Hi @chris,
sorry to direct this right to you, but you’ve been extremely helpful in the past, and you’re the real savvy one here. I’m desperate, I have a long standing story of trying to get the OH2 zwave binding to fully work for my housing setup.
But I have a couple of battery zwave devices that just keep failing to initialize or, to be more precise, to get properly identified by the binding.
Thing is, they work fine with the OH1 legacy binding. There’s OH1 binding generated XML files for all of them.
I do find all of the bad devices in your device database, too.
For most of them, I do have identical devices that DO work. It’s all ‘standard’ multi sensors like Fibaro and Aeon gen 6 devices, the probably most uncommon ones are two Philio PST multi sensors. The only commonality seems to be it’s all battery multi sensors.
Running any of the OH2 bindings (2.1 release, latest snapshot or latest refactored), these devices fail to initialize.
Habmin and PaperUI keep telling me the type of node is unknown (FWIW, I’m running OH2.2 snapshot #1020 at the moment).
I’ve made various attempts at deleting things, rediscover them, reinitialize by clicking the buttons on them, wait, repeat, etc., re-include them, moved them close to the controller. I do see their zwave messages when I single- or triple-click.
I’ve purged/reinstalled OH multiple times and even tried copying (and properly edited) XML files from working siblings before restarting, but they all still fail to initialize. The binding still feels they’re unknown type node.
EDIT: I just noticed that the bad nodes are ALL tagged to be of thingTypeUID “qubino_zmnhda_00_000” in jsondb.
Might be coincidence because that type is the first or last in a list somewhere in the code and as such used as the default if the device cannot be identified.
For a bad node in question like 122, I have NOT seen any log entry saying ‘NODE 122: Device discovery resolved to thingType XXXX’ while for all working nodes that I’ve checked, I did find such a log line.
Some more oddities:
on OH2 (snapshot) binding start, there’s some error messages saying the (legacy binding generated) XML files cannot be (fully) parsed, but I think this is mostly unrelated because some of those incriminated nodes (such as the 42 and 19 shown below, which are Fibaro FGMS and FGD devices) still do work, and there’s affected nodes without XML files generated under the new binding (such as 122, a Fibaro FGSD-002).
Then again, that might be a pointer or not. 122 is a smoke detector device that I used to include, exclude, include multiple times, resulting in different nodeIDs, too. Same is true for various other (but not all) of the affected nodes.
I remember the 122 smoke detector even used to have a higher ID at some earlier point in time. That’s about the only occasion that I have seen my controller assign a lower number to a new device.
And 122 is a smoke detector that should not have a GARAGE_DOOR zwave class type, should it ?
2017-08-24 10:24:39.628 [ERROR] [ve.internal.protocol.ZWaveController] - NODE 42: Restore from config: Error deserialising XML file. com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter$UnknownFieldException: No such field org.openhab.binding.zwave.internal.protocol.ZWaveNode.deviceClass
---- Debugging information ----
field : deviceClass
class : org.openhab.binding.zwave.internal.protocol.ZWaveNode
required-type : org.openhab.binding.zwave.internal.protocol.ZWaveNode
converter-type : com.thoughtworks.xstream.converters.reflection.ReflectionConverter
path : /node/deviceClass
line number : 2
version : 1.4.7
2017-08-24 10:27:38.682 [ERROR] [ve.internal.protocol.ZWaveController] - NODE 19: Restore from config: Error deserialising XML file. com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter$UnknownFieldException: No s
uch field org.openhab.binding.zwave.internal.protocol.ZWaveNode.healState
2017-08-24 10:27:38.948 [ERROR] [ve.internal.protocol.ZWaveController] - NODE 122: Restore from config: Error deserialising XML file. com.thoughtworks.xstream.converters.ConversionException: No enum constant org.openhab.binding.zwave.i
nternal.protocol.ZWaveDeviceClass.Generic.GARAGE_DOOR : No enum constant org.openhab.binding.zwave.internal.protocol.ZWaveDeviceClass.Generic.GARAGE_DOOR
I do not see anything wrong about the initialization process, here’s the (grep’ed-out) messages for that node 122 if run under the refactored binding.
I’m probably missing some important messages, but there’s so many of them when the binding starts initializing all nodes…
2017-08-24 10:20:29.343 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 122: Serialise aborted as static stages not complete
2017-08-24 10:24:35.838 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 122: Node found
2017-08-24 10:24:37.015 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 122: Init node thread start
2017-08-24 10:24:39.254 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 122: Serializing from file /var/lib/openhab2/zwave/network_c602b032__node_122.xml
2017-08-24 10:24:39.348 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 122: Error serializing from file: file does not exist.
