Hm, I again forgot what I had for breakfast this morning
Occasionally I forget breakfast.
Hm, I bookmarked this thread, but don’t remember why (which indicates that I am the oldest in this conversation)
@sihui / Bruce: let me know if/when there is a version that I should test upfront (if it is just the replacement of one .jar or so that would be perfect of course - that I can do manually and also revert easily)
The database changes were merged yesterday:
The latest successful snapshot has been built the day before yesterday:
https://ci.openhab.org/view/Integration%20Builds%20(2.5.x)/job/openHAB2.5.x-Distribution/
You need to wait for the next successful build, download the jar, uninstall the binding through PaperUI, drop the jar into your addons folder.
The changes these days are making me mad, now it looks like we have the snapshot builds over here:
https://ci.openhab.org/view/Integration%20Builds%20(2.5.x)/job/openHAB2.5.x-ZWave/
So you should download it and give it a try.
My bad, that was the link to the distro, the new link is to the zwave snapshot
It still doesn’t seem to work.
I copied the .jar into the shared addon folder and re-created the binding. I assume the right .jar is used as the channel now shows up as “Tamper”:
But in the “Control” tab the value is not shown:
See below the part of the logs when pressing and releasing the tamper swtich on the device.
Btw: I created the items via PaperUI. To me “Switch” is not logical for Tamper, as this is a sensor, not an actor - or am I wrong? Anyway I also tried to configure it via an items-file as “Contact”, but that also did not help.
I am not sure if I do it correctly. Is it possibl to have a joint remote session - e.g. via Skype or so?
Log:
2020-01-07 11:28:34.207 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 05 0A 71 05 00 00 00 FF 07 00 00 00 68
2020-01-07 11:28:34.207 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 192 to 193
2020-01-07 11:28:34.219 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 0A 71 05 00 00 00 FF 07 00 00 00
2020-01-07 11:28:34.224 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 0A 71 05 00 00 00 FF 07 00 00 00
2020-01-07 11:28:34.227 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-01-07 11:28:34.229 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Application Command Request (ALIVE:DONE)
2020-01-07 11:28:34.232 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: resetResendCount initComplete=true isDead=false
2020-01-07 11:28:34.234 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2020-01-07 11:28:34.237 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2020-01-07 11:28:34.239 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2020-01-07 11:28:34.242 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 5: NOTIFICATION report - 0 = 0, event=0, status=255, plen=0
2020-01-07 11:28:34.244 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 5: Alarm Type = BURGLAR (0)
2020-01-07 11:28:34.247 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2020-01-07 11:28:34.249 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2020-01-07 11:28:34.252 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 5: Alarm converter processing NOTIFICATION
2020-01-07 11:28:34.255 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 5: Alarm converter NOTIFICATION event is 0, type OnOffType
2020-01-07 11:28:34.262 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 5: Alarm converter NOTIFICATION event is 0, channel alarm_general is not implemented.
2020-01-07 11:28:34.264 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Commands processed 1.
2020-01-07 11:28:34.266 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1b3a176.
2020-01-07 11:28:34.268 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-07 11:28:34.270 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-07 11:28:34.272 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-01-07 11:28:34.274 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-01-07 11:28:34.358 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 193 to 194
2020-01-07 11:28:34.358 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 05 0A 71 05 00 00 00 FF 07 03 00 00 6B
2020-01-07 11:28:34.366 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 0A 71 05 00 00 00 FF 07 03 00 00
2020-01-07 11:28:34.369 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 0A 71 05 00 00 00 FF 07 03 00 00
2020-01-07 11:28:34.370 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-01-07 11:28:34.372 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Application Command Request (ALIVE:DONE)
2020-01-07 11:28:34.373 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: resetResendCount initComplete=true isDead=false
2020-01-07 11:28:34.374 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2020-01-07 11:28:34.376 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2020-01-07 11:28:34.377 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2020-01-07 11:28:34.378 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 5: NOTIFICATION report - 0 = 0, event=3, status=255, plen=0
2020-01-07 11:28:34.380 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 5: Alarm Type = BURGLAR (0)
2020-01-07 11:28:34.381 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2020-01-07 11:28:34.383 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2020-01-07 11:28:34.384 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 5: Alarm converter processing NOTIFICATION
2020-01-07 11:28:34.386 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 5: Alarm converter NOTIFICATION event is 3, type OnOffType
2020-01-07 11:28:34.387 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 5: Alarm converter NOTIFICATION event is 3, channel alarm_general is not implemented.
