Hi guys,
I have an issue with my ABUS SHBW-10000 multi sensor. The brightness threshold report is not working as expected. Report threshold is set by configuration to 10lx (config parameter: config_113_2) but turning off/on the light will not trigger the report. Test was done during night, so the local light will cause a brightness change > 10lx. Do you have any ideas? Did I miss something?
I have added my platform configuration and the configuraiton of the sensor below.
Platform information:
Hardware: Raspberry Pi 4 8GB
OS: openhabian 3.4 M2
Thing configuration:
UID: zwave:device:e216f68b3e:node7
label: EG_Office_ABUS_SHBW10000
thingTypeUID: zwave:abus_shbw10000_00_000
configuration:
config_10_1: 10
wakeup_interval: 7200
group_1:
- controller
group_2: []
config_111_2: 1
config_112_1: 5
config_100_1: 0
config_110_1: 1
config_101_4: 3600
wakeup_node: 1
config_102_4: 3600
config_113_2: 10
config_114_1: 10
config_12_1: 10
config_103_4: 600
config_13_2: 20
config_14_1: 0
config_104_4: 86400
config_15_1: 0
node_id: 7
bridgeUID: zwave:serial_zstick:e216f68b3e
Thank you in advance for your suggestions.
Regards,
Matthias
