I believe the Zwave Security class is still being worked on, and secure inclusions cant’ be done yet?
So in continuing my learning in general, I recently setup OpenZwave and OZCP and was able to securely pair my front door lock to a zwave.me UZB1 stick. I then tried adding the same network key into the zwave controller in OH2, and was hoping to see it work, but no luck
But should that work when the binding is ready with the secure class working? The lock is already securely paired to the zstick and I can control it in OZCP. Although I did note that OZCP is not updating the status if you manually lock or unlock the door.
You sorta confused me though. So, confirming we are still waiting for secure inclusion to be added to the binding going forward, and…
When it is ready, that I would need unpair it from the zstick and then repair again under OpenHab?
The device is actually already secure included via OZCP and OpenZwave. That is why I was believing when OH2 is ready, all that would be needed is to set the same secure key in controller configuration in Habmin?
Maybe I misunderstood what you said actually - sorry. Once the security classes are included, then (hopefully!), yes, it should work without having to reinclude. (sorry - I thought I read if you included it securely through OZW then it should work in OH now, but I think I missed the last bit).
OpenHab and stuff can be painfully addicting to play with. I’m hoping to add a few more light switches and sensors soon as well.
I do know as well, and not sure if it matters, but OZCP and OpenHab when i tried have both picked up my Kwikset 916 lock as a 914 model. But it seems to work ok.
And also if helps in your thoughts, I did find out that manually locking/unlocking the door was not updating it in OZCP. But when that same lock was paired to a Wink Hub, manually locking/unlocking did updat the Wink App.
