OH 3.3.0 on Raspbian.
ZWave binding 3.3.0 (per bundle:list)
I have one specific ZWave device that displays as an empty page in the Settings/Things view.
It displays the Thing name, the status (Online), and the Delete Thing link, but nothing else.
Analyze on one of the items linked to the thing shows that it is receiving regular updates (approx. hourly)
Using the Chrome inspector, I believe I’m looking at the REST call the UI is making to get the Thing properties,
Request URL: http://10.1.3.35:8080/rest/things/zwave:device:f6d34df4:node11
Request Method: GET
Status Code: 200 OK
{"channels":[{"linkedItems":[],"uid":"zwave:device:f6d34df4:node11:sensor_binary","id":"sensor_binary","channelTypeUID":"zwave:sensor_binary","itemType":"Switch","kind":"STATE","label":"Binary Sensor","description":"Indicates if a sensor has triggered","defaultTags":[],"properties":{"binding:*:OnOffType":"COMMAND_CLASS_SENSOR_BINARY"},"configuration":{}},{"linkedItems":["GuestRoomSensor_Sensortemperature"],"uid":"zwave:device:f6d34df4:node11:sensor_temperature","id":"sensor_temperature","channelTypeUID":"zwave:sensor_temperature","itemType":"Number:Temperature","kind":"STATE","label":"Sensor (temperature)","description":"Indicates the current temperature","defaultTags":[],"properties":{"binding:*:QuantityType":"COMMAND_CLASS_SENSOR_MULTILEVEL;type\u003dTEMPERATURE"},"configuration":{}},{"linkedItems":[],"uid":"zwave:device:f6d34df4:node11:sensor_dewpoint","id":"sensor_dewpoint","channelTypeUID":"zwave:sensor_dewpoint","itemType":"Number","kind":"STATE","label":"Sensor (dew point)","description":"Indicates the dewpoint","defaultTags":[],"properties":{"binding:*:DecimalType":"COMMAND_CLASS_SENSOR_MULTILEVEL;type\u003dDEW_POINT"},"configuration":{}},{"linkedItems":["GuestRoomSensor_Sensorrelativehumidity"],"uid":"zwave:device:f6d34df4:node11:sensor_relhumidity","id":"sensor_relhumidity","channelTypeUID":"zwave:sensor_relhumidity","itemType":"Number","kind":"STATE","label":"Sensor (relative humidity)","description":"Indicates the current relative humidity","defaultTags":[],"properties":{"binding:*:DecimalType":"COMMAND_CLASS_SENSOR_MULTILEVEL;type\u003dRELATIVE_HUMIDITY"},"configuration":{}},{"linkedItems":[],"uid":"zwave:device:f6d34df4:node11:alarm_general","id":"alarm_general","channelTypeUID":"zwave:alarm_general","itemType":"Switch","kind":"STATE","label":"Alarm","description":"Indicates if an alarm is triggered","defaultTags":[],"properties":{"binding:*:OnOffType":"COMMAND_CLASS_ALARM"},"configuration":{}},{"linkedItems":["GuestRoomSensor_BatteryLevel"],"uid":"zwave:device:f6d34df4:node11:battery-level","id":"battery-level","channelTypeUID":"system:battery-level","itemType":"Number","kind":"STATE","label":"Battery Level","defaultTags":[],"properties":{"binding:*:PercentType":"COMMAND_CLASS_BATTERY"},"configuration":{}}],"statusInfo":{"status":"ONLINE","statusDetail":"NONE"},"editable":true,"label":"Guest Room Sensor","bridgeUID":"zwave:serial_zstick:f6d34df4","configuration":{"config_64_0":1.0,"config_11_1":0,"config_10_1":0,"config_255_4":0,"group_5":[],"group_4":[],"group_6":[],"wakeup_interval":604800,"group_1":["controller"],"group_3":[],"group_2":[],"config_1_1":20,"config_2_1":5,"config_6_2":10,"config_7_1":0,"wakeup_node":1,"config_8_1":0,"config_9_1":255,"config_12_1":0,"config_13_1":0,"config_4_2":3600,"config_5_2":0,"node_id":11},"properties":{"zwave_class_basic":"BASIC_TYPE_ROUTING_SLAVE","zwave_class_generic":"GENERIC_TYPE_SENSOR_NOTIFICATION","zwave_lastwakeup":"2023-03-15T13:36:53Z","zwave_neighbours":"5","modelId":"ZWA009","zwave_plus_devicetype":"NODE_TYPE_ZWAVEPLUS_NODE","zwave_version":"2.0","defaultAssociations":"1","vendor":"Aeotec Limited","zwave_routing":"true","zwave_beaming":"true","zwave_secure":"false","zwave_class_specific":"SPECIFIC_TYPE_NOTIFICATION_SENSOR","zwave_devicetype":"258","zwave_frequent":"false","zwave_listening":"false","manufacturerId":"0371","manufacturerRef":"0002:0009,0102:0009","dbReference":"1336","zwave_deviceid":"9","zwave_nodeid":"11","zwave_lastheal":"2022-02-25T17:14:33Z","zwave_plus_roletype":"ROLE_TYPE_SLAVE_SLEEPING_REPORTING","zwave_manufacturer":"881"},"UID":"zwave:device:f6d34df4:node11","thingTypeUID":"zwave:aeotec_zwa009_00_000","location":"Guest Room"}```
A subsequent call may be responsible?
Request URL: http://10.1.3.35:8080/rest/thing-types/zwave:aeotec_zwa009_00_000
Request Method: GET
Status Code: 204 No Content
This item worked when I originally set it up - which may have been on an earlier OH version.
I’ve restarted the ZWave binding (via bundle:restart), but haven’t take any other actions at this point to try to correct this.
I’ve turned on DEBUG logging for the binding, and I’m waiting for the next update to come around to see if anything stands out there.
Edit: typo
