I have two garage doors. I wanted to be notified if I inadvertently left a door open longer the x minutes. It looked like using the Expire binding would fit nicely into my plan. Following a tutorial, I put together this test code.
My items.
Number myGar1Counter "Garage1 Minutes counter [%s]" <clock> {expire="1m,command=-1", autoupdate="false"}
Switch myGar1testLamp "Garage1 example light [%s]" <light>
Switch MyGar1Door "Garage Door1" <button>
Number myGar2Counter "Garage2 Minutes counter [%s]" <clock> {expire="1m,command=-1", autoupdate="false"}
Switch myGar2testLamp "Garage2 example light [%s]" <light>
Switch MyGar2Door "Garage Door2" <button>
Site Map
Text item=myGar1Counter
Switch item=myGar1testLamp
Switch item=MyGar1Door
Text item=myGar2Counter
Switch item=myGar2testLamp
Switch item=MyGar2Door
Rules
// Rule to manage countdown
rule "Garage 1 Door"
Item myGar1Counter received command
var cmmd = (receivedCommand as Number).intValue // integers only
var count = 0
var String msg = "Garage 1 Door" + cmmd
logInfo("motion", msg)
if (myGar1Counter.state != NULL) { // avoid 1st time run error
count = (myGar1Counter.state as Number).intValue
if (cmmd == -1 && count > 0) { // decrement counter, do not go below zero
if (count == 1) {
// do actions for counter expiry, as we about to zero it now
myGar1testLamp.sendCommand(OFF)
myGar1Counter.postUpdate(count - 1)
} /*else if (cmmd >= count || cmmd < -1) { // new or refreshed target
if (cmmd < -1) { // force override
cmmd = 0 - cmmd // make it positive
myGar1Counter.postUpdate(cmmd) // nb we still update even if equal value - resets expire binding
// do startup/continue actions
if (myGar1testLamp.state != ON) {
myGar1testLamp.sendCommand(ON)
else if (cmmd == 5) { // new or refreshed target
else if (cmmd == 0) { // cancel countdown
myGar1Counter.postUpdate(0)
// do optional cancel actions
rule "Garage 2 Door"
Item myGar2Counter received command
var count = 0
var String msg = "Garage 2 Door" + cmmd
if (myGar2Counter.state != NULL) { // avoid 1st time run error
if (count == 1) {
myGar2testLamp.sendCommand(OFF)
myGar2Counter.postUpdate(count - 1)
else if (cmmd == 3) { // new or refreshed target
myGar2Counter.postUpdate(cmmd) // nb we still update even if equal value - resets expire binding
if (myGar2testLamp.state != ON) {
myGar2testLamp.sendCommand(ON)
myGar2Counter.postUpdate(0)
rule "Garage1 opened"
Item MyGar1Door changed from OFF to ON
myGar1Counter.sendCommand(5)
rule "Garage1 Closed"
Item MyGar1Door changed from ON to OFF
myGar1Counter.sendCommand(0)
rule "Garage2 opened"
Item MyGar2Door changed from OFF to ON
myGar2Counter.sendCommand(3)
rule "Garage2 Closed"
Item MyGar2Door changed from ON to OFF
myGar2Counter.sendCommand(0)
So when I set MyGar2Door to ON, myGar2Counter is set to 3, three minutes. So far so good. When I set MyGar1Door to ON, myGar1Counter is set to 5, five minutes. When
myGar1Counter decrements to 4, myGar2Counter also goes to 4. I don’t know why myGar2Counter is now equal to myGar1Counter.
I have looked at this code over and over again, and don’t understand how the two counters are reacting to each other. I am at a loss as to why this is.
I am on openHab 2.5.1 with a Raspberry Pi apt install. Expire binding is 1.14.0
Thanks,
Chris