2020-01-07 11:28:34.389 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Commands processed 1.
2020-01-07 11:28:34.390 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1b645e4.
2020-01-07 11:28:34.391 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-07 11:28:34.393 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-07 11:28:34.394 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-01-07 11:28:34.395 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
The Paper UI should only be used to administer OH. The Basic UI is the major interface used for daily control.
Ok, but is there a difference when it goes to debugging?
I created a sitemap, which looks like this
The “Door Sensor” icon/open-close follow the changes of the sensor, but the “Tamper” icons stay static.
Also when comparing the logs when 1) the Door sensor is changed (to “close” and back to “open”) looks different from the logs when 2) the Tamper sensor is changed (to “close”=no-alarm and back to “open”). Especially for the door sensor a “channel state” update is logged whereas for the tamper sensor there is no such line:
Detailed logs “door sensor”:
2020-01-07 12:17:12.652 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 05 03 20 01 00 D5
2020-01-07 12:17:12.656 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 308 to 309
2020-01-07 12:17:12.660 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 03 20 01 00
2020-01-07 12:17:12.664 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 03 20 01 00
2020-01-07 12:17:12.666 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-01-07 12:17:12.669 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Application Command Request (ALIVE:DONE)
2020-01-07 12:17:12.673 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: resetResendCount initComplete=true isDead=false
2020-01-07 12:17:12.677 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Incoming command class COMMAND_CLASS_BASIC, endpoint 0
2020-01-07 12:17:12.681 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2020-01-07 12:17:12.685 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Received COMMAND_CLASS_BASIC V1 BASIC_SET
2020-01-07 12:17:12.689 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 5: Basic report, value = 0
2020-01-07 12:17:12.693 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2020-01-07 12:17:12.698 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_BASIC, value=0
2020-01-07 12:17:12.701 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 05 03 30 03 00 C7
2020-01-07 12:17:12.705 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 309 to 310
2020-01-07 12:17:12.705 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating channel state zwave:device:303fa2be:node5:sensor_door to CLOSED [OpenClosedType]
2020-01-07 12:17:12.707 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 03 30 03 00
2020-01-07 12:17:12.709 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Commands processed 1.
2020-01-07 12:17:12.713 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1bb18cf.
2020-01-07 12:17:12.719 [vent.ItemStateChangedEvent] - ZWaveNode005ZW120DoorWindowSensorGen5_DoorSensor changed from OPEN to CLOSED
2020-01-07 12:17:12.719 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-07 12:17:12.721 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-07 12:17:12.725 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 03 30 03 00
2020-01-07 12:17:12.729 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-01-07 12:17:12.731 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 05 0A 71 05 00 00 00 FF 06 17 00 00 7E
2020-01-07 12:17:12.731 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 310 to 311
2020-01-07 12:17:12.733 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Application Command Request (ALIVE:DONE)
2020-01-07 12:17:12.736 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: resetResendCount initComplete=true isDead=false
2020-01-07 12:17:12.739 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
2020-01-07 12:17:12.742 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2020-01-07 12:17:12.746 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Received COMMAND_CLASS_SENSOR_BINARY V1 SENSOR_BINARY_REPORT
2020-01-07 12:17:12.749 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 5: Sensor Binary report, type=Unknown, value=0
2020-01-07 12:17:12.752 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
2020-01-07 12:17:12.755 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=0
2020-01-07 12:17:12.756 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 0A 71 05 00 00 00 FF 06 17 00 00
2020-01-07 12:17:12.758 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating channel state zwave:device:303fa2be:node5:sensor_door to CLOSED [OpenClosedType]
2020-01-07 12:17:12.764 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Commands processed 1.
2020-01-07 12:17:12.767 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@10e32bc.
