Greetings,
today I’m performing some tests on the latest zwave binding code by compiling it directly from git, but it seems I’m unable to use it from inside both an OpenHAB2-2.0.0 and a OpenHAB2-2.1.0-SNAPSHOT runtime.
Every time I try to configure the controller this is what I get in the logs:
2017-04-03 18:35:23.143 [DEBUG] [org.openhab.binding.zwave ] - BundleEvent STARTED - org.openhab.binding.zwave
2017-04-03 18:35:23.148 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.events.EventFactory}={component.name=org.openhab.binding.zwave.event.BindingEventFactory, component.id=172, service.id=297, service.bundleid=185, service.scope=bundle} - org.openhab.binding.zwave
2017-04-03 18:35:23.153 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.ConfigOptionProvider, org.eclipse.smarthome.config.core.ConfigDescriptionProvider}={component.name=org.openhab.binding.zwave.ConfigDescription, component.id=173, service.id=298, service.bundleid=185, service.scope=bundle} - org.openhab.binding.zwave
2017-04-03 18:35:23.156 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=org.openhab.binding.zwave.internal.ZWaveHandlerFactory, component.id=176, service.id=299, service.bundleid=185, service.scope=bundle} - org.openhab.binding.zwave
2017-04-03 18:35:23.459 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Initializing ZWave serial controller.
2017-04-03 18:35:23.462 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Initializing ZWave Controller.
2017-04-03 18:35:23.463 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM0'
2017-04-03 18:35:23.463 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while initializing handler of thing 'zwave:serial_zstick:e47a3545': java.lang.NoSuchMethodError: gnu.io.CommPortIdentifier.open(Ljava/lang/String;I)Lgnu/io/CommPort;
java.util.concurrent.ExecutionException: java.lang.NoSuchMethodError: gnu.io.CommPortIdentifier.open(Ljava/lang/String;I)Lgnu/io/CommPort;
at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_121]
at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_121]
at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:194)[99:org.eclipse.smarthome.core:0.9.0.201703201701]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:83)[99:org.eclipse.smarthome.core:0.9.0.201703201701]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:67)[99:org.eclipse.smarthome.core:0.9.0.201703201701]
at org.eclipse.smarthome.core.thing.internal.ThingManager$9.run(ThingManager.java:705)[106:org.eclipse.smarthome.core.thing:0.9.0.201703201701]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_121]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_121]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)[:1.8.0_121]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_121]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
Caused by: java.lang.NoSuchMethodError: gnu.io.CommPortIdentifier.open(Ljava/lang/String;I)Lgnu/io/CommPort;
at org.openhab.binding.zwave.handler.ZWaveSerialHandler.initialize(ZWaveSerialHandler.java:82)
at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:708)
at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:1)
at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:181)
... 3 more
It seems like there’s a misalignment between the serial library used by the binding and the one available from the runtime, which is nrjavaserial (org.openhab/nrjavaserial/3.12.0.OH
in both cases), installed either via the addons interface or the karaf feature openhab-transport-serial
I previously tested the stable version of the binding (2.0.0) and it worked flawlessly with the aforementioned serial library…
Does anybody have a clue about what is going wrong here?
