I have a Kwikset Convert Zwave lock. I am able to discover and add the device to openhab, but it never identifies the device properly. I’m running openhab 2.5 build 1549. I see this error in the logs:
[WARN ] [org.openhab.binding.zwave.discovery.ZWaveDiscoveryService] - NODE 10: Device discovery could not resolve to a thingType! 0090:0003:0446::4.45
Looking in the device database, I see the item there, and I see the manufacturer id, and references. They all seem to match.
Can any kind soul shed some light on this? Thanks!
I believe it has to be done via Habmin vs PaperUI. It may also help to change the logging level of zwave and leverage the log viewer at Chris’s site and one of the more experienced zwave guys may have a better idea on a resolution.
Yes, it does seem to match what’s in the database here.
Unfortunately, no. It looks like it should work.
Yes.
Note: As a general rule, it’s best to use HABmin to manage your zwave devices, although I’m not saying that that’s the issue you’re experiencing here.
It might be best to exclude the device, then include it again with debugging enabled. Then post the debug log and we can try to better identify what’s happening.
you have a kwikset lock
it gets discovered
OH never identifies the device
you are running openhab 2.5 build 1549
it would be better to start a new thread
either way, please include your OS/platform, OpenHAB version, zwave version
set your logs to debug as described in the ‘when things don’t go as planned’ section of the binding documentation found here
