today I have installed a 2nd Pid-Controller on my installation.
The first one is working for a while ( used for heating in the kitchen). No I will use a 2nd one in the living room.
I created a 2nd rule from the ui with a PID-Controller. The setup is the same as for the first one.
The rule with the controller itself seems to work, But after changing the setpoint, the Reset command is not working.
Here is my setup from the working one:
configuration: {}
triggers:
- id: 19fc1495-36b4-49a7-9a2c-2dc132bd4a69
label: PID Controller Trigger
configuration:
iInspector: KUET_iInspector
setpoint: KUET_SetPoint_Heat
kp: 65
pInspector: KUET_pInspector
kdTimeConstant: 0
dInspector: KUET_dInspector
input: KUAQ_T_Temperature
eInspector: KUET_eInspector
kd: 0
commandItem: KUET_PidCommandItem
ki: 0.4
loopTime: 60000
type: pidcontroller.trigger
conditions: []
actions:
- inputs: {}
configuration:
itemName: KU_Pid_out
type: core.ItemCommandAction
and here a part of the loggfile after changing the setpoint
2023-12-27 10:39:52.696 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'KUET_PidCommandItem' received command RESET
2023-12-27 10:39:52.700 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'KUET_PidCommandItem' changed from NULL to RESET
2023-12-27 10:39:52.703 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'KUET_PidCommandItem' changed from RESET to NULL
2023-12-27 10:39:52.713 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'KUET_Th_Valve_Position' received command 33
2023-12-27 10:39:52.714 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'KUET_Th_Valve_Position' predicted to become 33
2023-12-27 10:39:52.720 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'KUET_Th_Valve_Position' changed from 0 to 33
So the Rule/controller changes the reset back to Null after doing something.
Here is the setup from the second:
configuration: {}
triggers:
- id: b5633be2-6c6e-4921-8cf9-c0166d64c544
configuration:
setpoint: WZET_SetPoint_Heat
iInspector: WZ_iInspector
kp: 65
pInspector: WZ_pInspector
kdTimeConstant: 0
dInspector: WZ_dInspector
input: WZAQ_T_Temperature
eInspector: WZ_eInspector
kd: 0
commandItem: WZ_PidCommandItem
ki: 0.4
loopTime: 60000
conditions: []
actions:
- inputs: {}
configuration:
itemName: WZ_Pid_Out
and here the log part
2023-12-27 10:41:01.128 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'WZ_PidCommandItem' received command RESET
2023-12-27 10:41:01.800 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'WZET_SetPoint_Heat' received command 19
2023-12-27 10:41:01.805 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WZET_SetPoint_Heat' changed from 1 to 19
2023-12-27 10:41:01.817 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'WZ_Pid_Out' received command -5779.189222333376
2023-12-27 10:41:01.820 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WZ_pInspector' changed from -1123.2 to 46.799999999999926
2023-12-27 10:41:01.824 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WZ_iInspector' changed from -5825.9928271333765 to -5825.989222333376
2023-12-27 10:41:01.827 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WZ_eInspector' changed from -17.28 to 0.7199999999999989
here you can see that the controller item received the reset, but did not change it back to null as on the working one.
I compared all items needed for this rules. On both the rule to sent a reset is working, because we can see the reset in the logging.
But I did not do any reset.
Has someone an idea wht’s going wrong, or where can I debug something?
