I originally installed openhab. I stopped it and installed OpenHab2 bc I was having a problem with an unknown device thatwas in the DB. Openhab2 did fix the problem and the device was recognized (Inovelli NZW31) but now there is nothing in controls.
I’m on a windows 10 machine with I3
I downloaded and installed Zulu Java
Screenshots and logs can help to understand the problem.
event log
2018-08-01 12:04:13.831 [thome.event.ExtensionEvent] - Extension 'package-standard' has been installed.
2018-08-01 12:04:19.116 [thome.event.ExtensionEvent] - Extension 'ui-homebuilder' has been installed.
2018-08-01 12:04:19.116 [thome.event.ExtensionEvent] - Extension 'ui-basic' has been installed.
2018-08-01 12:04:19.117 [thome.event.ExtensionEvent] - Extension 'ui-habpanel' has been installed.
2018-08-01 12:04:19.118 [thome.event.ExtensionEvent] - Extension 'ui-paper' has been installed.
2018-08-01 12:05:05.554 [thome.event.ExtensionEvent] - Extension 'binding-zwave' has been installed.
2018-08-01 12:05:22.686 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:9c2cc40d' changed from UNINITIALIZED to INITIALIZING
2018-08-01 12:05:22.710 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:9c2cc40d' has been updated.
2018-08-01 12:05:22.721 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:9c2cc40d' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2018-08-01 12:05:25.949 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:9c2cc40d' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2018-08-01 12:05:31.606 [home.event.InboxAddedEvent] - Discovery Result with UID 'zwave:device:9c2cc40d:node3' has been added.
2018-08-01 12:05:33.870 [home.event.InboxAddedEvent] - Discovery Result with UID 'zwave:device:9c2cc40d:node2' has been added.
2018-08-01 12:05:49.334 [me.event.InboxRemovedEvent] - Discovery Result with UID 'zwave:device:9c2cc40d:node2' has been removed.
2018-08-01 12:05:49.347 [hingStatusInfoChangedEvent] - 'zwave:device:9c2cc40d:node2' changed from UNINITIALIZED to INITIALIZING
2018-08-01 12:05:49.352 [hingStatusInfoChangedEvent] - 'zwave:device:9c2cc40d:node2' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2018-08-01 12:05:49.383 [hingStatusInfoChangedEvent] - 'zwave:device:9c2cc40d:node2' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to UNINITIALIZED
2018-08-01 12:05:49.393 [hingStatusInfoChangedEvent] - 'zwave:device:9c2cc40d:node2' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-08-01 12:05:49.419 [hingStatusInfoChangedEvent] - 'zwave:device:9c2cc40d:node2' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2018-08-01 12:05:49.423 [hingStatusInfoChangedEvent] - 'zwave:device:9c2cc40d:node2' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2018-08-01 12:05:49.424 [hingStatusInfoChangedEvent] - 'zwave:device:9c2cc40d:node2' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2018-08-01 12:05:49.446 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:9c2cc40d:node2' has been updated.
2018-08-01 12:05:49.476 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:9c2cc40d:node2' has been updated.
2018-08-01 12:05:49.507 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:9c2cc40d:node2' has been updated.
2018-08-01 12:05:49.513 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[]]
2018-08-01 12:05:49.519 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:9c2cc40d:node2' has been updated.
2018-08-01 12:05:53.117 [me.event.InboxRemovedEvent] - Discovery Result with UID 'zwave:device:9c2cc40d:node3' has been removed.
2018-08-01 12:05:53.131 [hingStatusInfoChangedEvent] - 'zwave:device:9c2cc40d:node3' changed from UNINITIALIZED to INITIALIZING
2018-08-01 12:05:53.146 [hingStatusInfoChangedEvent] - 'zwave:device:9c2cc40d:node3' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2018-08-01 12:05:53.157 [hingStatusInfoChangedEvent] - 'zwave:device:9c2cc40d:node3' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to UNINITIALIZED
2018-08-01 12:05:53.159 [hingStatusInfoChangedEvent] - 'zwave:device:9c2cc40d:node3' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-08-01 12:05:53.182 [hingStatusInfoChangedEvent] - 'zwave:device:9c2cc40d:node3' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2018-08-01 12:05:53.187 [hingStatusInfoChangedEvent] - 'zwave:device:9c2cc40d:node3' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2018-08-01 12:05:53.188 [hingStatusInfoChangedEvent] - 'zwave:device:9c2cc40d:node3' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2018-08-01 12:05:53.219 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:9c2cc40d:node3' has been updated.
2018-08-01 12:05:53.243 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:9c2cc40d:node3' has been updated.
2018-08-01 12:05:53.260 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:9c2cc40d:node3' has been updated.
2018-08-01 12:05:53.261 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[]]
2018-08-01 12:05:53.263 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:9c2cc40d:node3' has been updated.
2018-08-01 12:06:11.326 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:9c2cc40d:node3' has been updated.
2018-08-01 12:06:11.327 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[ConfigStatusMessage [parameterName=config_1_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=switchall_mode, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_2_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=group_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_4_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=group_3, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=group_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_5_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null]]]
2018-08-01 12:06:11.450 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:9c2cc40d:node3' has been updated.
2018-08-01 12:06:11.450 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[ConfigStatusMessage [parameterName=config_1_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=switchall_mode, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_2_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_4_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=group_3, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=group_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_5_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null]]]
2018-08-01 12:06:11.503 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:9c2cc40d:node3' has been updated.
2018-08-01 12:06:11.504 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[ConfigStatusMessage [parameterName=config_1_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=switchall_mode, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_2_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_4_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=group_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_5_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null]]]
2018-08-01 12:06:11.567 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:9c2cc40d:node3' has been updated.
2018-08-01 12:06:11.570 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[ConfigStatusMessage [parameterName=config_1_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=switchall_mode, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_2_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_4_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_5_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null]]]
2018-08-01 12:06:15.383 [arthome.event.BindingEvent] - org.openhab.binding.zwave.event.BindingEvent@155ad35
2018-08-01 12:06:45.460 [arthome.event.BindingEvent] - org.openhab.binding.zwave.event.BindingEvent@1ceb4da
2018-08-01 12:17:33.853 [hingStatusInfoChangedEvent] - 'zwave:device:9c2cc40d:node2' changed from ONLINE to UNINITIALIZED
2018-08-01 12:17:33.875 [hingStatusInfoChangedEvent] - 'zwave:device:9c2cc40d:node2' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-08-01 12:17:33.876 [hingStatusInfoChangedEvent] - 'zwave:device:9c2cc40d:node3' changed from ONLINE to UNINITIALIZED
2018-08-01 12:17:33.890 [hingStatusInfoChangedEvent] - 'zwave:device:9c2cc40d:node3' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-08-01 12:17:33.890 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:9c2cc40d' changed from ONLINE to UNINITIALIZED
2018-08-01 12:17:37.251 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:9c2cc40d' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
i’m trying to paste the openhab.log file but i get the error :
slight_smile: slight_smile:Body is limited to 32000 characters; you entered 179734.
select for change
and assign the channels to items.
Hi Harry - Your screenshots are cutoff so I don’t know what I am supposed to do
I don’t have your configuration, so the short form.
Go to the PaperUi / Things and select Z-Wave Serial Controller …
and then?
