I use the ZXT-120 to send IR Commands to a fan. Its connected to A Raspberry Pi 3B+ with Openhabian through the Zwave Binding. I send the commands to an Item linked to the setpoint(heating) channel of the ZXT-120. Everytime I send a command I get this error in the log
2019-01-13 10:18:50.943 [ERROR] [lass.ZWaveThermostatModeCommandClass] - NODE 2: Unsupported mode type 26
2019-01-13 10:18:50.948 [WARN ] [nverter.ZWaveThermostatModeConverter] - NODE 2: Generating message failed for command class = COMMAND_CLASS_THERMOSTAT_MODE, endpoint = 0
The ZXT executes the command anyway and the IR command gets send without a problem. Im just wondering if I should change something or just ignore the error in the log.
Best regards Johannes
