I have a problem with openhab, switches themselves sometimes turn on lights.
Their state changes the automatically from OFF to ON and vice versa.
My modules are PAN06, openhab version 1.8.0.
Where to find solutions?
Slawomir
Slawomir
What are your Item configurations?
Do you have any Rules that work with these Items?
Do you have any logs from around when the lights automatically turn on?
Item Configurations:
Switch Salon_wlacznik_1_0 "Oczka" <switch> (GF_Living) { zwave="17:1" }
Number Power_Salon_wlacznik_1_0 "Energia Salon_wlacznik_1_0 [%.1f W]" (GF_Living,GF_Energy,GF_Energy_Chart) { zwave="17:1:command=meter,meter_scale=E_W,refresh_interval=60" }
Number Energy_Salon_wlacznik_1_0 "Zuzycie energii [%.4f KWh]" (GF_Living) { zwave="17:1:command=meter,meter_scale=E_KWh,refresh_interval=300" }
Number Voltage_Salon_wlacznik_1_0 "Napiecie [%.1f V]" (GF_Living) { zwave="17:1:command=meter,meter_scale=E_V,refresh_interval=300" }
Switch Salon_wlacznik_1_1 "Oczka dwa pasy" <switch> (GF_Living) { zwave="17:2" }
Number Power_Salon_wlacznik_1_1 "Energia Salon_wlacznik_1_1 [%.1f W]" (GF_Living,GF_Energy,GF_Energy_Chart) { zwave="17:2:command=meter,meter_scale=E_W,refresh_interval=60" }
Number Energy_Salon_wlacznik_1_1 "Zuzycie energii [%.4f KWh]" (GF_Living) { zwave="17:2:command=meter,meter_scale=E_KWh,refresh_interval=300" }
Switch Salon_wlacznik_1_2 "Oczka jeden pas" <switch> (GF_Living) { zwave="17:3" }
Number Power_Salon_wlacznik_1_2 "Energia Salon_wlacznik_1_2 [%.1f W]" (GF_Living,GF_Energy,GF_Energy_Chart) { zwave="17:3:command=meter,meter_scale=E_W,refresh_interval=60" }
Number Energy_Salon_wlacznik_1_2 "Zuzycie energii [%.4f KWh]" (GF_Living) { zwave="17:3:command=meter,meter_scale=E_KWh,refresh_interval=300" }
I don’t have any rules.
this is openhab.log
2015-10-25 04:31:00.005 [INFO ] [penhab.model.script.Base Rules] - *** *** *** SunSet Updated *** *** ***::2015-10-25T15:18:35
2015-10-25 04:31:00.025 [INFO ] [penhab.model.script.Base Rules] - *** *** *** SunRise Updated *** *** ***::2015-10-25T05:17:08
2015-10-25 04:31:38.364 [INFO ] [penhab.model.script.Base Rules] - *** *** *** SunRise Updated *** *** ***::2015-10-25T05:17:13
2015-10-25 04:31:38.413 [INFO ] [penhab.model.script.Base Rules] - *** *** *** SunSet Updated *** *** ***::2015-10-25T15:18:30
2015-10-25 04:32:00.005 [INFO ] [penhab.model.script.Base Rules] - *** *** *** SunSet Updated *** *** ***::2015-10-25T15:18:30
2015-10-25 04:32:00.027 [INFO ] [penhab.model.script.Base Rules] - *** *** *** SunRise Updated *** *** ***::2015-10-25T05:17:13
2015-10-25 04:33:00.005 [INFO ] [penhab.model.script.Base Rules] - *** *** *** SunSet Updated *** *** ***::2015-10-25T15:18:30
2015-10-25 04:33:00.026 [INFO ] [penhab.model.script.Base Rules] - *** *** *** SunRise Updated *** *** ***::2015-10-25T05:17:13
2015-10-25 04:33:01.806 [ERROR] [WaveController$ZWaveSendThread] - NODE 11: Timeout while sending message. Requeueing - 0 attempts left!
2015-10-25 04:33:01.807 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 11: Node is DEAD. Dropping message.
