Martin,
I also use the 1.9 version of the astro binding. When I look at the PaperUI I see both the 1.9 and 2.0 versions. Do you use the offline version. I saw above if you want the offline distro. you need to do the following commands:
I downloaded the snapshot, unpacked it and started openhab und a Windows 7 64bit professional system.
In the console everything loojed fine, got the openhab logo an so on.
Then i tried localhost:8080 an got the following line.
Error 404 - Not Found.
No context on this server matched or handled this request.
Contexts known to this server are:
/8199 ā> org.mortbay.jetty.webapp.WebAppContext@1db05b2{/8199,file:/C:/Program%20Files%20(x86)/WEKA/Energieaudits%20in%20kleinen%20und%20mittleren%20Unternehmen/webapp/}
This also happend some time ago with the offline distro and demo package.
Maybe some of you have an idea what I“m doing wron.
Hi @Daniel_OH , You canāt place it in a location that has spaces. Such as āProgram Filesā for example. Try moving it away and seeing if that works better.
Is the new .deb package expected to work on Raspbian Jessie Lite as a starting point on a Pi2B? I still canāt find any reason why the runtime loads up Karaf and doesnāt go further (no logs, no listening ports except the Karaf shutdown and Java remote debugging port). If I either start the openhab2 service or do this by hand
pi@habpi2:/usr/share/openhab2 $ sudo -u openhab ./start_debug.sh
Launching the openHAB runtime...
Listening for transport dt_socket at address: 5005
Yesterdy I tried the new single distro, and because I was curios, I chose the simple package.
It woud be no problem, to download the distro agein and start from the beginning, but I was wondering if there is an easyier way to choose an other package? How can I get back to the initial setup an choose the standard package?
Iām sure there is a setting somewhere down in the userdata folder. But you can manually set the package by changing the package parameter in your services/addons.cfg folder. The comments in that file indicate valid values.
Hi, I didnāt try it but I think you can edit your userdata/etc/org.openhab.addons.cfg file and set the āpackageā setting to āstandardā. At least itās the setting in my org.openhab.addons.cfg:
Actually, the package selection does nothing else than creating the file userdata/etc/org.openhab.addons.cfg. So if you delete this file and set a different package in conf/services/addons.cfg it will create a new file with the addons specified of that package. But there really isnāt a need to switch package, because you can simply change the installed addons yourself at any time and for your personal needs.
