ZWAVE unknown device Aeotec ZWA045 sensor
OH 4.3 (huzzah)
Pi4 Bookworm
I have an Aeotec ZWA045-A TriSensor 8 (thank you Santa) that is not recognized by the zwave binding
Z-Wave Node 030 (0371:0102:002D:2.7)
unknown device
I’m not sure if I have a device with a new set of references. There is a device in the Open Smart House database although it is not a -A and the type is 0002:002D where mine looks like 0102:002D. Also, the device in the database appears to be marked OH-SNAPSHOT with a last approval date 2024-09-21 although I don’t know the import of that.
There is a definition in the zwave jar file
    22706  2024-12-15 16:40   OH-INF/thing/aeotec/zwa045_0_0.xml
The xml file produced for my device is
<node>
  <homeId>0xd7aa21e1</homeId>
  <nodeId>30</nodeId>
  <version>4</version>
  <manufacturer>0x371</manufacturer>
  <deviceId>0x2d</deviceId>
  <deviceType>0x102</deviceType>
  <listening>false</listening>
  <frequentlyListening>false</frequentlyListening>
  <routing>true</routing>
  <security>false</security>
  <beaming>true</beaming>
  <maxBaudRate>40000</maxBaudRate>
  <sleepDelay>500</sleepDelay>
  <nodeInformationFrame>
    <commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
    <commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
    <commandClass>COMMAND_CLASS_ASSOCIATION_GRP_INFO</commandClass>
    <commandClass>COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION</commandClass>
    <commandClass>COMMAND_CLASS_BATTERY</commandClass>
    <commandClass>COMMAND_CLASS_SENSOR_MULTILEVEL</commandClass>
    <commandClass>COMMAND_CLASS_ALARM</commandClass>
    <commandClass>COMMAND_CLASS_APPLICATION_STATUS</commandClass>
    <commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
    <commandClass>COMMAND_CLASS_TRANSPORT_SERVICE</commandClass>
    <commandClass>COMMAND_CLASS_VERSION</commandClass>
    <commandClass>COMMAND_CLASS_WAKE_UP</commandClass>
    <commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
    <commandClass>COMMAND_CLASS_DEVICE_RESET_LOCALLY</commandClass>
    <commandClass>COMMAND_CLASS_INDICATOR</commandClass>
    <commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
    <commandClass>COMMAND_CLASS_SECURITY</commandClass>
    <commandClass>COMMAND_CLASS_SECURITY_2</commandClass>
    <commandClass>COMMAND_CLASS_SUPERVISION</commandClass>
    <commandClass>COMMAND_CLASS_FIRMWARE_UPDATE_MD</commandClass>
  </nodeInformationFrame>
  <associationGroups class="concurrent-hash-map">
    <entry>
      <int>1</int>
      <associationGroup>
        <index>1</index>
        <maxNodes>0</maxNodes>
        <associations/>
      </associationGroup>
    </entry>
    <entry>
      <int>2</int>
      <associationGroup>
        <index>2</index>
        <associations/>
      </associationGroup>
    </entry>
    <entry>
      <int>3</int>
      <associationGroup>
        <index>3</index>
        <associations/>
      </associationGroup>
    </entry>
    <entry>
      <int>4</int>
      <associationGroup>
        <index>4</index>
        <associations/>
      </associationGroup>
    </entry>
    <entry>
      <int>5</int>
      <associationGroup>
        <index>5</index>
        <associations/>
      </associationGroup>
    </entry>
    <entry>
      <int>6</int>
      <associationGroup>
        <index>6</index>
        <associations/>
      </associationGroup>
    </entry>
    <entry>
      <int>7</int>
      <associationGroup>
        <index>7</index>
        <associations/>
      </associationGroup>
    </entry>
  </associationGroups>
  <endpoints class="concurrent-hash-map">
    <entry>
      <int>0</int>
      <endPoint>
        <deviceClass>
          <basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
          <genericDeviceClass>GENERIC_TYPE_SENSOR_NOTIFICATION</genericDeviceClass>
          <specificDeviceClass>SPECIFIC_TYPE_NOTIFICATION_SENSOR</specificDeviceClass>
        </deviceClass>
        <endpointId>0</endpointId>
        <secureCommandClasses/>
        <supportedCommandClasses class="concurrent-hash-map">
          <entry>
            <commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
            <COMMAND__CLASS__NO__OPERATION>
              <version>1</version>
              <instances>1</instances>
              <control>false</control>
