46) [org.eclipse.jetty.io_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603) [org.eclipse.jetty.util_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538) [org.eclipse.jetty.util_8.1.3.v20120522.jar:8.1.3.v20120522]
at java.lang.Thread.run(Thread.java:745) [na:1.8.0_91]
2016-08-11 13:28:38.398 [ERROR] [.a.h.ReflectorServletProcessor] - onRequest()
at com.sun.jersey.server.impl.application.WebApplicationImpl._handleRequest(WebApplicationImpl.java:1542) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.WebApplicationImpl._handleRequest(WebApplicationImpl.java:1473) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1419) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1409) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.spi.container.servlet.WebComponent.service(WebComponent.java:409) ~[jersey-servlet-1.18.1.jar:1.18.1]
at com.sun.jersey.spi.container.servlet.ServletContainer.service(ServletContainer.java:540) ~[jersey-servlet-1.18.1.jar:1.18.1]
at com.sun.jersey.spi.container.servlet.ServletContainer.service(ServletContainer.java:715) ~[jersey-servlet-1.18.1.jar:1.18.1]
at org.atmosphere.util.AtmosphereFilterChain.doFilter(AtmosphereFilterChain.java:135) ~[atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.util.AtmosphereFilterChain.invokeFilterChain(AtmosphereFilterChain.java:96) ~[atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.handler.ReflectorServletProcessor$FilterChainServletWrapper.service(ReflectorServletProcessor.java:317) ~[atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.handler.ReflectorServletProcessor.onRequest(ReflectorServletProcessor.java:160) ~[atmosphere-runtime-2.2.5.jar:2.2.5]
2016-08-11 13:28:38.411 [WARN ] [e.jetty.servlet.ServletHandler] - /services/habmin/zwave/products/
java.lang.RuntimeException: java.lang.NullPointerException
at org.atmosphere.handler.ReflectorServletProcessor.onRequest(ReflectorServletProcessor.java:163) ~[na:na]
at org.atmosphere.cpr.AsynchronousProcessor.action(AsynchronousProcessor.java:206) ~[na:na]
at org.atmosphere.cpr.AsynchronousProcessor.suspended(AsynchronousProcessor.java:105) ~[na:na]
at org.atmosphere.container.Jetty7CometSupport.service(Jetty7CometSupport.java:57) ~[na:na]
at org.atmosphere.container.JettyAsyncSupportWithWebSocket.service(JettyAsyncSupportWithWebSocket.java:67) ~[na:na]
at org.atmosphere.cpr.AtmosphereFramework.doCometSupport(AtmosphereFramework.java:2076) ~[na:na]
at org.atmosphere.cpr.AtmosphereServlet.doPost(AtmosphereServlet.java:211) ~[na:na]
at org.atmosphere.cpr.AtmosphereServlet.doGet(AtmosphereServlet.java:197) ~[na:na]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:735) ~[javax.servlet_3.0.0.v201112011016.jar:na]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848) ~[javax.servlet_3.0.0.v201112011016.jar:na]
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61) ~[na:na]
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128) ~[na:na]
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:68) ~[na:na]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598) ~[org.eclipse.jetty.servlet_8.1.3.v20120522.jar:8.1.3.v20120522]
Caused by: java.lang.NullPointerException: null
at org.openhab.binding.zwave.internal.config.ZWaveConfiguration.getConfiguration(ZWaveConfiguration.java:127) ~[na:na]
at com.sun.jersey.spi.container.JavaMethodInvokerFactory$1.invoke(JavaMethodInvokerFactory.java:60) ~[na:na]
at com.sun.jersey.server.impl.model.method.dispatch.AbstractResourceMethodDispatchProvider$ResponseOutInvoker._dispatch(AbstractResourceMethodDispatchProvider.java:205) ~[na:na]
at com.sun.jersey.server.impl.model.method.dispatch.ResourceJavaMethodDispatcher.dispatch(ResourceJavaMethodDispatcher.java:75) ~[na:na]
at com.sun.jersey.server.impl.uri.rules.HttpMethodRule.accept(HttpMethodRule.java:302) ~[na:na]
at com.sun.jersey.server.impl.uri.rules.RightHandPathRule.accept(RightHandPathRule.java:147) ~[na:na]
at com.sun.jersey.server.impl.uri.rules.ResourceClassRule.accept(ResourceClassRule.java:108) ~[na:na]
at com.sun.jersey.server.impl.uri.rules.RootResourceClassesRule.accept(RootResourceClassesRule.java:84) ~[na:na]
at com.sun.jersey.server.impl.application.WebApplicationImpl._handleRequest(WebApplicationImpl.java:1542) ~[na:na]
