- Platform information:
- Hardware: _Raspberry PI 3 model B Plus 1.3 / 64GB Flash
- OS: Openhabian
- openHAB version: V2.5
Hi
Since I installed V2.5 OH constantly cycle through connecting and disconnecting my AEOTEC Z-Stick Gen5. It’s been working well for many month before.
I reset the controler, rebooted, even uninstalled/reinstalled the ZWave binding to no avail.
I made several searches on the forum but found no articles relating to that issue
Here a log snapshot with several iterations of the loop.
2019-12-19 14:08:03.682 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
2019-12-19 14:08:03.684 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:2f3f2eed' has been updated.
2019-12-19 14:08:03.689 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM0'
2019-12-19 14:08:03.690 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:2f3f2eed' changed from OFFLINE (COMMUNICATION_ERROR): Serial Error: Port /dev/ttyACM1 does not exist to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-12-19 14:08:03.761 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2019-12-19 14:08:03.836 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2019-12-19 14:08:03.840 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2019-12-19 14:08:15.544 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:2f3f2eed' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-12-19 14:08:15.556 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:2f3f2eed' has been updated.
2019-12-19 14:08:19.482 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:2f3f2eed' changed from ONLINE to UNINITIALIZED
2019-12-19 14:08:22.560 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
2019-12-19 14:08:22.638 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:2f3f2eed' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-12-19 14:08:24.214 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs, openhab-binding-HP Printer Binding'
2019-12-19 14:08:35.021 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2019-12-19 14:08:35.349 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:2f3f2eed' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-12-19 14:08:35.378 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM0'
2019-12-19 14:08:35.381 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:2f3f2eed' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-12-19 14:08:35.484 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2019-12-19 14:08:35.545 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2019-12-19 14:08:35.548 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2019-12-19 14:08:46.871 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:2f3f2eed' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-12-19 14:08:46.888 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:2f3f2eed' has been updated.
2019-12-19 14:09:14.936 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs, openhab-binding-HP Printer Binding'
2019-12-19 14:09:45.870 [vent.ItemStateChangedEvent] - AstroSunData_Radiation_DirectRadiation changed from 38.29049957069636 W/m² to 35.91617957316753 W/m²
2019-12-19 14:09:45.873 [vent.ItemStateChangedEvent] - AstroSunData_Radiation_TotalRadiation changed from 116.53795354565747 W/m² to 113.03996658446229 W/m²
2019-12-19 14:10:15.205 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:2f3f2eed' changed from ONLINE to UNINITIALIZED
2019-12-19 14:10:18.302 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
2019-12-19 14:10:18.343 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:2f3f2eed' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-12-19 14:10:19.686 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs, openhab-binding-HP Printer Binding'
2019-12-19 14:10:29.871 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2019-12-19 14:10:30.177 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:2f3f2eed' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-12-19 14:10:30.204 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM0'
2019-12-19 14:10:30.204 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:2f3f2eed' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-12-19 14:10:30.235 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2019-12-19 14:10:30.276 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2019-12-19 14:10:30.277 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2019-12-19 14:10:40.877 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:2f3f2eed' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-12-19 14:10:40.897 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:2f3f2eed' has been updated.
2019-12-19 14:11:15.397 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:2f3f2eed' changed from ONLINE to UNINITIALIZED
2019-12-19 14:11:18.592 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
Can someone help?
PS: I’m not an expert in computer science, Linux etc and as such I’m seriously considering stepping over to another (home assistant) platform that is less cryptic to non IT experts and does hopefully not require hours of config resolving for every upgrade. My experience up till now is that to experiment OH is fabulous, but if I had to install a system at a friend’s or for a customer I would not go for this platform. Any thoughts on this would be appreciated.
Txs!
