Hello
My Setup
################# openHABianPi #################################### 7.05.170509
## Ip = 192.168.2.5
## Release = Raspbian GNU/Linux 8 (jessie)
## Kernel = Linux 4.9.35-v7+
## Platform = Raspberry Pi 3 Model B Rev 1.2
## Uptime = 3 day(s). 3:48:28
## CPU Usage = 1.76 % avg over 4 cpu(s) (4 core(s) x 1 socket(s))
## CPU Load = 1m: 0.85, 5m: 0.70, 15m: 0.63
## Memory = Free: 0.03GB (3%), Used: 0.91GB (97%), Total: 0.94GB
## Swap = Free: 0.08GB (86%), Used: 0.01GB (14%), Total: 0.09GB
## Root = Free: 10.43GB (77%), Used: 3.11GB (23%), Total: 14.14GB
## Updates = 0 apt-get updates available.
## Sessions = 1 sessions
## Processes = 135 running processes of 32768 maximum processes
Welcome to __ _____ ____ _
____ ____ ___ ____ / / / / | / __ )(_)___ _____
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ / / __ `/ __ \
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ / / /_/ / / / /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/_/\__,_/_/ /_/
/_/
openHAB 2.2.0-1 (Release Build)
Looking for a place to get started? Check out ‘sudo openhabian-config’ and the
documentation at http://docs.openhab.org/installation/openhabian.html
The openHAB dashboard can be reached at http://openHABianPi:8080
I am having trouble with xml file not generating for monoprice
Z-Wave Plus Smart Plug and Repeater with 2 USB Ports (Works with Alexa & Google Home with Hub)
no issue with monoprice motion sensor…
Appreciate your help
[11:33:05] openhabian@openHABianPi:/srv/openhab2-userdata/zwave$ tail -f /var/log/openhab2/openhab.log
2017-12-23 11:26:51.110 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘zwave:device:8384dd0e:node40’ to inbox.
2017-12-23 11:27:06.441 [WARN ] [ome.core.thing.internal.ThingManager] - Initializing handler for thing ‘zwave:device:8384dd0e:node40’ takes more than 5000ms.
2017-12-23 11:30:42.807 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘zwave:device:8384dd0e:node41’ to inbox.
2017-12-23 11:30:56.725 [WARN ] [class.ZWaveConfigurationCommandClass] - NODE 41: Parameter 2 response has 0 length
2017-12-23 11:30:56.772 [WARN ] [class.ZWaveConfigurationCommandClass] - NODE 41: Parameter 3 response has 0 length
2017-12-23 11:30:56.817 [WARN ] [class.ZWaveConfigurationCommandClass] - NODE 41: Parameter 2 response has 0 length
2017-12-23 11:30:56.858 [WARN ] [class.ZWaveConfigurationCommandClass] - NODE 41: Parameter 3 response has 0 length
2017-12-23 11:30:56.902 [WARN ] [class.ZWaveConfigurationCommandClass] - NODE 41: Parameter 2 response has 0 length
2017-12-23 11:30:56.944 [WARN ] [class.ZWaveConfigurationCommandClass] - NODE 41: Parameter 3 response has 0 length
2017-12-23 11:30:56.988 [WARN ] [class.ZWaveConfigurationCommandClass] - NODE 41: Parameter 2 response has 0 length
2017-12-23 11:30:57.030 [WARN ] [class.ZWaveConfigurationCommandClass] - NODE 41: Parameter 3 response has 0 length
2017-12-23 11:30:57.075 [WARN ] [class.ZWaveConfigurationCommandClass] - NODE 41: Parameter 2 response has 0 length
