Please explain in more detail what your problem is.
Increase loglevel (log:set debug org.openhab.binding.zwave in Karaf console) as your log does not show anything relevant to a potential zwave controller malfunction.
Stop rebooting - that won’t help. Increase debug level as I wrote.
Start Karaf console by running openhab-cli console in shell.
And read the openHABian README and openHAB docs, it’s all in there.
No - it has nothing to do with the stick communications. It simply states that these are your settings before the binding starts. I don’t think at this point that there is any communications with the controller.
I think it is an USB On the Go (OTG) related issue of Raspberry Pi Zero Wifi. Maybe someone wich have some experience with RPI Zero Wifi could help here. I found a lot of people in this forum stucked with RPI Zero wich simple abandoned to install OH2 on RPI Zero Wifi because of lack of support.
Maybe it’s worth trying a post on a Pi Zero support forum to resolve some of these hardware specific issues? By definition, you’re unlikely to find a lot of support for hardware that is not used very much .
Thanks for feedback, C. I’ve had a great experience on this forum setting up my RPI2B so I came back for this new approach with RPI Zero. I didn’t realise that not many people avoid RPI Zero board.
I do not personally know if it’s popular, I’m only going by your earlier statement where you said that people were not supported on the RPi Zero. It is clearly going to be very entry level hardware, and if there’s not too many people within the community to support it, then you may need to look elsewhere for the answer…
However - once you find it (hopefully), maybe you can report back and answer all the other questions . Then we can break the cycle.
