Have you specified pushover binding in the addons.cfg??
Yes. It specified there, under action.
/Sas
This may sound odd. But maybe try delete it from there, and install it manually.. Just to see what happens.
You havenât mentioned the type of installation or how you upgraded, but have you cleared the cache and what jars do you have in your addons directory?
I had the exact same symptoms with the zwave stick. My logs showed âFailed installing âopenhab-binding-yahooweatherââ and the only fix was to remove the yahooweather from the list of addons in addons.cfg. This wasnât a major issue since i donât use it. But weird that the zwave binding seems to be affected by this in the milestone releases.
7 posts were split to a new topic: Memory dropping?
