KidSquid
(The Squid)
November 4, 2017, 5:16am
1
I just noticed that I’m receiving the following in my OpenHab log…
2017-11-03 20:43:13.330 [WARN ] [org.openhab.io.net.http.HttpUtil ] - Method failed: HTTP/1.1 500 Internal Server Error
How can I perform additional research to find out what is causing this error? I see HTTP so is this an issue with Jetty?
I’m running on 2.2 SNAPSHOT #1072
KidSquid
(The Squid)
November 5, 2017, 4:27pm
2
In looking at the logs I see a pattern…this seems to happening on the hour, every hour.
2017-11-05 04:51:09.909 [WARN ] [org.openhab.io.net.http.HttpUtil ] - Method failed: HTTP/1.1 500 Internal Server Error
2017-11-05 05:51:23.812 [WARN ] [org.openhab.io.net.http.HttpUtil ] - Method failed: HTTP/1.1 500 Internal Server Error
2017-11-05 06:51:37.892 [WARN ] [org.openhab.io.net.http.HttpUtil ] - Method failed: HTTP/1.1 500 Internal Server Error
2017-11-05 07:51:51.746 [WARN ] [org.openhab.io.net.http.HttpUtil ] - Method failed: HTTP/1.1 500 Internal Server Error
2017-11-05 08:52:06.347 [WARN ] [org.openhab.io.net.http.HttpUtil ] - Method failed: HTTP/1.1 500 Internal Server Error
Any Thoughts??
jerryhurst
(Jerry Hurst)
November 5, 2017, 4:43pm
3
Assuming you are using the Ecobee binding, it’s a harmless Ecobee token expiration. I get the same errors.
Mentioned here:
KidSquid
(The Squid)
November 5, 2017, 4:47pm
4
I am using the ecobee binding…thank you!
Wish there was a way to suppress or better correlate to ecobee. When you are looking for issues it’s generic nature makes you want to explore it further.
Squid
watou
(John C)
November 5, 2017, 4:59pm
5
I think it’s incorrect for org.openhab.io.net.http.HttpUtil to log anything above DEBUG level and I think it might be a regression that it now does. A utility class like HttpUtil does not know whether a 500 HTTP status code is something that warrants a log entry; rather the code using HttpUtil would be in a position to know if it should be logged, and at what level.
Kai
(Kai Kreuzer)
November 5, 2017, 6:53pm
6
I agree. Actually, the ESH version of HttpUtil only logs debug messages, the warning was only left in the 1.x compatibility layer. I have created reduced logging level as the util class cannot judge the severity by kaikreuzer · Pull Request #227 · openhab/openhab-core · GitHub to fix this.
