I upgraded to 4.0 M1 and now I see this issue:
2023-03-26 13:24:10.334 [WARN ] [core.thing.internal.ThingManagerImpl] - Could not normalize configuration for 'zwave:device:d09e64fb:node6' because the thing type was not found in registry.
2023-03-26 13:24:10.335 [WARN ] [core.thing.internal.ThingManagerImpl] - Could not normalize configuration for 'zwave:device:d09e64fb:node6' because the thing type was not found in registry.
2023-03-26 13:24:10.347 [WARN ] [core.thing.internal.ThingManagerImpl] - Could not normalize configuration for 'zwave:device:d09e64fb:node12' because the thing type was not found in registry.
2023-03-26 13:24:10.349 [WARN ] [core.thing.internal.ThingManagerImpl] - Could not normalize configuration for 'zwave:device:d09e64fb:node12' because the thing type was not found in registry.
2023-03-26 13:24:10.582 [WARN ] [core.thing.internal.ThingManagerImpl] - Could not normalize configuration for 'zwave:device:d09e64fb:node4' because the thing type was not found in registry.
2023-03-26 13:24:10.584 [WARN ] [core.thing.internal.ThingManagerImpl] - Could not normalize configuration for 'zwave:device:d09e64fb:node4' because the thing type was not found in registry.
Also tried build 3386, no change. Suggestions?
