I use two different ZWAVE sensors:
- a Fibaro FGBS222 SmartImplant
- an Aeotec ZW100 Multisensor 6
I’d like to be able to refresh some channels of these sensors to have a consistent state after a reboot.
On the Fibaro sensor, the command only refreshes the internal temperature and the output switch but not the input alarms. When the refresh command is sent, I get the following debug log:
[DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling zwave:device:5fadc798:node3:alarm_burglar1
[DEBUG] [nternal.converter.ZWaveAlarmConverter] - NODE 3: Generating poll message for COMMAND_CLASS_ALARM, endpoint 1, alarm BURGLAR, event null
[DEBUG] [l.commandclass.ZWaveAlarmCommandClass] - NODE 3: Creating new message for application command NOTIFICATION_GET V0
[DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling skipped for zwave:device:5fadc798:node3:alarm_burglar1 on COMMAND_CLASS_BASIC
[DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling zwave:device:5fadc798:node3:alarm_burglar2
[DEBUG] [nternal.converter.ZWaveAlarmConverter] - NODE 3: Generating poll message for COMMAND_CLASS_ALARM, endpoint 2, alarm BURGLAR, event null
[DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling skipped for zwave:device:5fadc798:node3:alarm_burglar2 on COMMAND_CLASS_BASIC
On the Aeotec sensor, the motion alarm is not refresh either, and I get the following debug log:
[DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 2: Command received zwave:device:5fadc798:node2:alarm_motion --> REFRESH [RefreshType]
[DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling initialised at 86400 seconds - start in 50 milliseconds.
[DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling…
[DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling zwave:device:5fadc798:node2:alarm_motion
[DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling zwave:device:5fadc798:node2:alarm_tamper
Is this the intended behavior for these sensors ?
If yes, is there any workaround to force an update of every channel ?
