Yes - that would be fine. Restart, wait a few minutes for things to settle (maybe longer if you’re on a slow machine), then wake the device a few times - let’s say 4 times, waking it every 10 seconds. This ought to ensure that we get enough transactions through to see what is happening.
Choose your favourite web hosting system, and post there (eg dropbox, github etc). Then just provide the link here.
Please don’t filter the log - just provide it as it comes as you will likely miss some stuff. I use a log viewer to filter, and it does all the hard work.
I’m not completely sure where PaperUI picks that up from, but it looks like most devices are ok. Do you have channels available for the devices? Also are the properties showing up when you click on the thing?
For reference the “Unknown” label in the inbox was due to the way the binding handles the thing-types. They are normally changed after the device is instantiated, and this means the “Unknown” label remains while the thing is in the inbox.
The following PR changes the way discovery works and should remove this “feature”.
No, not directly - but the UID of the device may change and that is probably what you are seeing. In the past it was always device but it now uses the “proper” device UID if it’s known while the device is still in the inbox after discovery. This was done to get rid of the “Unknown device” label in the inbox even when the device is known.
Hmmm - ok, I’m not sure how to work around that. We could leave it as it was, and live with all devices being marked as Unknown, which I don’t like now that I see it in PaperUI. This is a one off issue - if you rediscover the same device again, it should still have the same (ie new) UID.
Sorry - I missed your edit. Again, it’s the same point as above related to the UID change.
So, to be clear, I don’t necessarily have a problem with the change. I think it makes sense. It’s just that anyone who installs this version will be surprised.
If they rediscover a node, none of the items linked to channels on that node will update until they edit the channel ID in their items file. It took me a while to realize that the channel ID changed.
Their inbox also will fill up with new versions of all their existing nodes, and this will be confusing.
