hey guys, im getting the following errors.i had a crack at this a couple of years ago and im still stumped now. ive got a Yale door lock and im guessing that Unknown Type in alarmRawParser means the codes that its sending to openhanded are different to what’s in the rule but im a little over my head tbh so any help would be awesome.
2020-06-21 23:20:38.474 [INFO ] [eclipse.smarthome.model.script.Rules] - Lock: Alarm events: FrontDoor_Test_DoorLock=[{"type":"24","value":"1"}]
2020-06-21 23:20:38.477 [INFO ] [eclipse.smarthome.model.script.Rules] - Lock: Alarm events: Unknown Type in alarmRawParser, {"type":"24","value":"1"}
2020-06-21 23:20:38.478 [INFO ] [eclipse.smarthome.model.script.Rules] - Lock: Alarm events: Unknown Type in alarmRawParser, {"type":"24","value":"1"}
2020-06-21 23:20:40.589 [INFO ] [eclipse.smarthome.model.script.Rules] - Lock: Alarm events: FrontDoor_Test_DoorLock=[{"type":"24","value":"1"}]
2020-06-21 23:20:40.591 [INFO ] [eclipse.smarthome.model.script.Rules] - Lock: Alarm events: Unknown Type in alarmRawParser, {"type":"24","value":"1"}
2020-06-21 23:20:41.400 [INFO ] [eclipse.smarthome.model.script.Rules] - Lock: Alarm events: FrontDoor_Test_DoorLock=[{"type":"25","value":"1"}]
2020-06-21 23:20:41.402 [INFO ] [eclipse.smarthome.model.script.Rules] - Lock: Alarm events: Unknown Type in alarmRawParser, {"type":"25","value":"1"}
2020-06-21 23:20:58.158 [INFO ] [eclipse.smarthome.model.script.Rules] - Lock: Alarm events: FrontDoor_Test_DoorLock=[{"type":"0","value":"0"}]
2020-06-21 23:20:58.160 [INFO ] [eclipse.smarthome.model.script.Rules] - Lock: Alarm events: Unknown Type in alarmRawParser, {"type":"0","value":"0"}
2020-06-21 23:21:00.221 [INFO ] [eclipse.smarthome.model.script.Rules] - Lock: Alarm events: FrontDoor_Test_DoorLock=[{"type":"24","value":"1"}]
2020-06-21 23:21:00.223 [INFO ] [eclipse.smarthome.model.script.Rules] - Lock: Alarm events: Unknown Type in alarmRawParser, {"type":"24","value":"1"}
2020-06-21 23:21:12.568 [INFO ] [eclipse.smarthome.model.script.Rules] - Lock: Alarm events: FrontDoor_Test_DoorLock=[{"type":"0","value":"0"}]
2020-06-21 23:21:12.571 [INFO ] [eclipse.smarthome.model.script.Rules] - Lock: Alarm events: Unknown Type in alarmRawParser, {"type":"0","value":"0"}
2020-06-21 23:21:13.218 [INFO ] [eclipse.smarthome.model.script.Rules] - Lock: Alarm events: FrontDoor_Test_DoorLock=[{"type":"24","value":"1"}]
2020-06-21 23:21:13.220 [INFO ] [eclipse.smarthome.model.script.Rules] - Lock: Alarm events: Unknown Type in alarmRawParser, {"type":"24","value":"1"}
here’s my item files
Group:Switch:OR(OFF,ON) gLock "Locks [MAP(lock.map):%s]"
Switch FrontDoor_Test_DoorLock "Lock (Front Door [MAP(lock.map):%s]" (gLock) {channel="zwave:device:b0b17ba4:node27:lock_door"}
String FrontDoor_Test_DoorLock_Alarm_Raw "Lock (Front Door): Alarm Raw [%s]" (gLock) {channel="zwave:device:b0b17ba4:node27:alarm_raw"}
and my rule file too
rule "Lock: Update lock states after alarm_raw event" when
Item FrontDoor_Test_DoorLock_Alarm_Raw received update then
val actionItem = gLock.members.findFirst[ item | item.name.toString == triggeringItem.name.toString.replace("_Alarm_Raw","") ]
logInfo("Rules", "Lock: Alarm events: {}=[{}]",actionItem.name,triggeringItem.state.toString)
switch (transform("JSONPATH","$.type",triggeringItem.state.toString)) {
case "ACCESS_CONTROL" : {
switch (transform("JSONPATH", "$.event", triggeringItem.state.toString)) {
case "1" : {
actionItem.postUpdate(ON)
logInfo("FrontDoor", "Lock: Alarm events: {} updated to Locked",actionItem.name)
val StringBuilder message = new StringBuilder("Locked via")
switch (transform("JSONPATH", "$.level", triggeringItem.state.toString)) {
case "1" : {
message.append(" Twist Knob")
case "2" : {
message.append(" Lock and Leave")
logInfo("FrontDoor", "Lock: {}",message.toString)
if(gPresenceSensors.state == OFF) {
sendBroadcastNotification(message.toString)
if(gPresenceSensors.state == ON) {
/*gAllEchoAlerts.sendCommand(message.toString)*/
UserCode.postUpdate(message.toString)
case "2" : {
actionItem.postUpdate(OFF)
val StringBuilder message = new StringBuilder("Unlocked via TwistKnob")
logInfo("FrontDoor", "Unlock: {}",message.toString)
case "3" : {
val StringBuilder message = new StringBuilder("Locked via UI")
case "4" : {
val StringBuilder message = new StringBuilder("Unlocked via UI")
case "5" : {
val StringBuilder message = new StringBuilder("Locked with ")
case "1" : {
message.append(" Jodies Code")
case "2" : {
message.append(" Kris Code")
case "3" : {
message.append(" user code 3")
case "4" : {
message.append(" user code 4")
case "5" : {
message.append(" user code 5")
case "6" : {
val StringBuilder message = new StringBuilder("Unlocked with")
case "1" : {
case "2" : {
case "3" : {
case "4" : {
case "5" : {
case "251" : {
message.append(" Master code")
logInfo("Rules", "Unlock: {}",message.toString)
case "11" : {
logInfo("Rules", "Lock: Alarm events: {} is jammed, so setting lock to OFF (unlocked)",actionItem.label)
sendBroadcastNotification(actionItem.label + " is jammed")
case "13" : {
val String message = "Front Door Usercode has been deleted"
logInfo("Rules", "Door Lock: User Code: {}",message)
case "14" : {
val String message = "Front Door Usercode has been added"
case "16" : {
val String message = actionItem.label + " keypad is disabled due to too many failed codes"
logInfo("Rules", "Lock: Alarm events: {}",message)
default : {
val String message = "Unknown door lock Event, " + triggeringItem.state.toString
sendBroadcastNotification(message)
if (transform("JSONPATH", "$.event", triggeringItem.previousState(true, "influxdb").state.toString) == "11" && transform("JSONPATH", "$.event", triggeringItem.state.toString)
!= "11") {
val String message = actionItem.label + " is no longer jammed"
case "BURGLAR" : {
FrontDoorLock_Tamper.sendCommand(ON)
val String message = "Intruder at " + actionItem.name
logInfo("Tamper Alert", "Lock: Alarm events: {}",message)
case "POWER_MANAGEMENT" : {
val String message = "Power Management alarm for " + actionItem.label + ", " + triggeringItem.state.toString
//SMS_Notification.sendCommand(message)
default : {
val String message = "Unknown Type in alarmRawParser, " + triggeringItem.state.toString