at com.sun.jersey.server.impl.application.WebApplicationImpl._handleRequest(WebApplicationImpl.java:1473) ~[na:na]
at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1419) ~[na:na]
at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1409) ~[na:na]
at com.sun.jersey.spi.container.servlet.WebComponent.service(WebComponent.java:409) ~[na:na]
at com.sun.jersey.spi.container.servlet.ServletContainer.service(ServletContainer.java:540) ~[na:na]
at com.sun.jersey.spi.container.servlet.ServletContainer.service(ServletContainer.java:715) ~[na:na]
at org.atmosphere.util.AtmosphereFilterChain.doFilter(AtmosphereFilterChain.java:135) ~[na:na]
at org.atmosphere.util.AtmosphereFilterChain.invokeFilterChain(AtmosphereFilterChain.java:96) ~[na:na]
at org.atmosphere.handler.ReflectorServletProcessor$FilterChainServletWrapper.service(ReflectorServletProcessor.java:317) ~[na:na]
at org.atmosphere.handler.ReflectorServletProcessor.onRequest(ReflectorServletProcessor.java:160) ~[na:na]
… 36 common frames omitted
Hi, sorry, I didn’t answer that. I use Openhab 1 (Openhab 2 ist just installed, but not started, for testing). What makes you think I use OpenHAB2? My z-wave binding is version 1.8.3.
I finally found a model number (seems to be only on the Declaration of Conformity sheet): MT:2653.
I am also looking at this apparently realted thread:
but I don’t even have a configuration parameters listing in HABmin (I do have one for the meter switch, so I am looking at the right place, I guess)
Ok, thanks. Please can you upgrade to the most recent version - I think this error was fixed a long time ago. If it still persists after you’re using a newer version I’ll take a look, but I’m pretty sure it’s solved.
It still won’t be in the database. You might need to manually configure associations which will need the database to be updated.
Hi, I used apt-get from the (semi?)official PPA to install 1.8.3. That seems to be the most recent version there. Can you point me into the right direction how to install this manually? Also note that I edited some information into the last post, you might not have read that.
No - I meant to grab the latest snapshot binding from cloudbees. I’m not sure how that works with the apt repository, but you need to get the 1.9 snapshot of the zwave binding.
I’ve the same device here. After inlcusion, it shows up w/o Association Groups I don’t get it to work. Also, it needs some configuration parameters to set the operation mode of the keys correctly. Since this device is prepaired for the Devolo Home Control, the default setup might be something…
The Device ist pretty the same as the zwave.me 4-Button control, it also show up with the same ID, but with the manufacture id of Devolo:
If I understand it right, it should be enough to add an Device Entry and link it to the Config-File of the same Device from ZWave.me, this should be: zwaveme/kfob.xml
I’m not fimilar with github, if I get it right, there must be some PR and then wait for the next build of the zwave-bindung Addon?
Ok, I installed the 1.9.0 snapshot manually. Now I have Association Groups and Configuration Parameters, but they are both empty.
Logs now say
2016-08-11 19:02:31.060 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 6: Sent Data was not placed on stack due to error 0.
2016-08-11 19:02:36.058 [ERROR] [WaveController$ZWaveSendThread] - NODE 6: Timeout while sending message. Requeueing - 0 attempts left!
I also updated to the 1.9.0 snapshot and the inclusion of the device seems to be normal - for an unknown device. Per default the buttons of the RC are working on 4 differend association goups - and so we get no response until we are able access these groups, right? Association Groups are actually empty in habmin.
If you can’t see any devices in HABmin, then the problem is not ZWave, but something else (HABmin configuration, network, REST, or something along those lines). The log shows that ZWave is working ok, so the problem must be elsewhere in the system, but I’m not really sure what unfortunately.
Maybe try restarting in case the HABmin -> ZWave communication has got confused with the change of binding.
