- Platform information:
- Hardware: Raspberry Pi 3 Model B Rev 1.2
- OS: Raspbian GNU/Linux 9 (stretch)
- Java Runtime Environment: _from openhabian image installation
- openHAB version: openHAB 2.5.0~M3-1 (Milestone Build)
- Issue of the topic: Zipato WTRFID not working as documented in the user manual
Let me refer to https://github.com/openhab/org.openhab.binding.zwave/blob/master/doc/wintop/wtrfid_0_0.md#alarm-access
The Channels documentation states that: "The notification_access_control
channel supports the Number
item. This is a read only channel so will only be updated following state changes from the device.
Event ID 5 = Away
Event ID 6 = Home
For the Alarm (access) channel)
this channel shows only decimal values of 0 and 255.
Additionally this table is making things less clear
The following state translation is provided for this channel to the Number item type -:
Value Label
0 Previous Events cleared
1 Manual Lock Operation
2 Manual Unlock Operation
3 RF Lock Operation
4 RF Unlock Operation
5 Keypad Lock Operation
6 Keypad Unlock Operation
7 Manual Not Fully Locked Operation
8 RF Not Fully Locked Operation
9 Auto Lock Locked Operation
10 Auto Lock Not Fully Operation
11 LockJammed
12 All user codes deleted
13 Single user code deleted
14 New user code added
15 New user code not added due to duplicate code
16 Keypad temporary disabled
17 Keypad busy
18 New Program code Entered- Unique code for lock configuration
19 Manually Enter user Access code exceeds code limit
20 Unlock by RF with invalid user code
21 Locked by RF with invalid user code
22 Window/Door is open
23 Window/Door is closed
64 Barrier performing initialization process
65 Barrier operation (Open / Close) force has been exceeded
66 Barrier motor has exceeded manufacturer's operational time limit
67 Barrier operation has exceeded physical mechanical limits
68 Barrier unable to perform requested operation due to UL requirements
69 Barrier Unattended operation has been disabled per UL requirements
70 Barrier failed to perform Requested operation, device malfunction
71 Barrier Vacation Mode
72 Barrier Safety Beam Obstacle
73 Barrier Sensor Not Detected / Supervisory Error
74 Barrier Sensor Low Battery Warning
75 Barrier detected short in WallStation wires
76 Barrier associated with non-Z-wave remote control
Because 0 should be interpreted as “Previous Events cleared”
I have read a comment from @Cris in https://github.com/openhab/org.openhab.binding.zwave/issues/1145 saying “Alarms should never use values like 5 and 6 - they should normally be On and Off (ie binary)”, and I agree with that.
What I’m trying to do?
As the device has the COMMAND_CLASS_USER_CODE_V1 I think it would be possible to trace who is activating or deactivating the alarm device.
When you use a user code configured in the device using habmin, you can see this in the logs
2019-09-19 19:38:58.064 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 12 00 04 00 02 0A 71 05 00 00 00 FF 06 06 01 04 C1 00 AE
2019-09-19 19:38:58.070 [vent.ItemStateChangedEvent] - zwave_serial_zstick_controller_serial_sof changed from 1859 to 1860
2019-09-19 19:38:58.075 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 0A 71 05 00 00 00 FF 06 06 01 04 C1 00
2019-09-19 19:38:58.079 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 0A 71 05 00 00 00 FF 06 06 01 04 C1 00
2019-09-19 19:38:58.081 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-09-19 19:38:58.082 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Application Command Request (ALIVE:DONE)
2019-09-19 19:38:58.084 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
2019-09-19 19:38:58.085 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 04 02 02 84 07 CF 00 B9
2019-09-19 19:38:58.086 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2019-09-19 19:38:58.087 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY not supported
2019-09-19 19:38:58.089 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Received COMMAND_CLASS_ALARM V2 NOTIFICATION_REPORT
2019-09-19 19:38:58.090 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=4, payload=04 02 02 84 07 CF 00
2019-09-19 19:38:58.091 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 2: ALARM report - 0 = 0
2019-09-19 19:38:58.093 [vent.ItemStateChangedEvent] - zwave_serial_zstick_controller_serial_sof changed from 1860 to 1861
2019-09-19 19:38:58.095 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 2: Alarm Type = ACCESS_CONTROL (0)
2019-09-19 19:38:58.097 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2019-09-19 19:38:58.098 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=0
2019-09-19 19:38:58.102 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 2: Alarm converter processing ALARM
2019-09-19 19:38:58.103 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 2: Alarm converter processing ALARM
2019-09-19 19:38:58.105 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - **NODE 2: Updating channel state zwave:device:controller:node2:notification_access_control to 0 [DecimalType]**
2019-09-19 19:38:58.109 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Commands processed 1.