2015-10-25 04:33:06.809 [ERROR] [WaveController$ZWaveSendThread] - NODE 17: Timeout while sending message. Requeueing - 2 attempts left!
2015-10-25 04:33:06.810 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 17: Got an error while sending data. Resending message.
2015-10-25 04:33:11.814 [ERROR] [WaveController$ZWaveSendThread] - NODE 17: Timeout while sending message. Requeueing - 1 attempts left!
2015-10-25 04:33:11.814 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 17: Got an error while sending data. Resending message.
2015-10-25 04:33:12.889 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 17: Sent Data was not placed on stack due to error 0.
2015-10-25 04:33:16.818 [ERROR] [WaveController$ZWaveSendThread] - NODE 17: Timeout while sending message. Requeueing - 0 attempts left!
2015-10-25 04:33:16.819 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 17: Node is DEAD. Dropping message.
2015-10-25 04:33:16.830 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 5: Sent Data was not placed on stack due to error 0.
2015-10-25 04:33:21.827 [ERROR] [WaveController$ZWaveSendThread] - NODE 5: Timeout while sending message. Requeueing - 2 attempts left!
2015-10-25 04:33:21.827 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 5: Got an error while sending data. Resending message.
2015-10-25 04:33:21.924 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 5: Sent Data was not placed on stack due to error 0.
2015-10-25 04:33:26.831 [ERROR] [WaveController$ZWaveSendThread] - NODE 5: Timeout while sending message. Requeueing - 1 attempts left!
2015-10-25 04:33:26.831 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 5: Got an error while sending data. Resending message.
2015-10-25 04:33:26.838 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 5: Sent Data was not placed on stack due to error 0.
2015-10-25 04:33:27.153 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 5: Node is DEAD. Dropping message.
2015-10-25 04:33:27.178 [ERROR] [NodeNeighborUpdateMessageClass] - NODE 17: NodeNeighborUpdate FAILED
2015-10-25 04:33:27.184 [ERROR] [NodeNeighborUpdateMessageClass] - NODE 17: NodeNeighborUpdate FAILED
2015-10-25 04:33:27.190 [ERROR] [NodeNeighborUpdateMessageClass] - NODE 17: NodeNeighborUpdate FAILED
2015-10-25 04:33:27.197 [ERROR] [NodeNeighborUpdateMessageClass] - NODE 17: NodeNeighborUpdate FAILED
2015-10-25 04:33:27.370 [ERROR] [eController$ZWaveReceiveThread] - Protocol error (CAN), resending
2015-10-25 04:33:27.371 [WARN ] [b.z.i.p.s.SendDataMessageClass] - NODE 17: Already processed another send data request for this callback Id, ignoring.
2015-10-25 04:33:27.473 [WARN ] [b.z.i.p.s.SendDataMessageClass] - NODE 17: Already processed another send data request for this callback Id, ignoring.
2015-10-25 04:33:27.477 [ERROR] [eController$ZWaveReceiveThread] - Protocol error (CAN), resending
2015-10-25 04:33:33.182 [ERROR] [NodeNeighborUpdateMessageClass] - NODE 5: NodeNeighborUpdate FAILED
2015-10-25 04:33:33.188 [ERROR] [NodeNeighborUpdateMessageClass] - NODE 5: NodeNeighborUpdate FAILED
2015-10-25 04:33:33.194 [ERROR] [NodeNeighborUpdateMessageClass] - NODE 5: NodeNeighborUpdate FAILED
2015-10-25 04:33:33.200 [ERROR] [NodeNeighborUpdateMessageClass] - NODE 5: NodeNeighborUpdate FAILED
2015-10-25 04:34:00.005 [INFO ] [penhab.model.script.Base Rules] - *** *** *** SunSet Updated *** *** ***::2015-10-25T15:18:30
2015-10-25 04:34:00.024 [INFO ] [penhab.model.script.Base Rules] - *** *** *** SunRise Updated *** *** ***::2015-10-25T05:17:13
2015-10-25 04:34:42.779 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 15: Node is DEAD. Dropping message.
2015-10-25 04:34:47.783 [ERROR] [WaveController$ZWaveSendThread] - NODE 7: Timeout while sending message. Requeueing - 0 attempts left!
