3.4.0 -> 4.1.0 Amazon Echo Control does not work with two accounts anymore
Hi all,
I just migrated my OpenHAB 3.4.0 installation to 4.1.0.
Since than it looks like only one of my two Amazon Accounts is working any more.
2023-12-26 17:25:52.321 [WARN ] [trol.internal.handler.AccountHandler] - Failed to create account servlet
java.lang.IllegalStateException: ServletModel{id=ServletModel-87,name='org.openhab.binding.amazonechocontrol.internal.AccountServlet',alias='/amazonechocontrol/hans',urlPatterns=[/amazonechocontrol/hans/*],servlet=org.openhab.binding.amazonechocontrol.internal.AccountServlet@9a9bf1,contexts=[{HS,OCM-35,default,/}]} can't be registered. ServletContextModel{id=ServletContextModel-4,contextPath='/'} already contains servlet named org.openhab.binding.amazonechocontrol.internal.AccountServlet: ServletModel{id=ServletModel-86,name='org.openhab.binding.amazonechocontrol.internal.AccountServlet',alias='/amazonechocontrol/christoph',urlPatterns=[/amazonechocontrol/christoph/*],servlet=org.openhab.binding.amazonechocontrol.internal.AccountServlet@5d7a4a,contexts=[{HS,OCM-35,default,/}]}
	at org.openhab.binding.amazonechocontrol.internal.AccountServlet.<init>(AccountServlet.java:95) ~[bundleFile:?]
	at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.initialize(AccountHandler.java:146) [bundleFile:?]
	at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) ~[?:?]
	at java.lang.reflect.Method.invoke(Method.java:568) ~[?:?]
	at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:147) [bundleFile:?]
	at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
Currently the account Christoph is working Hans is not.
If I select hans under /amazonechocontrol/ nothing is happening. Looks like I just get forwarded to the same page.
This was working in 3.4.0 before.
Anything I have missed?
Best regards
Timmi
Nothing changed on the code since at least 02/2021, that’s way before 3.4. The most probable reason is something on Amazon’s side changed that is not properly implemented.
Hi @J-N-K ,
hm.. the accounts are working separately. So I would doubt that this is on Amazon side.
Any logs required from my side or should I open a ticket for the binding?
I have a similar problem with one account:
Updating from 3.3 to 4.1 didn’t work so well.
I quickly decided for a fresh install. :grinning:
I can not get my amazonechocontrol:account working.
I does not let me enter the verification code I receive from amazon.
1.) go to http://openhabianpi:8080/amazonechocontrol/XXXXXX
2.) login with my account
3.) solve the captcha
4.) wait for a verification code via mail from amazon
5.) page goes back to login page within 5 seconds
6.) receive the verification code - but can’t enter because page switched back to login :stuck_out_tongue_closed_eyes:
You must enable the “Zwei-Schritt-Verifizierung (2SV)” “Two Factor Authentication (2FA)” in your amazon account.
That did it for me.
Thank you - that’s the solution. :+1:
I didn’t expect that it becomes easier if I tighten security. :joy:
I think Christoph and Hans will both be working both with this fix :slight_smile: :
https://github.com/openhab/openhab-addons/pull/16152
@wborn super news thx