2019-09-19 19:38:58.110 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@c3d7a9.
2019-09-19 19:38:58.113 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-09-19 19:38:58.112 [vent.ItemStateChangedEvent] - KeyPadAccess changed from 255 to 0
2019-09-19 19:38:58.114 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-09-19 19:38:58.117 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=4, payload=04 02 02 84 07 CF 00
2019-09-19 19:38:58.118 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-09-19 19:38:58.120 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Application Command Request (ALIVE:DONE)
2019-09-19 19:38:58.122 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
2019-09-19 19:38:58.123 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Is awake with 0 messages in the queue
2019-09-19 19:38:58.125 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Start sleep timer at 1000ms
2019-09-19 19:38:58.127 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2019-09-19 19:38:58.143 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:controller:node2' has been updated.
2019-09-19 19:38:58.143 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 2: Node Status event - Node is AWAKE
2019-09-19 19:38:58.144 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Commands processed 1.
2019-09-19 19:38:58.146 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@69e4bb.
2019-09-19 19:38:58.148 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-09-19 19:38:58.149 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-09-19 19:38:58.151 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-09-19 19:38:58.152 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-09-19 19:38:58.626 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: WakeupTimerTask 0 Messages waiting, state DONE
2019-09-19 19:38:59.127 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: WakeupTimerTask 0 Messages waiting, state DONE
2019-09-19 19:38:59.128 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: No more messages, go back to sleep
2019-09-19 19:38:59.130 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 2: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2019-09-19 19:38:59.131 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY not supported
2019-09-19 19:38:59.133 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2019-09-19 19:38:59.135 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@c6a51
2019-09-19 19:38:59.139 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Bump transaction 634 priority from Immediate to Immediate
2019-09-19 19:38:59.142 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Adding to device queue
2019-09-19 19:38:59.144 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Added 634 to queue - size 1
2019-09-19 19:38:59.146 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-09-19 19:38:59.149 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 02 02 84 08 25 8A C6
2019-09-19 19:38:59.152 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 2: Sending REQUEST Message = 01 09 00 13 02 02 84 08 25 8A C6
2019-09-19 19:38:59.156 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2019-09-19 19:38:59.158 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-09-19 19:38:59.154 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2019-09-19 19:38:59.160 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-09-19 19:38:59.161 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 634: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 138
2019-09-19 19:38:59.162 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-09-19 19:38:59.163 [vent.ItemStateChangedEvent] - zwave_serial_zstick_controller_serial_ack changed from 911 to 912
2019-09-19 19:38:59.163 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2019-09-19 19:38:59.164 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2019-09-19 19:38:59.166 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-09-19 19:38:59.166 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-09-19 19:38:59.168 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-09-19 19:38:59.170 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-09-19 19:38:59.171 [vent.ItemStateChangedEvent] - zwave_serial_zstick_controller_serial_sof changed from 1861 to 1862
2019-09-19 19:38:59.172 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 634: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 138
2019-09-19 19:38:59.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-09-19 19:38:59.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 634: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 138
2019-09-19 19:38:59.177 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-09-19 19:38:59.179 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: sentData successfully placed on stack.