2015-10-25 04:34:47.783 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 7: Node is DEAD. Dropping message.
2015-10-25 04:34:52.786 [ERROR] [WaveController$ZWaveSendThread] - NODE 3: Timeout while sending message. Requeueing - 2 attempts left!
2015-10-25 04:34:52.786 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 3: Got an error while sending data. Resending message.
2015-10-25 04:34:57.789 [ERROR] [WaveController$ZWaveSendThread] - NODE 3: Timeout while sending message. Requeueing - 1 attempts left!
2015-10-25 04:34:57.789 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 3: Got an error while sending data. Resending message.
2015-10-25 04:34:57.795 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 3: Sent Data was not placed on stack due to error 0.
2015-10-25 04:35:00.005 [INFO ] [penhab.model.script.Base Rules] - *** *** *** SunSet Updated *** *** ***::2015-10-25T15:18:30
2015-10-25 04:35:00.419 [INFO ] [penhab.model.script.Base Rules] - *** *** *** SunRise Updated *** *** ***::2015-10-25T05:17:13
2015-10-25 04:35:02.793 [ERROR] [WaveController$ZWaveSendThread] - NODE 3: Timeout while sending message. Requeueing - 0 attempts left!
2015-10-25 04:35:02.794 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 3: Node is DEAD. Dropping message.
2015-10-25 04:35:02.853 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 19: Sent Data was not placed on stack due to error 0.
2015-10-25 04:35:06.661 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 19: Got an error while sending data. Resending message.
2015-10-25 04:35:06.892 [ERROR] [NodeNeighborUpdateMessageClass] - NODE 3: NodeNeighborUpdate FAILED
2015-10-25 04:35:06.898 [ERROR] [NodeNeighborUpdateMessageClass] - NODE 3: NodeNeighborUpdate FAILED
2015-10-25 04:35:06.904 [ERROR] [NodeNeighborUpdateMessageClass] - NODE 3: NodeNeighborUpdate FAILED
2015-10-25 04:35:06.910 [ERROR] [NodeNeighborUpdateMessageClass] - NODE 3: NodeNeighborUpdate FAILED
2015-10-25 04:36:00.005 [INFO ] [penhab.model.script.Base Rules] - *** *** *** SunSet Updated *** *** ***::2015-10-25T15:18:30
It seems like the node you use is very lazy to responde (if at all).
How did you include the node in question?
For inclusion, the device has to be within reach of the controller. Where did you deploy the device after that?
Do you heal your network regularly? (E.g. did you set a heal time in the binding configuration?
If you feel like you did everything right and it still does not work you could try to restart your whole zwave network from scratch. Off course that means that you have to exclude all your devices, reset your controller and then include every node again.
Sławek, are you sure that PAN 06 has the metering module? According to http://www.z-wave.pl/pl/c/Moduly-podtynkowe/13 it is only on/off swith.
It seems like connectivity problem, please check if it work when antena is positioned differenlty. I had huge intereference problems with PAN08 roller shutter controller in one location and had to rearange the wires from the wall switch to the module to make it work. The module was ok (I checked two of them) and was falling to the error mode and required reboot.
I use PAN 04 and AEON Labs USB S2 stick, they work without any issues.
My setting is:
Switch PAN04_Toaleta { zwave="14:command=SWITCH_BINARY" } // To get rid of warnings
Switch Grzejnik_Toaleta_Reczniki_ster "Grzejnik ręczniki" <heating> { zwave="14:1:command=SWITCH_BINARY" }
Switch Wentylator_Toaleta "Wentylator" <selfAiring> { zwave="14:2:command=SWITCH_BINARY,refresh_interval=30" }
Your right. it is PAN04, i bought it in the same place z-wave.pl.
i have 15 modules PAN04.
This module is about 1 metre from AEON Labs USB S2 stick.
It was work good about 3 months, and now without changes I have problem.
What you mean?
It is about 1 metre.
What you mean?
No. Now I set it.
it is hard becouse I have 15 modules PAN 04.
I know this is a last point
please to e-mail to ep121 małpa nazwisko kropka info