2020-01-07 12:17:12.770 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-07 12:17:12.772 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-07 12:17:12.776 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 0A 71 05 00 00 00 FF 06 17 00 00
2020-01-07 12:17:12.779 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-01-07 12:17:12.782 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Application Command Request (ALIVE:DONE)
2020-01-07 12:17:12.784 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: resetResendCount initComplete=true isDead=false
2020-01-07 12:17:12.787 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2020-01-07 12:17:12.790 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2020-01-07 12:17:12.792 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2020-01-07 12:17:12.793 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 5: NOTIFICATION report - 0 = 0, event=23, status=255, plen=0
2020-01-07 12:17:12.795 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 5: Alarm Type = ACCESS_CONTROL (0)
2020-01-07 12:17:12.796 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2020-01-07 12:17:12.798 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2020-01-07 12:17:12.800 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 5: Alarm converter processing NOTIFICATION
2020-01-07 12:17:12.802 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 5: Alarm converter NOTIFICATION event is 23, type OnOffType
2020-01-07 12:17:12.805 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 5: Alarm converter NOTIFICATION event is 23, channel alarm_general is not implemented.
2020-01-07 12:17:12.807 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Commands processed 1.
2020-01-07 12:17:12.809 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@12cf726.
2020-01-07 12:17:12.810 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-07 12:17:12.811 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-07 12:17:12.813 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-01-07 12:17:12.814 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-01-07 12:17:13.218 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 05 03 20 01 FF 2A
2020-01-07 12:17:13.221 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 03 20 01 FF
2020-01-07 12:17:13.221 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 311 to 312
2020-01-07 12:17:13.223 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 03 20 01 FF
2020-01-07 12:17:13.225 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-01-07 12:17:13.227 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Application Command Request (ALIVE:DONE)
2020-01-07 12:17:13.229 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: resetResendCount initComplete=true isDead=false
2020-01-07 12:17:13.230 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Incoming command class COMMAND_CLASS_BASIC, endpoint 0
2020-01-07 12:17:13.232 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2020-01-07 12:17:13.233 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Received COMMAND_CLASS_BASIC V1 BASIC_SET
2020-01-07 12:17:13.235 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 5: Basic report, value = 255
2020-01-07 12:17:13.236 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2020-01-07 12:17:13.238 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_BASIC, value=255
2020-01-07 12:17:13.240 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating channel state zwave:device:303fa2be:node5:sensor_door to OPEN [OpenClosedType]
2020-01-07 12:17:13.243 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Commands processed 1.
2020-01-07 12:17:13.246 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3f7f2e.
2020-01-07 12:17:13.246 [vent.ItemStateChangedEvent] - ZWaveNode005ZW120DoorWindowSensorGen5_DoorSensor changed from CLOSED to OPEN
2020-01-07 12:17:13.247 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-07 12:17:13.249 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-07 12:17:13.251 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-01-07 12:17:13.253 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-01-07 12:17:13.268 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 05 03 30 03 FF 38
2020-01-07 12:17:13.271 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 312 to 313
2020-01-07 12:17:13.275 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 03 30 03 FF
2020-01-07 12:17:13.278 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 03 30 03 FF
2020-01-07 12:17:13.280 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-01-07 12:17:13.281 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Application Command Request (ALIVE:DONE)
2020-01-07 12:17:13.283 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: resetResendCount initComplete=true isDead=false
2020-01-07 12:17:13.285 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
2020-01-07 12:17:13.286 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2020-01-07 12:17:13.288 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Received COMMAND_CLASS_SENSOR_BINARY V1 SENSOR_BINARY_REPORT
2020-01-07 12:17:13.290 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 5: Sensor Binary report, type=Unknown, value=255
2020-01-07 12:17:13.291 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
2020-01-07 12:17:13.295 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 05 0A 71 05 00 00 00 FF 06 16 00 00 7F
2020-01-07 12:17:13.297 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 313 to 314
2020-01-07 12:17:13.295 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=255
2020-01-07 12:17:13.301 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 0A 71 05 00 00 00 FF 06 16 00 00
2020-01-07 12:17:13.302 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating channel state zwave:device:303fa2be:node5:sensor_door to OPEN [OpenClosedType]
2020-01-07 12:17:13.306 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Commands processed 1.
2020-01-07 12:17:13.308 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@19b67c6.