              <versionSupported>1</versionSupported>
            </COMMAND__CLASS__NO__OPERATION>
          </entry>
          <entry>
            <commandClass>COMMAND_CLASS_BASIC</commandClass>
            <COMMAND__CLASS__BASIC>
              <version>0</version>
              <instances>0</instances>
              <versionSupported>0</versionSupported>
              <isGetSupported>true</isGetSupported>
            </COMMAND__CLASS__BASIC>
          </entry>
          <entry>
            <COMMAND__CLASS__APPLICATION__STATUS>
            </COMMAND__CLASS__APPLICATION__STATUS>
          </entry>
          <entry>
            <COMMAND__CLASS__SENSOR__MULTILEVEL>
              <version>11</version>
              <versionSupported>11</versionSupported>
              <sensors>
                <entry>
                  <multilevelSensorType>TEMPERATURE</multilevelSensorType>
                  <multilevelSensor>
                    <sensorType>TEMPERATURE</sensorType>
                    <initialised>true</initialised>
                  </multilevelSensor>
                </entry>
                <entry>
                  <multilevelSensorType>LUMINANCE</multilevelSensorType>
                  <multilevelSensor>
                    <sensorType>LUMINANCE</sensorType>
                  </multilevelSensor>
                </entry>
              </sensors>
            </COMMAND__CLASS__SENSOR__MULTILEVEL>
          </entry>
          <entry>
            <COMMAND__CLASS__ASSOCIATION__GRP__INFO>
              <versionSupported>3</versionSupported>
              <autoSubscribeGroups/>
            </COMMAND__CLASS__ASSOCIATION__GRP__INFO>
          </entry>
          <entry>
            <COMMAND__CLASS__DEVICE__RESET__LOCALLY>
            </COMMAND__CLASS__DEVICE__RESET__LOCALLY>
          </entry>
          <entry>
            <COMMAND__CLASS__ZWAVEPLUS__INFO>
              <versionSupported>2</versionSupported>
              <zwPlusVersion>2</zwPlusVersion>
              <zwPlusRole>ROLE_TYPE_SLAVE_SLEEPING_REPORTING</zwPlusRole>
              <zwPlusNodeType>NODE_TYPE_ZWAVEPLUS_NODE</zwPlusNodeType>
            </COMMAND__CLASS__ZWAVEPLUS__INFO>
          </entry>
          <entry>
            <COMMAND__CLASS__CONFIGURATION>
              <versionSupported>4</versionSupported>
              <configParameters/>
            </COMMAND__CLASS__CONFIGURATION>
          </entry>
          <entry>
            <COMMAND__CLASS__ALARM>
              <version>8</version>
              <versionSupported>8</versionSupported>
              <alarms>
                <entry>
                  <alarmType>BURGLAR</alarmType>
                  <alarmState>
                    <reportedEvents>
                      <int>8</int>
                    </reportedEvents>
                    <outer-class reference="../../../.."/>
                  </alarmState>
                </entry>
                <entry>
                  <alarmType>POWER_MANAGEMENT</alarmType>
                  <alarmState>
                    <reportedEvents/>
                  </alarmState>
                </entry>
                <entry>
                  <alarmType>SYSTEM</alarmType>
                  <alarmState>
                    <reportedEvents/>
                  </alarmState>
                </entry>
              </alarms>
              <v1Supported>true</v1Supported>
            </COMMAND__CLASS__ALARM>
          </entry>
          <entry>
            <COMMAND__CLASS__MANUFACTURER__SPECIFIC>
              <initSerialNumber>false</initSerialNumber>
              <deviceManufacturer>881</deviceManufacturer>
              <deviceType>258</deviceType>
              <deviceId>45</deviceId>
            </COMMAND__CLASS__MANUFACTURER__SPECIFIC>
          </entry>
          <entry>
            <COMMAND__CLASS__POWERLEVEL>
              <powerLevel>0</powerLevel>
              <powerTimeout>0</powerTimeout>
            </COMMAND__CLASS__POWERLEVEL>
          </entry>
          <entry>
            <COMMAND__CLASS__FIRMWARE__UPDATE__MD>
              <versionSupported>5</versionSupported>
            </COMMAND__CLASS__FIRMWARE__UPDATE__MD>
          </entry>
          <entry>
            <COMMAND__CLASS__BATTERY>
              <batteryLevel>90</batteryLevel>
              <batteryLow>false</batteryLow>
