I’m using arround 30 wall plugs (zwave) in my house. Every few weeks when normally “hot water” system should start at 6:30am, it seems to not do anything at all. And i have no idea what could be the problem.
Not sure what is the reason (reset Raspi with v2.5.2, unplug the wall plugs,) but after this happens all is fine for the next few weeks.
Its also not only the FRISTAR_hotwater system but also other switches in the basement that do not work…Connectivity is good, so its all arround 10m apart from the controller.
@chris , any idea what i could try…its hard to log more detailed as it would take weeks until it happens again. At 6:53 i realized in the shower that again i ran into this issue so i turned on manually.
2020-04-30 06:30:00.113 [ome.event.ItemCommandEvent] - Item 'FRISTAR_Switch' received command ON
2020-04-30 06:30:00.166 [nt.ItemStatePredictedEvent] - FRISTAR_Switch predicted to become ON
2020-04-30 06:30:00.217 [vent.ItemStateChangedEvent] - FRISTAR_Switch changed from OFF to ON
2020-04-30 06:31:22.698 [vent.ItemStateChangedEvent] - FRISTAR_Switch changed from ON to OFF
2020-04-30 06:53:18.728 [ome.event.ItemCommandEvent] - Item 'FRISTAR_Switch' received command ON
2020-04-30 06:53:18.761 [nt.ItemStatePredictedEvent] - FRISTAR_Switch predicted to become ON
2020-04-30 06:53:18.809 [vent.ItemStateChangedEvent] - FRISTAR_Switch changed from OFF to ON
