Hi everybody,
I am pretty new to openHAB. Right know I have just a little setup for my office to play arround a little bit. Currently I am testing different z-wave multisensors. One of them causing some issues I don’t understand.
To my setup:
- Platform information:
- Hardware: Raspberry PI 4 8GB Ram
- OS: openhabian
- openHAB version: 3.3
I have the sensor ABUS SHBW10000. The autosetup showed some issues so I have configured the thing by modifing the settings in the code section in the UI:
UID: zwave:device:e216f68b3e:node7
label: t_ABUS_SHBW10000_Office_EG
thingTypeUID: zwave:abus_shbw10000_00_000
configuration:
config_10_1: 10
wakeup_interval: 7200
group_1:
- controller
config_111_2: 5
config_112_1: 5
config_100_1: 1
config_110_1: 1
config_101_4: 0
wakeup_node: 1
config_102_4: 0
config_113_2: 15
config_114_1: 10
config_12_1: 0
config_103_4: 10
config_13_2: 30
config_14_1: 0
config_104_4: 0
config_15_1: 0
node_id: 7
bridgeUID: zwave:serial_zstick:e216f68b3e
I am wondering about parameters 12_1, 101_4 and 102_4. Due to the description within the z-wave database those parameters should accept other values than 0. But if I configure it the thing goes in ERROR mode.
Also I have set the parameters for 111-114 and enabled the threshold base reports. The reports are not send by the device. Does anybody know more about that behaviour? What could be the reason?
Thanks you in advance!
Regards,
Matthias
