All questions and discussions around the initial installation of openHAB.
Hi everybody,
I am new to OpenHab and hope to get some help from you.
Harware : Raspberry Pi 3 - connected via ethernet
Install Image : openhabianpi-raspbian-201804031720-gitdba76f6-crc9e93c3eb (latest stable version)
I followed the online documentation for a basic installation.
The connection, ssh and the html access work.
When I go to the dashboard to start the initial setup and klick on any of the four packages - nothing happens…
What am I doing wrong?
Thank you for your help in advance.
KGestrich
again - I found my stupid mistake:
I had to turn off my my scribt blocker (NoScribt) - which makes absolutly sens - now everything works like a charm.![]()
KGestrich
I repost my post in another topic:
I wanted to start from a clean installation, I downloaded the image file of openhabian and the installation constantly stops always, reporting:
Installing Java Zulu 32-Bit OpenJDK…
gzip: stdin: unexpected end of file
tar: Child returned status 1
tar: Error is not recoverable: exiting now
FAILED
openHABian] Initial setup exiting with an error!
I try to install from openhabian-config but always error:
$ wget -nv -O /tmp/openhabian.kOD2D/zulu8.tar.gz
http://: Invalid host name.
FAILED
Is there an official solution to solve the problem or at the moment the installation with openhabian is impossible?
Thanks.
Dear Kai
I want to install openhab2 on windows 8.1, but karaf could not finish the installation at first time.
Launching the openHAB runtime...
org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Could not create plugin o
f type class org.apache.logging.log4j.core.appender.ConsoleAppender for element
Console: java.util.MissingResourceException: Can't find bundle for base name Log
4j-charsets, locale en_US Ignored FQCN: org.apache.logging.log4j.spi.AbstractLog
ger
java.util.MissingResourceException: Can't find bundle for base name Log4j-charse
ts, locale en_US
at java.util.ResourceBundle.throwMissingResourceException(ResourceBundle
.java:1581)
at java.util.ResourceBundle.getBundleImpl(ResourceBundle.java:1396)
at java.util.ResourceBundle.getBundle(ResourceBundle.java:782)
at org.apache.logging.log4j.util.PropertiesUtil.getCharsetsResourceBundl
e(PropertiesUtil.java:434)
at org.apache.logging.log4j.util.PropertiesUtil.getCharsetProperty(Prope
rtiesUtil.java:183)
at org.apache.logging.log4j.core.appender.ConsoleAppender$Target.getChar
set(ConsoleAppender.java:88)
at org.apache.logging.log4j.core.appender.ConsoleAppender$Target$1.getDe
faultCharset(ConsoleAppender.java:72)
at org.apache.logging.log4j.core.appender.ConsoleAppender$Builder.build(
ConsoleAppender.java:222)
ConsoleAppender.java:189)
at org.apache.logging.log4j.core.config.plugins.util.PluginBuilder.build
(PluginBuilder.java:122)
at org.apache.logging.log4j.core.config.AbstractConfiguration.createPlug
inObject(AbstractConfiguration.java:1002)
at org.apache.logging.log4j.core.config.AbstractConfiguration.createConf
iguration(AbstractConfiguration.java:942)
iguration(AbstractConfiguration.java:934)
at org.apache.logging.log4j.core.config.AbstractConfiguration.doConfigur
e(AbstractConfiguration.java:552)
at org.apache.logging.log4j.core.config.AbstractConfiguration.initialize
(AbstractConfiguration.java:241)
at org.apache.logging.log4j.core.config.AbstractConfiguration.start(Abst
ractConfiguration.java:288)
at org.apache.logging.log4j.core.LoggerContext.setConfiguration(LoggerCo
ntext.java:579)
at org.apache.logging.log4j.core.LoggerContext.start(LoggerContext.java:
285)
at org.ops4j.pax.logging.log4j2.internal.PaxLoggingServiceImpl.configure
Log4J2(PaxLoggingServiceImpl.java:409)
at org.ops4j.pax.logging.log4j2.internal.PaxLoggingServiceImpl.updated(P
axLoggingServiceImpl.java:272)
at org.ops4j.pax.logging.log4j2.internal.PaxLoggingServiceImpl$1ManagedP
axLoggingService.updated(PaxLoggingServiceImpl.java:569)
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(Managed
ServiceTracker.java:189)
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(M
anagedServiceTracker.java:152)
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfigur
ation(ManagedServiceTracker.java:85)
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.pr
ovide(ConfigurationManager.java:1118)
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.ru
n(ConfigurationManager.java:1074)
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:138)
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:105)
at java.lang.Thread.run(Thread.java:748)
org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Unable to invoke factory
method in class org.apache.logging.log4j.core.appender.ConsoleAppender for eleme
nt Console: java.lang.IllegalStateException: No factory method found for class o
rg.apache.logging.log4j.core.appender.ConsoleAppender Ignored FQCN: org.apache.l
ogging.log4j.spi.AbstractLogger
java.lang.IllegalStateException: No factory method found for class org.apache.lo
at org.apache.logging.log4j.core.config.plugins.util.PluginBuilder.findF
actoryMethod(PluginBuilder.java:234)
(PluginBuilder.java:134)
ntext.java:579)
285)
org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Null object returned for
Console in Appenders. Ignored FQCN: org.apache.logging.log4j.spi.AbstractLogger
org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Unable to locate appender
"STDOUT" for logger config "org.apache.karaf.shell.support" Ignored FQCN: org.a
__ _____ ____
____ ____ ___ ____ / / / / | / __ )
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ |
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/
/_/ 2.5.4
Release Build
Hit '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
Hit '<ctrl-d>' or type 'system:shutdown' or 'logout' to shutdown openHAB.
openhab>
Hi, I am still a bit noob here and do apologise if I am raising this in the wrong place.
I have recently migrated from OH2.5 running on a Pi (openhabian) to OH3 on Synology Docker, so far so good. I did however just come across something which I thought might be worth bringing up to potentially add to the docker deployment (again sorry if i am in the wrong place for this).
On failing to ping a device outside of my LAN (using the OH network binding) I came across the necessity to
apt-get install iputils-ping
which allowed the Openhab Network binding ICMP and ARP capabilities. Would is iputils-ping something that could be added to the Openhab container deployment?
Regards
Thanks for creating this space! It’s a helpful place to discuss initial openHAB installation, setup issues, and common configuration questions.
