After upgrading to this latest the karaf ssh configuration is reset to only allow login from local host. How can i prevent that the file “/var/lib/openhab2/config/org/apache/karaf/shell.config” is reset on start service?
Forget it: Did my edit in the wrong place.
Using /var/lib/openhab2/etc/org.apache.karaf.shell.cfg now.
Just a minor question, Designer 0.9.0 was broken in some aspects for a long time
did these fixes [quote=“Kai, post:1, topic:19903”]
there are also noteworthy functional enhancements. A new stable ESH build is used in the distro, which addressed this long list of issues.
[/quote]
address some of these issues (mainly highlighting syntax, class errors, issues with imports, missing items, things, etc that were indeed not wrong) or do we still have to wait for that? Not trying to sound ungrateful, but this is one of the things that makes it hard for me (non_Java guy) to get more into it. The resolved issues list surely looks impressive and important, but I did not get the impression that the snapshot 0.9.0 changed in this regard…yet I may have easily missed something…
pi@homeauto /etc/init.d $ sudo apt-get upgrade Reading package lists... Done Building dependency tree Reading state information... Done The following packages have been kept back: nuscratch The following packages will be upgraded: openhab2 1 upgraded, 0 newly installed, 0 to remove and 1 not upgraded. Need to get 52.1 MB of archives. After this operation, 0 B of additional disk space will be used. Do you want to continue [Y/n]? Get:1 http://dl.bintray.com/openhab/apt-repo2/ unstable/main openhab2 all 2.0.0~20170112185728-1 [52.1 MB] Fetched 52.1 MB in 28s (1,847 kB/s) (Reading database ... 82696 files and directories currently installed.) Preparing to replace openhab2 2.0.0~20170111215718-1 (using .../openhab2_2.0.0~20170112185728-1_all.deb) ... Unpacking replacement openhab2 ... Setting up openhab2 (2.0.0~20170112185728-1) ... Installing new version of config file /var/lib/openhab2/etc/version.properties ... Installing new version of config file /var/lib/openhab2/etc/branding-ssh.properties ... Failed to get D-Bus connection: No connection to service manager. dpkg: error processing openhab2 (--configure): subprocess installed post-installation script returned error exit status 1 Errors were encountered while processing: openhab2 E: Sub-process /usr/bin/dpkg returned an error code (1)
Where can I find this file(userdata/etc/org.openhab.addons.cfg) on raspberry?
I can’t also change conf/services/addons.cfg. This is only read only file. When I want to change chmode, it’s run error.
Could you write me what I do wrong?