            </COMMAND__CLASS__BATTERY>
          </entry>
          <entry>
            <COMMAND__CLASS__WAKE__UP>
              <version>2</version>
              <targetNodeId>1</targetNodeId>
              <interval>7200</interval>
              <minInterval>1800</minInterval>
              <maxInterval>86400</maxInterval>
              <defaultInterval>28800</defaultInterval>
              <intervalStep>60</intervalStep>
            </COMMAND__CLASS__WAKE__UP>
          </entry>
          <entry>
            <COMMAND__CLASS__ASSOCIATION>
              <maxGroups>7</maxGroups>
            </COMMAND__CLASS__ASSOCIATION>
          </entry>
          <entry>
            <COMMAND__CLASS__VERSION>
              <libraryType>LIB_SLAVE_ENHANCED</libraryType>
              <protocolVersion>7.18</protocolVersion>
              <applicationVersion>2.7</applicationVersion>
              <hardwareVersion>1</hardwareVersion>
            </COMMAND__CLASS__VERSION>
          </entry>
          <entry>
            <COMMAND__CLASS__INDICATOR>
              <version>3</version>
              <supportedIndicatorsInitialised>true</supportedIndicatorsInitialised>
              <supportedIndicators>
                <ZWaveIndicator>
                  <type>NODE_IDENTIFY</type>
                </ZWaveIndicator>
              </supportedIndicators>
            </COMMAND__CLASS__INDICATOR>
          </entry>
          <entry>
            <COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
            </COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
          </entry>
          <entry>
            <COMMAND__CLASS__SECURITY>
            </COMMAND__CLASS__SECURITY>
          </entry>
        </supportedCommandClasses>
      </endPoint>
    </entry>
  </endpoints>
  <nodeNeighbors>
    <int>1</int>
    <int>16</int>
    <int>17</int>
    <int>19</int>
    <int>20</int>
    <int>21</int>
    <int>22</int>
    <int>23</int>
    <int>24</int>
    <int>26</int>
    <int>27</int>
    <int>32</int>
  </nodeNeighbors>
  <lastReceived>2024-12-30 08:56:58.730 UTC</lastReceived>
The instructions say to raise an issue, so here I am. If I had the slightest idea what bits to twiddle, I would experiment, but, alas…
For background Guidance for "unknown" Zwave Device
So now I’m confused. I’ve been chasing this all day and where I am stymied is in the guidance you provided because that is how I got here. From the guidance
So, with that background when confronting an unknown device.
1. Check your device TYPE:ID in your local XML
2. Check the [ZW DB ](https://www.opensmarthouse.org/zwavedatabase/) for your device and the TYPE:ID’s currently mapped.
3. Assess the last update date-time relative to your OH version. This could be a bit tricky. Lately (due to time zone communication issues and the developer schedule) the ZW binding DB updates are not included in stable patch releases. For instance, the last DB update for any OH4.1.x (0, 1, 2, etc.) was December 19, 2023. If the DB date-time is after that, OH4.2 applies to the options below
4. Options
a) If the device and/or the local TYPE:ID not in DB, it will need to be added (see [ZW DB Blog ](https://www.opensmarthouse.org/blog/))
The device in the database described by ‘ZWA045’ is 0002:002d.
Here is a screen shot
Manufacturer|[0371] Aeotec Limited|
|Label|ZWA045|
|Description|Motion, light, and temperature sensor|
|Type|0002:002D|
|Category|Sensor|
My device is a ZWA045 with a type 0102:222D
Here is a snippet from the xml file
I gathered from the guidance that maybe I should update from a SNAPSHOT but from what I can tell the entries in the jars match the database.
I’m thinking that a new reference needs to be appended in the DB so that it reads
0002:002D,0102:002D
There are similar examples of this under other Aerotec devices where there are combinations of device type 0002 and 0102 used the same reference combined with the same device id
I think you have it figured out. The local TYPE:ID is not in the database, so needs to be added. (option4a)
I just modified that for someone else on the forum, but that is not the change you need.
Try this file
zwa045_0_0.xml (22.5 KB)
with this method
EDIT: I edited the DB for the future
Thank you and Happy New Year. That is the bit twiddling I needed
