Zwave - Yale YRD220 Lock
@chris,
Here is a bit more of the log during an unlock using the keypad, I think it might give you more information than just the JSON string.
2018-02-08 12:56:06.623 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = REDAC
2018-02-08 12:56:09.718 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=9, payload=REDAC
2018-02-08 12:56:09.721 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=SendData[19], type=Request[0], dest=0, callback=9, payload=REDAC
2018-02-08 12:56:09.722 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=9, payload=REDAC
2018-02-08 12:56:09.724 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 12461: [WAIT_REQUEST] requiresResponse=true callback: 9
2018-02-08 12:56:09.725 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2018-02-08 12:56:09.725 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 12461: [WAIT_REQUEST] requiresResponse=true callback: 9
2018-02-08 12:56:09.726 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 12461: (Callback 9)
2018-02-08 12:56:09.726 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = REDAC
2018-02-08 12:56:09.728 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2018-02-08 12:56:09.730 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 12461: callback 9
2018-02-08 12:56:09.733 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=9, payload=REDAC
2018-02-08 12:56:09.736 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 116: SendData Request. CallBack ID = 9, Status = Transmission complete and ACK received(0)
2018-02-08 12:56:09.737 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 116: resetResendCount initComplete=true isDead=false
2018-02-08 12:56:09.738 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 12461: Transaction COMPLETED
2018-02-08 12:56:09.739 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 12461: TransactionAdvance ST: DONE
2018-02-08 12:56:09.743 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 12461: TransactionAdvance WT: null {}
2018-02-08 12:56:09.745 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 12461: TransactionAdvance RX: Message: class=SendData[19], type=Request[0], dest=0, callback=9, payload=REDAC
2018-02-08 12:56:09.749 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 12461: TransactionAdvance TO: DONE
2018-02-08 12:56:09.750 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 116: Response processed after 3248ms
2018-02-08 12:56:09.752 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 116: TID 12461: Transaction completed
2018-02-08 12:56:09.753 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 116: notifyTransactionResponse TID:12461 DONE
2018-02-08 12:56:09.757 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2018-02-08 12:56:09.758 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 116: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-02-08 12:56:09.760 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=116, callback=0, payload=REDAC
2018-02-08 12:56:09.762 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[4], type=Request[0], dest=116, callback=0, payload=REDAC
2018-02-08 12:56:09.765 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = REDAC
2018-02-08 12:56:09.769 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=116, callback=0, payload=REDAC
2018-02-08 12:56:09.770 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-02-08 12:56:09.773 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 116: Application Command Request (ALIVE:DONE)
2018-02-08 12:56:09.774 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 116: resetResendCount initComplete=true isDead=false
2018-02-08 12:56:09.775 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 116: Decapsulating COMMAND_CLASS_SECURITY
2018-02-08 12:56:09.777 [DEBUG] [mmandclass.ZWaveSecurityCommandClass] - NODE 116: SECURITY_RXD REDAC
2018-02-08 12:56:09.778 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 116: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2018-02-08 12:56:09.779 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 116: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2018-02-08 12:56:09.780 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 116: NOTIFICATION report - 19 = 1, event=6, status=255, plen=4
2018-02-08 12:56:09.781 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 116: Alarm Type = ACCESS_CONTROL (19)
2018-02-08 12:56:09.781 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
2018-02-08 12:56:09.782 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 116: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2018-02-08 12:56:09.783 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 116: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_ALARM, value = 255
2018-02-08 12:56:09.785 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2018-02-08 12:56:09.786 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter NOTIFICATION event is 6, type OnOffType
2018-02-08 12:56:09.788 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter NOTIFICATION event is 6, channel alarm_access is not implemented.
2018-02-08 12:56:09.790 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2018-02-08 12:56:09.790 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=116, callback=0, payload=REDAC
2018-02-08 12:56:09.791 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter NOTIFICATION event is 6, type OnOffType
2018-02-08 12:56:09.792 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2018-02-08 12:56:09.793 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter NOTIFICATION event is 6, type StringType
2018-02-08 12:56:09.794 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[4], type=Request[0], dest=116, callback=0, payload=REDAC
2018-02-08 12:56:09.796 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 116: Updating channel state zwave:device:de0bde91:node116:alarm_raw to {"notification":"ACCESS_CONTROL__KEYPAD_UNLOCK","code":"99","type":"ACCESS_CONTROL","event":"6","status":"255"} [StringType]
2018-02-08 12:56:09.800 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2018-02-08 12:56:09.806 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter NOTIFICATION event is 6, type OnOffType
2018-02-08 12:56:09.807 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter NOTIFICATION event is 6, channel alarm_general is not implemented.
2018-02-08 12:56:09.808 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 116: Commands processed 1.
2018-02-08 12:56:09.809 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 116: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@e5905b.
2018-02-08 12:56:09.810 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2018-02-08 12:56:09.811 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2018-02-08 12:56:09.812 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=116, callback=0, payload=REDAC
2018-02-08 12:56:09.813 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-02-08 12:56:09.814 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 116: Application Command Request (ALIVE:DONE)
2018-02-08 12:56:09.815 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 116: resetResendCount initComplete=true isDead=false
2018-02-08 12:56:09.816 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 116: Decapsulating COMMAND_CLASS_SECURITY
2018-02-08 12:56:09.817 [DEBUG] [mmandclass.ZWaveSecurityCommandClass] - NODE 116: SECURITY_ERR No valid NONCE! null
2018-02-08 12:56:09.818 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-02-08 12:56:09.819 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
Just looking at the code here
+            case "alarm_raw":
 +                Map<String, Object> object = new HashMap<String, Object>();
 +                object.put("type", eventAlarm.getAlarmType());
 +                object.put("event", eventAlarm.getAlarmEvent());
 +                object.put("status", eventAlarm.getAlarmStatus());
 +                return new StringType(propertiesToJson(object));
Do you think it would be as easy as adding a line like:
object.put("level", eventAlarm.getAlarmLevel());
I’m fixated on the level because of the column in the Yale support document, see snippet here:
Untitled
