Hi, i have 2 RPI3 first one has OH2 installed, a 433mhz sensor for my door sensor and a usb camera that im using as ip camera for second rpi3 the plus edition with Motion eye os in rpi3+ and Motion in rpi3
My problem is when Motion is up and runing i cant receive signal for my 433mhz sensor unless u stop Motion manually than it works, so im thinking maybe the voltage is dropping down but not sure?!
This appears to be a Raspberry Pi issue, not openHAB. Have you looked in any of their forums? They will likely be more experienced with running that hardware combination.
Are you using a good 5v 2.5a power supply? I would check with a meter to verify as some of the cheap ones will not provide as advertised.
Another option is power the motion sensor externally and check the output voltage to Pi as you may need to use a logic level shifter circuit to prevent hard to the Pi.
