Nip
(Nip Nippler)
May 30, 2018, 10:57am
#1
OpenHAB 2.3 Installation on Synology NAS
DSM 6 doesnt work. Spk isnt installing. 2.2 does work as described
Platform information:
Hardware: CPUArchitecture/RAM/storage
OS: what OS is used and which version
Java Runtime Environment: which java platform is used and what version
openHAB version:
Issue of the topic: please be detailed explaining your issue
Please post configurations (if applicable):
Items configuration related to the issue
Sitemap configuration related to the issue
Rules code related to the issue
Services configuration related to the issue
If logs where generated please post these here using code fences:
Same here openHAB-2.3.0.002-syno-noarch-0.001 does not start, files seems to be missing
openHAB-2.2.0.010-syno-noarch-0.001 does install and start
I’m on DSM 6.1, DS415+
Greza
(Greg)
June 11, 2018, 4:12pm
#3
Is your version of DSM up to date? I’m running DSM 6.1.7-15284 with OH 2.3.0.001-snapshot without issue.
Have you updated to Java8?
It also looks like in version 2.3.0.003 they fixed an issue with packages not starting.
latest spk works flawless on xpenology 6.1.7
mind that a extra folder is needed now to.
if choosen i use following pre created folder on my public drive.
addons
conf
userdata
kindest regards
