Hi there, I think my question is somewhat similar to MAP transform for zwave items?
I have a Stelpro STZW402 4000W Thermostat, I want to display the “friendly/formatted” text for the thermostat_state and thermostat_mode.
ie… instead of seeing a “1” for thermostat_mode, I would like to see “Heat”. This appears to be currently defined correctly in the corresponding [mappings] (https://github.com/openhab/org.openhab.binding.zwave/blob/e9f2f8304a9b60f76598f57750db0c38a8ec294c/ESH-INF/thing/_channels.xml#L1097) from the zwave binding
When I look in habmin, I see that it’s cross referencing correctly.
However in my sitemap, I am unsure how to show the translated value? My current sitemap line is:
Text item=zwave_device_be6c9b8e_node3_thermostat_mode icon="light"
Also, in the console, I see the numeric value:
openhab> items|grep zwave_device_be6c9b8e_node3
zwave_device_be6c9b8e_node3_sensor_temperature (Type=NumberItem, State=21, Label=Sensor (temperature), Category=null)
zwave_device_be6c9b8e_node3_thermostat_mode (Type=NumberItem, State=1, Label=Thermostat mode, Category=null)
zwave_device_be6c9b8e_node3_thermostat_state (Type=NumberItem, State=0, Label=Thermostat Operating State, Category=null)
zwave_device_be6c9b8e_node3_thermostat_setpoint_heating (Type=NumberItem, State=21, Label=Setpoint (heating), Category=null)
openhab>
Is there any way to get the translated value from the zwave binding? if not, what is the recommended way to transform the value myself? Define a new item with a map(of note, all my items have been auto-created so far)? I would hate to have to code what appears to be already done in the zwave binding.
thanks for your help!
