No such feature. It would probably be configuration group adresses wrong etc. without some more information about your setup its impossible to pin point the problem.
I need to check again (but I can’t do that when everyone is at home!), but I think the lights where switched off when this log occured:
2024-01-30 20:46:46.327 [INFO ] [nx.internal.client.AbstractKNXClient] - Bridge knx:ip:KnxGateway connected to KNX bus
There is something strange: the KNX bridge is a N146, configured as router. All is working fine since the begining. But right after the upgrade, the discovery service showed me an unconfigured N146!
As I can’t use the UI for more than 2 minutes (see my other thread), how can I retreive the config to show it here, from the console?
For each thing configured there is a code tab next to it. But that code mean nothing if we don’t know what group adress is status or switching. Also you sure you don’t have some sort of rule running at startup ?
