I’m just in touch with @ysc, the HabPanel’s developer, and he suggest to ask here.
It happen that when I try to save Panel configuration to OpenHab, I got a 500 Internal Server Error.
Running from REST API documentation site, and tring to save a valid panel configuration I got this:
I also tried to update the panel configuration from Paper UI->Configuration->Services but when I save, I get 500 Internal server Error in a small dark grey banner at bottom right of the page.
2016-12-14 11:58:33.273 [ERROR] [.service.ConfigurableServiceResource] - Cannot update configuration for service org.openhab.ui.habpanel: Permission denied
java.io.IOException: Permission denied
at java.io.UnixFileSystem.createFileExclusively(Native Method)[:1.8.0_102]
at java.io.File.createTempFile(File.java:2024)[:1.8.0_102]
at org.apache.felix.cm.file.FilePersistenceManager._store(FilePersistenceManager.java:699)
at org.apache.felix.cm.file.FilePersistenceManager.store(FilePersistenceManager.java:660)
at org.apache.felix.cm.impl.CachingPersistenceManagerProxy.store(CachingPersistenceManagerProxy.java:242)
at org.apache.felix.cm.impl.ConfigurationImpl.update(ConfigurationImpl.java:381)
at org.apache.felix.cm.impl.ConfigurationAdapter.update(ConfigurationAdapter.java:131)
at org.eclipse.smarthome.io.rest.core.config.ConfigurationService.update(ConfigurationService.java:91)
at org.eclipse.smarthome.io.rest.core.config.ConfigurationService.update(ConfigurationService.java:56)
at org.eclipse.smarthome.io.rest.core.service.ConfigurableServiceResource.updateConfiguration(ConfigurableServiceResource.java:136)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_102]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_102]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_102]
at java.lang.reflect.Method.invoke(Method.java:498)[:1.8.0_102]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271)[155:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267)[155:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315)[155:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297)[155:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267)[155:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317)[155:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154)[156:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473)[153:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427)[153:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388)[153:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341)[153:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228)[153:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76)[11:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:812)[79:org.eclipse.jetty.servlet:9.2.14.v20151106]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:587)[79:org.eclipse.jetty.servlet:9.2.14.v20151106]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:70)[170:org.ops4j.pax.web.pax-web-jetty:4.2.4]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)[78:org.eclipse.jetty.server:9.2.14.v20151106]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)[77:org.eclipse.jetty.security:9.2.14.v20151106]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)[78:org.eclipse.jetty.server:9.2.14.v20151106]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)[78:org.eclipse.jetty.server:9.2.14.v20151106]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:271)[170:org.ops4j.pax.web.pax-web-jetty:4.2.4]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)[79:org.eclipse.jetty.servlet:9.2.14.v20151106]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)[78:org.eclipse.jetty.server:9.2.14.v20151106]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)[78:org.eclipse.jetty.server:9.2.14.v20151106]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)[78:org.eclipse.jetty.server:9.2.14.v20151106]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)[170:org.ops4j.pax.web.pax-web-jetty:4.2.4]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)[78:org.eclipse.jetty.server:9.2.14.v20151106]
at org.eclipse.jetty.server.Server.handle(Server.java:499)[78:org.eclipse.jetty.server:9.2.14.v20151106]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:311)[78:org.eclipse.jetty.server:9.2.14.v20151106]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)[78:org.eclipse.jetty.server:9.2.14.v20151106]
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:544)[70:org.eclipse.jetty.io:9.2.14.v20151106]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)[81:org.eclipse.jetty.util:9.2.14.v20151106]
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)[81:org.eclipse.jetty.util:9.2.14.v20151106]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_102]
Sorry, I never have time, this is the wrong question
But looking at your exception, it obviously seems to be some issue with your file system privileges. Whatever folder Java wants to use for temporary files is not writable for the openHAB runtime.