2019-09-19 19:38:59.180 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 634: Advanced to WAIT_REQUEST
2019-09-19 19:38:59.182 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: TID 634: Transaction not completed
2019-09-19 19:38:59.183 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-09-19 19:38:59.185 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-09-19 19:38:59.186 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 8A 00 00 02 00 BC 7F 7F 7F 7F 00 01 03 00 00 00 00 02 01 00 00 C1
2019-09-19 19:38:59.191 [vent.ItemStateChangedEvent] - zwave_serial_zstick_controller_serial_sof changed from 1862 to 1863
2019-09-19 19:38:59.194 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=138, payload=8A 00 00 02 00 BC 7F 7F 7F 7F 00 01 03 00 00 00 00 02 01 00 00
2019-09-19 19:38:59.200 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=138, payload=8A 00 00 02 00 BC 7F 7F 7F 7F 00 01 03 00 00 00 00 02 01 00 00
2019-09-19 19:38:59.202 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 634: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 138
2019-09-19 19:38:59.205 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-09-19 19:38:59.208 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 634: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 138
2019-09-19 19:38:59.210 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 634: (Callback 138)
2019-09-19 19:38:59.213 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2019-09-19 19:38:59.215 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 634: callback 138
2019-09-19 19:38:59.219 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=138, payload=8A 00 00 02 00 BC 7F 7F 7F 7F 00 01 03 00 00 00 00 02 01 00 00
2019-09-19 19:38:59.221 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: SendData Request. CallBack ID = 138, Status = Transmission complete and ACK received(0)
2019-09-19 19:38:59.223 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
2019-09-19 19:38:59.225 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 634: Transaction COMPLETED
2019-09-19 19:38:59.227 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Response processed after 67ms
2019-09-19 19:38:59.229 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: TID 634: Transaction completed
2019-09-19 19:38:59.231 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: notifyTransactionResponse TID:634 DONE
2019-09-19 19:38:59.233 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2019-09-19 19:38:59.235 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-09-19 19:38:59.238 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-09-19 19:38:59.237 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 634: Transaction event listener: DONE: DONE ->
2019-09-19 19:38:59.241 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Went to sleep COMPLETE
It is updating the notification_user_control channel state with the decimal value 0 corresponding to a “Home -> registered user code ->Enter” key secuence.
For the “Away->registered user code->Enter” key secuence, the notification_user_control channel state gets a 255.
Now in the case you key “Away->“1111” wich is an unregistered user code->Enter”, the logs shows this:
2019-09-19 19:41:34.432 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 16 00 04 00 02 0E 63 03 00 00 31 31 31 31 00 00 00 00 00 00 BB 00 3A
2019-09-19 19:41:34.433 [vent.ItemStateChangedEvent] - zwave_serial_zstick_controller_serial_sof changed from 1863 to 1864
2019-09-19 19:41:34.440 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 0E 63 03 00 00 31 31 31 31 00 00 00 00 00 00 BB 00
2019-09-19 19:41:34.443 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 0E 63 03 00 00 31 31 31 31 00 00 00 00 00 00 BB 00
2019-09-19 19:41:34.445 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-09-19 19:41:34.446 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Application Command Request (ALIVE:DONE)
2019-09-19 19:41:34.448 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
2019-09-19 19:41:34.450 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Incoming command class COMMAND_CLASS_USER_CODE, endpoint 0
2019-09-19 19:41:34.452 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 04 02 02 84 07 CA 00 BC
2019-09-19 19:41:34.452 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY not supported
2019-09-19 19:41:34.454 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Received COMMAND_CLASS_USER_CODE V1 USER_CODE_REPORT
2019-09-19 19:41:34.456 [vent.ItemStateChangedEvent] - zwave_serial_zstick_controller_serial_sof changed from 1864 to 1865
2019-09-19 19:41:34.457 [DEBUG] [mmandclass.ZWaveUserCodeCommandClass] - NODE 2: USER_CODE_REPORT 0 is AVAILABLE
2019-09-19 19:41:34.457 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=4, payload=04 02 02 84 07 CA 00
2019-09-19 19:41:34.460 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveUserCodeValueEvent
2019-09-19 19:41:34.462 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_USER_CODE, value=31 31 31 31 00 00 00 00 00 00
2019-09-19 19:41:34.466 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Config updated
2019-09-19 19:41:34.483 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Commands processed 1.
2019-09-19 19:41:34.485 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@19d60f8.
2019-09-19 19:41:34.485 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:controller:node2' has been updated.
2019-09-19 19:41:34.486 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-09-19 19:41:34.486 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[]]
2019-09-19 19:41:34.488 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-09-19 19:41:34.491 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=4, payload=04 02 02 84 07 CA 00
2019-09-19 19:41:34.493 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-09-19 19:41:34.495 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Application Command Request (ALIVE:DONE)
2019-09-19 19:41:34.497 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
2019-09-19 19:41:34.500 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Is awake with 0 messages in the queue
2019-09-19 19:41:34.501 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Start sleep timer at 1000ms
2019-09-19 19:41:34.503 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2019-09-19 19:41:34.512 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 2: Node Status event - Node is AWAKE
2019-09-19 19:41:34.513 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Commands processed 1.
2019-09-19 19:41:34.513 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1c38c7d.
2019-09-19 19:41:34.513 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:controller:node2' has been updated.
