ABUS Z-Wave Doorlock HomeTec Pro CFA3010
Bob ( @apella12 ) and @chris , has anything been changed in the last weeks regarding security or locks on the binding? (At least I don’t see anything on github)
The reason I am asking is because my lock doesn’t work anymore since some time. What I know is though that I have updated my system around that time to 4.2.0.M2 (which the binding is also on) but that of course can be coincidence and I cannot say that exactly after that the dock wasn’t working anymore.
The device is online and it seems it is communicating over the bus. At least, when I debug the logs and I then set the device to inclusion mode (even though it is already included) then I receive these logs:
2024-05-01 17:53:50.941 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 136: Application update request. Node information received. Transaction null
2024-05-01 17:53:50.941 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 136: resetResendCount initComplete=true isDead=false
2024-05-01 17:53:50.942 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 136: Application update - no transaction.
I have made sure that the above S0 setting is configured on the lock (like I described above).
The controller’s setting is as follows (I changed the key for the screenshot)
When changing a state (like the intention to close the lock) I get the following logs
2024-05-01 18:04:25.390 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 136: notifyTransactionResponse TID:820 DONE
2024-05-01 18:04:25.392 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 136: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2024-05-01 18:04:25.394 [DEBUG] [mmandclass.ZWaveSecurityCommandClass] - NODE 136: SECURITY_TXD 62 02
2024-05-01 18:04:25.395 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 136: Sending REQUEST Message = 01 1D 00 13 88 16 98 81 89 56 E1 21 2F 55 CD 87 05 CF 49 D3 F0 B7 EB FD F8 06 69 DB 25 BE 8F
2024-05-01 18:04:25.408 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 136: sentData successfully placed on stack.
2024-05-01 18:04:25.409 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 136: TID 816: Transaction not completed
2024-05-01 18:04:28.070 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 136: SendData Request. CallBack ID = 190, Status = Transmission complete and ACK received(0)
2024-05-01 18:04:28.071 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 136: resetResendCount initComplete=true isDead=false
2024-05-01 18:04:28.071 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 136: TID 816: Transaction not completed
2024-05-01 18:04:33.071 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 136: TID 816: Timeout at state WAIT_DATA. 3 retries remaining.
2024-05-01 18:04:33.071 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 136: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2024-05-01 18:04:33.072 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 136: notifyTransactionResponse TID:816 CANCELLED
2024-05-01 18:04:33.073 [DEBUG] [mmandclass.ZWaveSecurityCommandClass] - NODE 136: isNonceAvailable = null
2024-05-01 18:04:33.074 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 136: Sending REQUEST Message = 01 09 00 13 88 02 98 40 25 BF 2D
2024-05-01 18:04:33.083 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 136: sentData successfully placed on stack.
2024-05-01 18:04:33.084 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 136: TID 821: Transaction not completed
2024-05-01 18:04:34.520 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 136: SendData Request. CallBack ID = 191, Status = Transmission complete and ACK received(0)
2024-05-01 18:04:34.520 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 136: resetResendCount initComplete=true isDead=false
2024-05-01 18:04:34.520 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 136: TID 821: Transaction not completed
2024-05-01 18:04:34.610 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 136: Application Command Request (ALIVE:DONE)
2024-05-01 18:04:34.610 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 136: resetResendCount initComplete=true isDead=false
2024-05-01 18:04:34.610 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 136: Incoming command class COMMAND_CLASS_SECURITY, endpoint 0
2024-05-01 18:04:34.611 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 136: SECURITY check internal
2024-05-01 18:04:34.611 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 136: Received COMMAND_CLASS_SECURITY V1 SECURITY_NONCE_REPORT
2024-05-01 18:04:34.611 [DEBUG] [mmandclass.ZWaveSecurityCommandClass] - NODE 136: NONCE Received start...
2024-05-01 18:04:34.611 [DEBUG] [mmandclass.ZWaveSecurityCommandClass] - NODE 136: NONCE Received start null
2024-05-01 18:04:34.611 [DEBUG] [mmandclass.ZWaveSecurityCommandClass] - NODE 136: NONCE Received ZWaveNonce [nonceBytes=(47 C7 57 C0 ED 52 D8 EB ), timer=84517, valid=true]
2024-05-01 18:04:34.612 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 136: Commands processed 1.
2024-05-01 18:04:34.612 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 136: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3e694906.
2024-05-01 18:04:34.612 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 136: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3e694906.
2024-05-01 18:04:34.612 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 136: notifyTransactionResponse TID:821 DONE
2024-05-01 18:04:34.613 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 136: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2024-05-01 18:04:34.615 [DEBUG] [mmandclass.ZWaveSecurityCommandClass] - NODE 136: SECURITY_TXD 80 02
2024-05-01 18:04:34.617 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 136: Sending REQUEST Message = 01 1D 00 13 88 16 98 81 BC A1 61 89 A0 A5 87 69 AB B4 3E 47 3E F4 C7 45 75 F5 21 52 25 C0 50
2024-05-01 18:04:34.632 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 136: sentData successfully placed on stack.
2024-05-01 18:04:34.632 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 136: TID 817: Transaction not completed
2024-05-01 18:04:34.746 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 136: SendData Request. CallBack ID = 192, Status = Transmission complete and ACK received(0)
2024-05-01 18:04:34.746 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 136: resetResendCount initComplete=true isDead=false
2024-05-01 18:04:34.746 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 136: TID 817: Transaction not completed
2024-05-01 18:04:39.747 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 136: TID 817: Timeout at state WAIT_DATA. 3 retries remaining.
2024-05-01 18:04:39.747 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 136: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2024-05-01 18:04:39.747 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 136: notifyTransactionResponse TID:817 CANCELLED
which to me looks like it is not processed by the device (and it does not react either).
When I do something on the hardware I don’t see nor receive anything on openHAB.
What is also strange is that after several days some of the a number of things go offline and when I restart the controller they are online again (I even have the feeling they still work, though, but I did not yet have the time to investigate that). I also never experienced that before.
Anything that comes to your mind with this?
