This is quite strange @Master79, did you upgrade firmware recently? I may suggest you to reboot your miflora device, remove its battery and put it back again (or maybe change it to a new battery).
Is it only one device is acting up or all your miflora devices?
It’s only this device. Use four of them. I have already reset it by putting out the battery. The same problem.
Okay, i will change the battery and test it again.
Thanks and greetings,
Markus
Hi @vkolotov. Nice work done here with tis binding. It looks pretty good.
I have two tablets laying around my house as control panels using HABPanel. They are running rooted android LineageOS. It would be really nice if I could make use of the Bluetooth of those tablets to work with the binding, reporting to it, the reachable devices that are near them.
Do you think this could be done?
i’ve recently re-installed linux that my OH runs on, and since then I’ve not been able to get bluetooth to work with OH - the adapters can’t be detected.
Bluetooth is installed. Doing ‘hcitool scan’ and ‘hcitool lescan’ from the commandline detects the adapter and nearby devices.
Same here. If you check the service something is not ok:
[14:23:21] openhabian@openHABianPi:~$ sudo systemctl status bluetooth
[sudo] password for openhabian:
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset
Active: active (running) since Sat 2019-07-13 14:21:48 CEST; 1min 58s ago
Docs: man:bluetoothd(8)
Main PID: 1622 (bluetoothd)
Status: “Running”
Tasks: 1 (limit: 4915)
CGroup: /system.slice/bluetooth.service
└─1622 /usr/libexec/bluetooth/bluetoothd
Jul 13 14:21:47 openHABianPi systemd[1]: Starting Bluetooth service…
Jul 13 14:21:48 openHABianPi bluetoothd[1622]: Bluetooth daemon 5.47
Jul 13 14:21:48 openHABianPi systemd[1]: Started Bluetooth service.
Jul 13 14:21:48 openHABianPi bluetoothd[1622]: Starting SDP server
Jul 13 14:21:48 openHABianPi bluetoothd[1622]: Bluetooth management interface 1.
Jul 13 14:21:48 openHABianPi bluetoothd[1622]: Failed to set privacy: Rejected (…
But if you restrt the service with: “sudo systemctl restart bluetooth” it is ok than…
I’m a long time OH user, but I’ve not ventured out to using bluetooth yet. Found this project and it seems interesting. Thanks to everyone who contributed! Forgive me if this has been covered before, but I couldn’t find it in search.
How is everyone setting up their BT adapters for presence detection in each room?
I haven’t tried out this binding yet, but based on what I understand from the readme, the binding is meant to be used with multiple adapters. However, I don’t quite understand how this would work. Are you meant to run USB extension cables to each room in the house? This wouldn’t work in large homes where wiring can be hard to run. Is there a way to get the adapters to mesh to each other wirelessly or via IP?
@Dibbler42@vkolotov Was there ever any progress on the Primadonna Elite series of coffee makers? I have this unit since a couple of years, and it is kind of a missing link in my home automation Could it be made to (at least) startup from oh?
Of is it simply not possible?
Hrm, USB over IP. Interesting idea. Thanks for the suggestions!
I did wind up installing this binding over the weekend to test it out on my odroid XU4, but didn’t have any luck. The discovery process starts, but no devices are ever found. I addressed all the items in the readme (downgrading to Bluez 5.47, turning on discovery, granting permissions to Bluez, etc), but no luck yet. The logs don’t seem to report any obvious errors after the “could not power adapter” issue was cleared.
Hi all, i have a small Q
can we make BT keyboard work with the binding and send commands to OH?
this can be a very cool addon just 8$ and you get some really good looking keys
and its wireless out of the box
did anyone do anything like this… i dont have a keyboard to test but i will buy if it works cheers
Hi, I have problems getting work my Xiaomi Mijia Bluetooth Temperature Smart Humidity sensors.
I’m on a Rpi3 with Raspbian Stretch, BlueZ 5.43, bluetooth binding 1.1.6 and tinyb 1.1.3.
The first problem I have is that I’m able to discover my sensors only if they are less than 1 meter far from the Rpi, but this is another problem and I’ll try to solve it later.
The first time I succedeed in discovering the sensors I got the temperature and humidity channels (and even battery).
Now, after having removed and re-added the things, I don’t have anymore those channels.
Having trouble with a North (compatible with xiaomi miflora, apparently) device. http://weliveupnorth.com/plant-monitor
It is working fine from the Xiaomi app, and can also see it with hcitool, but PaperUI doesn’t show it when scanning. MAC address is very similar to the official Miflora I do have.
It is also possible that scanning is not working for me, as it’s been a while since I’ve had to add a new bluetooth device
If you are on linux you can use the “linuxinput” binding to trigger on key events.
(Merged today, should show up in the snapshot builds soon).
Just pair the keyboard with bluez and use it as a normal keyboard.
Also the keyboard you linked is not in fact a bluetooth keyboard, it uses a custom receiver. It will work with the linuxinput binding, too.