2019-09-19 19:41:34.514 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-09-19 19:41:34.516 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-09-19 19:41:34.517 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-09-19 19:41:34.518 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-09-19 19:41:35.003 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: WakeupTimerTask 0 Messages waiting, state DONE
2019-09-19 19:41:35.503 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: WakeupTimerTask 0 Messages waiting, state DONE
2019-09-19 19:41:35.504 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: No more messages, go back to sleep
2019-09-19 19:41:35.506 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 2: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2019-09-19 19:41:35.507 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY not supported
2019-09-19 19:41:35.509 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2019-09-19 19:41:35.510 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@e09825
2019-09-19 19:41:35.514 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Bump transaction 635 priority from Immediate to Immediate
2019-09-19 19:41:35.516 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Adding to device queue
2019-09-19 19:41:35.518 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Added 635 to queue - size 1
2019-09-19 19:41:35.520 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-09-19 19:41:35.523 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 02 02 84 08 25 8B C7
2019-09-19 19:41:35.526 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 2: Sending REQUEST Message = 01 09 00 13 02 02 84 08 25 8B C7
2019-09-19 19:41:35.528 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2019-09-19 19:41:35.530 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 635: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 139
2019-09-19 19:41:35.531 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2019-09-19 19:41:35.533 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-09-19 19:41:35.535 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-09-19 19:41:35.535 [vent.ItemStateChangedEvent] - zwave_serial_zstick_controller_serial_ack changed from 912 to 913
2019-09-19 19:41:35.537 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 635: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 139
2019-09-19 19:41:35.539 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2019-09-19 19:41:35.542 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-09-19 19:41:35.544 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-09-19 19:41:35.545 [vent.ItemStateChangedEvent] - zwave_serial_zstick_controller_serial_sof changed from 1865 to 1866
2019-09-19 19:41:35.546 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2019-09-19 19:41:35.549 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-09-19 19:41:35.551 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-09-19 19:41:35.553 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 635: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 139
2019-09-19 19:41:35.555 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-09-19 19:41:35.557 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 635: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 139
2019-09-19 19:41:35.559 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 8B 00 00 02 00 B3 7F 7F 7F 7F 00 01 03 00 00 00 00 02 01 00 00 CF
2019-09-19 19:41:35.559 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-09-19 19:41:35.561 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: sentData successfully placed on stack.
2019-09-19 19:41:35.562 [vent.ItemStateChangedEvent] - zwave_serial_zstick_controller_serial_sof changed from 1866 to 1867
2019-09-19 19:41:35.564 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 635: Advanced to WAIT_REQUEST
2019-09-19 19:41:35.566 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: TID 635: Transaction not completed
2019-09-19 19:41:35.568 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-09-19 19:41:35.570 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=139, payload=8B 00 00 02 00 B3 7F 7F 7F 7F 00 01 03 00 00 00 00 02 01 00 00
2019-09-19 19:41:35.570 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-09-19 19:41:35.574 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=139, payload=8B 00 00 02 00 B3 7F 7F 7F 7F 00 01 03 00 00 00 00 02 01 00 00
2019-09-19 19:41:35.575 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 635: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 139
2019-09-19 19:41:35.577 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-09-19 19:41:35.579 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 635: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 139
2019-09-19 19:41:35.580 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 635: (Callback 139)
2019-09-19 19:41:35.582 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2019-09-19 19:41:35.584 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 635: callback 139
2019-09-19 19:41:35.587 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=139, payload=8B 00 00 02 00 B3 7F 7F 7F 7F 00 01 03 00 00 00 00 02 01 00 00
2019-09-19 19:41:35.589 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: SendData Request. CallBack ID = 139, Status = Transmission complete and ACK received(0)
2019-09-19 19:41:35.591 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
2019-09-19 19:41:35.593 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 635: Transaction COMPLETED
2019-09-19 19:41:35.594 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Response processed after 65ms
2019-09-19 19:41:35.596 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: TID 635: Transaction completed
2019-09-19 19:41:35.598 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: notifyTransactionResponse TID:635 DONE
2019-09-19 19:41:35.613 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2019-09-19 19:41:35.615 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-09-19 19:41:35.614 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 635: Transaction event listener: DONE: DONE ->
2019-09-19 19:41:35.616 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-09-19 19:41:35.618 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Went to sleep COMPLETE
The first received message shows the sequence “31 31 31 31 00 00 00 00 00 00” which contains the code keyed in by the user.
The Command Class user code has no channel associated, so is unaccesible from rules.
I try but didn’t find how to create a new channel to acces the code from a rule.
How can it be done?
Thanks.
