After updating to 4.1.1, openHab takes approximately 30 minutes to fully stabilize after reboot. During that time, the CPU and memory utilizations are below 50% and the heap file looks good. I’m getting a Rule Engine warning right at startup (shown below) and persistence errors for the next 30 minutes. During that time, I can manually run a rule, but none of the rules will trigger from a time or item change/command event. I’m not finding any other clues in the log. Any troubleshooting advice would be appreciated.
OpenHabian
OpenHAB 4.1.1
2024-01-18 23:12:36.508 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2024-01-18 23:12:36.605 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at java.util.Objects.requireNonNull(Objects.java:209) ~[?:?]
at io.micrometer.core.instrument.ImmutableTag.<init>(ImmutableTag.java:35) ~[?:?]
at io.micrometer.core.instrument.Tag.of(Tag.java:29) ~[?:?]
at org.openhab.core.io.monitor.internal.metrics.BundleStateMetric.createOrUpdateMetricForBundleState(BundleStateMetric.java:78) ~[?:?]
at org.openhab.core.io.monitor.internal.metrics.BundleStateMetric.lambda$0(BundleStateMetric.java:62) ~[?:?]
at java.util.Spliterators$ArraySpliterator.forEachRemaining(Spliterators.java:992) ~[?:?]
at java.util.stream.ReferencePipeline$Head.forEach(ReferencePipeline.java:762) ~[?:?]
at org.openhab.core.io.monitor.internal.metrics.BundleStateMetric.bindTo(BundleStateMetric.java:61) ~[?:?]
at org.openhab.core.io.monitor.internal.DefaultMetricsRegistration.lambda$0(DefaultMetricsRegistration.java:96) ~[?:?]
at java.lang.Iterable.forEach(Iterable.java:75) ~[?:?]
at org.openhab.core.io.monitor.internal.DefaultMetricsRegistration.registerMeters(DefaultMetricsRegistration.java:96) ~[?:?]
at org.openhab.core.io.monitor.internal.DefaultMetricsRegistration.onReadyMarkerAdded(DefaultMetricsRegistration.java:105) ~[?:?]
at org.openhab.core.internal.service.ReadyServiceImpl.lambda$0(ReadyServiceImpl.java:52) ~[?:?]
at java.util.stream.ForEachOps$ForEachOp$OfRef.accept(ForEachOps.java:183) ~[?:?]
at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:197) ~[?:?]
at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:179) ~[?:?]
at java.util.HashMap$EntrySpliterator.forEachRemaining(HashMap.java:1850) ~[?:?]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:509) ~[?:?]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:499) ~[?:?]
at java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:150) ~[?:?]
at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:173) ~[?:?]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:?]
at java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:596) ~[?:?]
at org.openhab.core.internal.service.ReadyServiceImpl.notifyTrackers(ReadyServiceImpl.java:76) ~[?:?]
at org.openhab.core.internal.service.ReadyServiceImpl.markReady(ReadyServiceImpl.java:52) ~[?:?]
at org.openhab.core.service.StartLevelService.setStartLevel(StartLevelService.java:249) ~[?:?]
at org.openhab.core.service.StartLevelService.lambda$0(StartLevelService.java:123) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) ~[?:?]
