Openhab: 2.5.x (multiple tried - all Docker containers)
O/S: Ubuntu Linux 18.04
Zwave controller: Aeotec ZStick
My Zwave network has ground to a halt after 12+ months of working properly. There are a variety of errors showing in HABmin and PaperUI but the most telling is the logs:
Exception in thread "ZWaveReceiveProcessorThread" java.lang.NullPointerException
at org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager$ZWaveReceiveThread.run(ZWaveTransactionManager.java:766)
java.lang.IllegalStateException: Queue full
at java.util.AbstractQueue.add(AbstractQueue.java:98) ~[?:1.8.0_232]
at java.util.concurrent.ArrayBlockingQueue.add(ArrayBlockingQueue.java:312) ~[?:1.8.0_232]
at org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager.processReceiveMessage(ZWaveTransactionManager.java:435) ~[bundleFile:?]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.incomingPacket(ZWaveController.java:1078) ~[bundleFile:?]
at org.openhab.binding.zwave.handler.ZWaveControllerHandler.incomingMessage(ZWaveControllerHandler.java:437) ~[bundleFile:?]
at org.openhab.binding.zwave.handler.ZWaveSerialHandler$ZWaveReceiveThread.run(ZWaveSerialHandler.java:420) [bundleFile:?]
I have reinstalled just about everything, switched out Aeotec Z-Sticks, deleted all the ZWave Things but to no avail.
Try turning off the zwave daily heal and then restart OH. There are several posts about this. Also, use the PC Controller app to find and remove ghost nodes.
Thanks, trying that now; and I was able to remove three dead nodes.
The error seems to have been resolved (not showing in the logs), but the Zwave network isn’t responding to OpenHAB. HABmin shows all the nodes online but they aren’t responding to state changes. Weirdly enough the Network Viewer isn’t working, it shows a single line. However, the Network displays properly in the Zensys tool.
I just upgraded to 2.5 and while I haven’t had my network stop, I have a ghost node from something that was deinstalled, and another switch that has not fully populated its data.
PC Controller is the new name for Zensys Tools. You can download it from SilconLabs. There are several topics discussing it. If you haven’t tried, you may also be able to remove the node through the zwave binding.
I gave up - somehow there was a corruption in the database and/or the controller as I kept getting zwave binding errors (null pointer exceptions, queue full etc etc).
I have hard reset one of my controllers and am in the slow process of adding the zwave devices back one at a time. Everything seems to be working so far.
