I’m trying to use new onewire binding based on OWFS.
Unfortunately, I get errors in log and my OW Server has status: OFFLINE - COMMUNICATION_ERROR
I get this entries all the time:
2019-04-05 23:16:54.872 [hingStatusInfoChangedEvent] - ‘onewire:owserver:27dbecfc’ changed from OFFLINE (COMMUNICATION_ERROR) to ONLINE
2019-04-05 23:16:54.891 [hingStatusInfoChangedEvent] - ‘onewire:owserver:27dbecfc’ changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
What have I done so far:
using raspi-config I’ve enabled 1-Wire and I2C
using openhabian-config I’ve installed owserver.
This is content of my /etc/owfs.conf:
I have two DS18B20 connected to GND, 3.3V and GPIO4 (I’ve added 4,7k resisor between 3.3V and GPIO4)
And this is how my Thing config looks like:
I’m not sure what lines I should change in owfs.conf.
I’m not using any USB device for 1-Wire devices, but as I understand correctly I can use Raspberry PI .
@J-N-K sorry for another silly question, but how to do that?
I don’t want to use USB device ot another server. I have DS18B20 connected directly to Raspberry PI 3B.
That’s what I thought
Openhabian-config tool is quite confusing. There should be an option to install/configure raspberry to support 1wire via gpio (without installs owfs) and another for owfs.
I’d like to ask also for clarification in docs, because now it is confusing. I thought I should use newest binding, but I lost two evenings because I picked the wrong binding
From my understanding by default OWFS expose two fake devices:
server: FAKE = DS18S20,DS2405
in my case, the problem is the communication between owserver and openHAB.
As I wrote I’m using openHAB 2.4.
With fake server I don’t need real devices, so I should be able to check everything.
