Migrating from version 2.4 I started with 2.5-M3 successfully, updated M3 successfully to 2.5-M4 and updated M4 successfully to 2.5-M5 a couple days ago.
First I want to say that you made a very good job.
According openHAB 2.5-M5 there are some points I want to ask and mybe to get them fixed/clarified prior or with the final release of 2.5:
SNMP Things/Items shows/stores values even the host is down. Please do not store values, if the thing is not available.
When creating items on things the link button is active even you already clicked on it e.g. to create a new item, this leads to duplication items in the database.
The item naming language changed from enlish (last seen) to german (zuletzt gesehen) while creating items on some things, even though the system regional language and the user interface was set to english. Even deleting and recreating the items did not change to english.
when creating items on things and you want to reuse existing items the drop down list ist not sorted alphabetically by type/short-name nor by the real item name and very small. It would be helpful to change the āreuse itemā functionality in a way that it could be used in a better way, e.g. sorting by real name and/or searching by part of name and resizable.
A little bit of information would be needed to know which thing or item is producing this error:
[.smarthome.model.script.actions.HTTP] - Fatal transport error: java.util.concurrent.TimeoutException: Total timeout 5000 ms elapsed
On the control view of the paperui it would be nice to see if a thing has been disabled within the configuration.
Multiple databases would be nice to store measurements like LAN statistics e.g. into influx-db and others e.g. into my sql or into multiple databases on the same sql engine. This should be configured by groups of things and/or directly on things an/or on by dedicated items or groups of them on different things.
How to delete automatic created items in paperui.
The paperui does not refresh every time you install or uninstall addons e.g bindings.
It would be nice to have in paperui/addons an overview of what you installed in a sum of all sub sections or by section. Otherwise you have to go thruw all sections.
There is for sure more to define by some points I wrote down, so please do not mind me for keeping so short worded.
I hope that some points, e.g. SNMP would be fixed prior major release of 2.5
Could it be possible that you change to minor versions to fix subsets of openHAB e.g. from 2.5 to 2.5.1 to get some updates into major releases faster?
Please reply with questions or concerns.
Thanks and best regards
Marc
