Platform information:
Hardware: Intel(R) Xeon(R) CPU E3-1265L V2 @ 2.50GHz
OS: Debian GNU/Linux 8 \n \l
Java Runtime Environment: : Oracle java version "1.8.0_131"
openHAB version:2.2.0, dev versions of zwave, exec
Issue of the topic: Multiple errors in logs after upgrade regarding cannot create folder AND BundleException
Hi List -
Upgraded my OH 2.1.0 installation using the upgrade script which complete successfully:
openHAB 2.x.x update script
Making Temporary Directory
Downloading openHAB 2.2.0...
######################################################################## 100.0%
Update script in .zip archive found, using that instead.
The script will attempt to update openHAB to version 2.2.0
Is this okay? [y/N]: y
Removing openHAB System Files...
mv: cannot stat ‘/opt/openhab2-nov/userdata/etc/custom.system.properties’: No such file or directory
Clearing cache...
Updating openHAB...
Deleting temporary files...
Restoring previous file ownership (openhab:openhab)
SUCCESS: openHAB updated from 2.1.0 to 2.2.0
But on startup I see errors in openhab.log. First are “Cannot create folder”:
2018-03-10 15:05:46.290 [ERROR] [org.apache.felix.fileinstall ] - Cannot create folder /opt/openhab2-nov/userdata/tmp/bundles. Is the folder write-protected?
2018-03-10 15:05:46.296 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedServiceFactory, id=37, bundle=8/mvn:org.apache.felix/org.apache.felix.fileinstall/3.5.8]: Unexpected problem updating configuration org.
apache.felix.fileinstall.dda8da99-17d6-4e6d-8eb9-1a432e6fac83
java.lang.RuntimeException: Cannot create folder: /opt/openhab2-nov/userdata/tmp/bundles
at org.apache.felix.fileinstall.internal.DirectoryWatcher.prepareDir(DirectoryWatcher.java:638) [8:org.apache.felix.fileinstall:3.5.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.prepareTempDir(DirectoryWatcher.java:618) [8:org.apache.felix.fileinstall:3.5.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.<init>(DirectoryWatcher.java:175) [8:org.apache.felix.fileinstall:3.5.8]
at org.apache.felix.fileinstall.internal.FileInstall.updated(FileInstall.java:247) [8:org.apache.felix.fileinstall:3.5.8]
at org.apache.felix.fileinstall.internal.FileInstall$ConfigAdminSupport$Tracker.updated(FileInstall.java:377) [8:org.apache.felix.fileinstall:3.5.8]
at org.apache.felix.cm.impl.helper.ManagedServiceFactoryTracker.updated(ManagedServiceFactoryTracker.java:159) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.helper.ManagedServiceFactoryTracker.provideConfiguration(ManagedServiceFactoryTracker.java:93) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceFactoryUpdate.provide(ConfigurationManager.java:1640) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceFactoryUpdate.run(ConfigurationManager.java:1582) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109) [7:org.apache.felix.configadmin:1.8.16]
2018-03-10 15:05:46.301 [ERROR] [org.apache.felix.fileinstall ] - Cannot create folder /opt/openhab2-2_2_0/userdata/tmp/bundles. Is the folder write-protected?
2018-03-10 15:05:46.301 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedServiceFactory, id=37, bundle=8/mvn:org.apache.felix/org.apache.felix.fileinstall/3.5.8]: Unexpected problem updating configuration org.
apache.felix.fileinstall.4b2bcac8-1d7c-4260-990e-c981b844996d
java.lang.RuntimeException: Cannot create folder: /opt/openhab2-2_2_0/userdata/tmp/bundles
Both of the paths in the error messages above (/opt/openhab2-nov/userdata/tmp/bundles, /opt/openhab2-2_2_0/userdata/tmp/bundles) are OLD install locations.
My current install is located in /opt/openhab2-2_2_0_zwave23snap and is started by systemd via a symlink of /opt/openhab2
Do I need to update this path somewhere in the config?
Next in openhab.log are multiple BundleExceptions (perhaps a result of the above error?)
org.osgi.framework.BundleException: A bundle is already installed with the name "org.openhab.binding.exec" and version "2.1.0.201801250215"
at org.eclipse.osgi.container.ModuleContainer.install(ModuleContainer.java:260) [?:?]
at org.eclipse.osgi.storage.Storage.install(Storage.java:539) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.installBundle(BundleContextImpl.java:146) [?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.installOrUpdateBundle(DirectoryWatcher.java:1036) [8:org.apache.felix.fileinstall:3.5.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.install(DirectoryWatcher.java:952) [8:org.apache.felix.fileinstall:3.5.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.install(DirectoryWatcher.java:871) [8:org.apache.felix.fileinstall:3.5.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:485) [8:org.apache.felix.fileinstall:3.5.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:361) [8:org.apache.felix.fileinstall:3.5.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:312) [8:org.apache.felix.fileinstall:3.5.8]
2018-03-10 15:05:48.320 [ERROR] [org.apache.felix.fileinstall ] - Failed to install artifact: /opt/openhab2-2_2_0_zwave23snap/addons/org.openhab.binding.zwave-2.3.0-SNAPSHOT.jar
org.osgi.framework.BundleException: A bundle is already installed with the name "org.openhab.binding.zwave" and version "2.3.0.201803041016"
2018-03-10 15:05:48.324 [ERROR] [org.apache.felix.fileinstall ] - Failed to install artifact: /opt/openhab2-2_2_0_zwave23snap/addons/org.openhab.binding.unifi-2.2.0-SNAPSHOT.jar
org.osgi.framework.BundleException: A bundle is already installed with the name "org.openhab.binding.unifi" and version "2.2.0.201709220819"
2018-03-10 15:05:48.332 [ERROR] [org.apache.felix.fileinstall ] - Failed to install artifact: /opt/openhab2-2_2_0_zwave23snap/addons/org.openhab.binding.exec-2.2.0-SNAPSHOT.jar
2018-03-10 15:05:48.349 [ERROR] [org.apache.felix.fileinstall ] - Failed to install artifact: /opt/openhab2-2_2_0_zwave23snap/addons/org.openhab.binding.zwave-2.3.0-SNAPSHOT.jar
2018-03-10 15:05:48.353 [ERROR] [org.apache.felix.fileinstall ] - Failed to install artifact: /opt/openhab2-2_2_0_zwave23snap/addons/org.openhab.binding.unifi-2.2.0-SNAPSHOT.jar
I have dealt with these types of errors in the past using the Karaf console to uninstall the conflicting bundle. I did so and restarted. But I continue to get these errors on every start. Here is the Karaf console bundle output:
openhab> bundle:list | grep "Exec Bind"
242 │ Active │ 80 │ 2.1.0.201801250215 │ Exec Binding
openhab> bundle:list | grep "ZW"
240 │ Active │ 80 │ 2.3.0.201803041016 │ ZWave Binding
openhab> bundle:list | grep "Un"
15 │ Active │ 80 │ 2.2.0.201709220819 │ UniFi Binding
openhab>
Thanks in advance!
Dave