2020-01-07 12:17:13.311 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-07 12:17:13.313 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-07 12:17:13.316 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 0A 71 05 00 00 00 FF 06 16 00 00
2020-01-07 12:17:13.317 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-01-07 12:17:13.319 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Application Command Request (ALIVE:DONE)
2020-01-07 12:17:13.323 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: resetResendCount initComplete=true isDead=false
2020-01-07 12:17:13.325 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2020-01-07 12:17:13.327 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2020-01-07 12:17:13.328 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2020-01-07 12:17:13.330 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 5: NOTIFICATION report - 0 = 0, event=22, status=255, plen=0
2020-01-07 12:17:13.333 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 5: Alarm Type = ACCESS_CONTROL (0)
2020-01-07 12:17:13.334 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2020-01-07 12:17:13.336 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2020-01-07 12:17:13.338 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 5: Alarm converter processing NOTIFICATION
2020-01-07 12:17:13.340 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 5: Alarm converter NOTIFICATION event is 22, type OnOffType
2020-01-07 12:17:13.342 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 5: Alarm converter NOTIFICATION event is 22, channel alarm_general is not implemented.
2020-01-07 12:17:13.343 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Commands processed 1.
2020-01-07 12:17:13.345 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1da30db.
2020-01-07 12:17:13.346 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-07 12:17:13.348 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-07 12:17:13.350 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-01-07 12:17:13.351 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
Detailed logs “tamper”:
2020-01-07 12:18:10.460 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 05 0A 71 05 00 00 00 FF 07 00 00 00 68
2020-01-07 12:18:10.462 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 314 to 315
2020-01-07 12:18:10.471 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 0A 71 05 00 00 00 FF 07 00 00 00
2020-01-07 12:18:10.475 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 0A 71 05 00 00 00 FF 07 00 00 00
2020-01-07 12:18:10.478 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-01-07 12:18:10.481 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Application Command Request (ALIVE:DONE)
2020-01-07 12:18:10.484 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: resetResendCount initComplete=true isDead=false
2020-01-07 12:18:10.487 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2020-01-07 12:18:10.490 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2020-01-07 12:18:10.493 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2020-01-07 12:18:10.495 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 5: NOTIFICATION report - 0 = 0, event=0, status=255, plen=0
2020-01-07 12:18:10.498 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 5: Alarm Type = BURGLAR (0)
2020-01-07 12:18:10.501 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2020-01-07 12:18:10.504 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2020-01-07 12:18:10.508 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 5: Alarm converter processing NOTIFICATION
2020-01-07 12:18:10.511 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 5: Alarm converter NOTIFICATION event is 0, type OnOffType
2020-01-07 12:18:10.513 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 5: Alarm converter NOTIFICATION event is 0, channel alarm_general is not implemented.
2020-01-07 12:18:10.516 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Commands processed 1.
2020-01-07 12:18:10.519 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1cf6701.
2020-01-07 12:18:10.521 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-07 12:18:10.524 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-07 12:18:10.526 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-01-07 12:18:10.528 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-01-07 12:18:10.894 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 05 0A 71 05 00 00 00 FF 07 03 00 00 6B
2020-01-07 12:18:10.896 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 315 to 316
2020-01-07 12:18:10.899 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 0A 71 05 00 00 00 FF 07 03 00 00
2020-01-07 12:18:10.901 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 0A 71 05 00 00 00 FF 07 03 00 00
2020-01-07 12:18:10.903 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-01-07 12:18:10.904 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Application Command Request (ALIVE:DONE)
2020-01-07 12:18:10.906 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: resetResendCount initComplete=true isDead=false
2020-01-07 12:18:10.908 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2020-01-07 12:18:10.909 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2020-01-07 12:18:10.911 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2020-01-07 12:18:10.912 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 5: NOTIFICATION report - 0 = 0, event=3, status=255, plen=0
2020-01-07 12:18:10.914 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 5: Alarm Type = BURGLAR (0)
2020-01-07 12:18:10.916 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2020-01-07 12:18:10.917 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2020-01-07 12:18:10.919 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 5: Alarm converter processing NOTIFICATION
2020-01-07 12:18:10.921 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 5: Alarm converter NOTIFICATION event is 3, type OnOffType
2020-01-07 12:18:10.923 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 5: Alarm converter NOTIFICATION event is 3, channel alarm_general is not implemented.
2020-01-07 12:18:10.924 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Commands processed 1.
2020-01-07 12:18:10.926 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@d8bb19.
2020-01-07 12:18:10.927 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-07 12:18:10.929 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-01-07 12:18:10.930 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-01-07 12:18:10.932 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
