just migrated my items with OH2 from the 1.9 zwave binding to 2.0 snapshot from yesterday.
Everything works great but my two binary switches “054375 Schuko Plug Switch” don’t work with the 2.0 zwave binding and produce the following error:
2016-12-20 14:38:20.620 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Command received zwave:device:9522d65e:node10:switch_binary --> ON
2016-12-20 14:38:20.622 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Command for unknown channel zwave:device:9522d65e:node10:switch_binary with OnOffType
2016-12-20 14:38:24.478 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Command received zwave:device:9522d65e:node10:switch_binary --> OFF
2016-12-20 14:38:24.481 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Command for unknown channel zwave:device:9522d65e:node10:switch_binary with OnOffType
The Thing is configured as follows:
zwave:device:9522d65e:node10 (Type=Thing, Status=ONLINE, Label=Z-Wave Node 10: 054375 Schuko Plug Switch, Bridge=zwave:serial_zstick:9522d65e)
And here is the link to the item:
GlobeLamp -> zwave:device:9522d65e:node10:switch_binary
Maybe the configuration in the database is wrong?
Thank you very much in advance an best regards,
Jens