2017-08-24 10:24:40.263 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 122: Starting initialisation from EMPTYNODE
2017-08-24 10:24:41.407 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 122: Init node thread finished
2017-08-24 10:24:41.413 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 122: Node advancer - advancing to IDENTIFY_NODE
2017-08-24 10:24:41.814 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 122: Node advancer: Initialisation starting
2017-08-24 10:25:09.313 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Controller status changed to ONLINE.
2017-08-24 10:25:09.315 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Controller is ONLINE. Starting device initialisation.
2017-08-24 10:25:09.323 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Updating node properties.
2017-08-24 10:25:09.326 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Updating node properties. MAN=2147483647
2017-08-24 10:25:09.330 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Properties synchronised
2017-08-24 10:25:09.338 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Initialising Thing Node...
2017-08-24 10:25:09.340 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Initialising cmd channel zwave:device:ddd23e6c:node122:switch_binary for OnOffType
2017-08-24 10:25:09.341 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Initialising state channel zwave:device:ddd23e6c:node122:switch_binary for OnOffType
2017-08-24 10:25:09.344 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Initialising cmd channel zwave:device:ddd23e6c:node122:switch_dimmer for OnOffType
2017-08-24 10:25:09.346 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Initialising cmd channel zwave:device:ddd23e6c:node122:switch_dimmer for PercentType
2017-08-24 10:25:09.347 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Initialising state channel zwave:device:ddd23e6c:node122:switch_dimmer for PercentType
2017-08-24 10:25:09.351 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Initialising cmd channel zwave:device:ddd23e6c:node122:sensor_temperature for DecimalType
2017-08-24 10:25:09.352 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Initialising state channel zwave:device:ddd23e6c:node122:sensor_temperature for DecimalType
2017-08-24 10:25:09.361 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Initialising cmd channel zwave:device:ddd23e6c:node122:meter_kwh for DecimalType
2017-08-24 10:25:09.363 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Initialising state channel zwave:device:ddd23e6c:node122:meter_kwh for DecimalType
2017-08-24 10:25:09.365 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Initialising cmd channel zwave:device:ddd23e6c:node122:meter_watts for DecimalType
2017-08-24 10:25:09.366 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Initialising state channel zwave:device:ddd23e6c:node122:meter_watts for DecimalType
2017-08-24 10:25:09.368 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Initialising cmd channel zwave:device:ddd23e6c:node122:sensor_binary1 for OnOffType
2017-08-24 10:25:09.370 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Initialising state channel zwave:device:ddd23e6c:node122:sensor_binary1 for OnOffType
2017-08-24 10:25:09.371 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Initialising state channel zwave:device:ddd23e6c:node122:sensor_binary1 for OnOffType
2017-08-24 10:25:09.386 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Initialising cmd channel zwave:device:ddd23e6c:node122:sensor_binary2 for OnOffType
2017-08-24 10:25:09.388 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Initialising state channel zwave:device:ddd23e6c:node122:sensor_binary2 for OnOffType
2017-08-24 10:25:09.405 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Initialising state channel zwave:device:ddd23e6c:node122:sensor_binary2 for OnOffType
2017-08-24 10:25:09.406 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Polling intialised at 1800 seconds - start in 1800000 milliseconds.
2017-08-24 10:25:09.409 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 122: Device initialisation complete.
In short, I’m stuck. Please get me a hint what to try or watch for. I really don’t know how to approach the problem.
For a start, I feel that one of the most annoying parts of the problem is that there’s no “Re-initialize” button available in habmin as long as the node is of unknown type.
Please could you change that ? I don’t know a means to trigger initial initialization (or identification, actually) other than to fully restart OH. Yes, of course I will still need to press the button(s), but at least that would speed up the process A LOT.
Any other idea or procedure to point me in the right direction is highly appreciated, too.
I really want to nail this thing down this time.
thanks in advance
Markus
PS: why I’m so frustrated:
It’s extremely stressful and time consuming for me to switch forth and back to see if a particular change makes a difference as this is my production config (the house I live in :)). I have a slow Raspi server, restarting OH often does not work (hangs, some Karaf or OH2 module dependency problems, not sure), lots of rules to process, and every switch results in a backlog of zwave messages whenever the zwave binding restarts to take half an hour to process. I’ve done that lots of times, and I’m fed up with it.
Then again, it’s extremely annoying, too, to keep running the house on OH2 with zwave1, as there is no working habmin, so I have to restart all of OH to temporarily use habmin2 (and zwave2 binding) whenever I need to change any of my zwave device’s configs (partial restarts, i.e. binding exchange only as per Karaf console, never seem to work, always results in some hanging state).