2017-12-23 11:30:57.115 [WARN ] [class.ZWaveConfigurationCommandClass] - NODE 41: Parameter 3 response has 0 length
2017-12-23 11:30:57.159 [WARN ] [class.ZWaveConfigurationCommandClass] - NODE 41: Parameter 2 response has 0 length
2017-12-23 11:30:57.202 [WARN ] [class.ZWaveConfigurationCommandClass] - NODE 41: Parameter 3 response has 0 length
[11:32:54] openhabian@openHABianPi:/srv/openhab2-userdata/zwave$ ls -latr /var/lib/openhab2/zwave/
total 296
-rw-rw-r-- 1 openhab openhabian 5135 Sep 5 18:22 node38.xml
-rw-rw-r-- 1 openhab openhabian 2020 Sep 16 20:47 node5.xml
-rw-rw-r-- 1 openhab openhabian 7044 Sep 19 20:38 node8.xml
drwxrwxr-x+ 17 openhab openhabian 4096 Dec 21 22:30 …
-rw-rw-r-- 1 openhab openhabian 1581 Dec 21 22:45 node1.xml
-rw-rw-r-- 1 openhab openhabian 10554 Dec 21 22:45 node4.xml
-rw-rw-r-- 1 openhab openhabian 4513 Dec 21 22:47 node12.xml
-rw-rw-r-- 1 openhab openhabian 7525 Dec 21 22:47 node35.xml
-rw-rw-r-- 1 openhab openhabian 7560 Dec 21 22:47 node11.xml
-rw-rw-r-- 1 openhab openhabian 7578 Dec 21 22:47 node10.xml
-rw-rw-r-- 1 openhab openhabian 7382 Dec 21 22:47 node37.xml
-rw-rw-r-- 1 openhab openhabian 10590 Dec 21 22:47 node2.xml
-rw-rw-r-- 1 openhab openhabian 5190 Dec 21 23:10 node14.xml
-rw-rw-r-- 1 openhab openhabian 5156 Dec 21 23:48 node22.xml
-rw-rw-r-- 1 openhab openhabian 5119 Dec 21 23:51 node16.xml
-rw-rw-r-- 1 openhab openhabian 5190 Dec 21 23:53 node17.xml
-rw-rw-r-- 1 openhab openhabian 5171 Dec 21 23:56 node20.xml
-rw-rw-r-- 1 openhab openhabian 6518 Dec 21 23:58 node39.xml
-rw-rw-r-- 1 openhab openhabian 5155 Dec 22 00:03 node23.xml
-rw-rw-r-- 1 openhab openhabian 7799 Dec 22 00:09 node28.xml
-rw-rw-r-- 1 openhab openhabian 7835 Dec 22 00:10 node31.xml
-rw-rw-r-- 1 openhab openhabian 5136 Dec 22 00:10 node33.xml
-rw-rw-r-- 1 openhab openhabian 5155 Dec 22 00:11 node21.xml
-rw-rw-r-- 1 openhab openhabian 5120 Dec 22 00:14 node36.xml
-rw-rw-r-- 1 openhab openhabian 5173 Dec 22 00:22 node15.xml
-rw-rw-r-- 1 openhab openhabian 5172 Dec 22 00:27 node3.xml
-rw-rw-r-- 1 openhab openhabian 7876 Dec 22 00:34 node29.xml
-rw-rw-r-- 1 openhab openhabian 5137 Dec 22 00:35 node18.xml
-rw-rw-r-- 1 openhab openhabian 7842 Dec 22 00:36 node32.xml
-rw-rw-r-- 1 openhab openhabian 7911 Dec 22 00:37 node30.xml
-rw-rw-r-- 1 openhab openhabian 5120 Dec 22 00:42 node34.xml
-rw-rw-r-- 1 openhab openhabian 5137 Dec 22 00:42 node24.xml
-rw-rw-r-- 1 openhab openhabian 6517 Dec 22 00:48 node19.xml
-rw-rw-r-- 1 openhab openhabian 5189 Dec 22 00:50 node7.xml
-rw-rw-r-- 1 openhab openhabian 6010 Dec 22 00:51 node6.xml
-rw-rw-r-- 1 openhab openhabian 6517 Dec 22 01:15 node9.xml
drwxrwxr-x+ 2 openhab openhabian 4096 Dec 23 11:30 .
-rw-rw-r-- 1 openhab openhab 5884 Dec 23 11:31 node41.xml
[11:33:58] openhabian@openHABianPi:/srv/openhab2-userdata/zwave$ vi /var/log/openhab2/openhab.log
[11:35:05] openhabian@openHABianPi:/srv/openhab2-userdata/zwave$ sudo find / -name ‘node4*.xml’
/srv/openhab2-userdata/zwave/node4.xml
/srv/openhab2-userdata/zwave/node41.xml
/var/lib/openhab2/zwave/node4.xml
/var/lib/openhab2/zwave/node41.xml
