Currently I have no channel for alarm notification. There is only one channel for battary state.
That’s my first z-wave database entry
Can anybody help defining the asociation group correctly?
I think you can see all the channels that are currently defined can’t you? When I looked yesterday, there were no channels in the database, so therefore, you will not have any channels until the database is updated (which looks like it was done this morning) and the binding is updated (which will be at the weekend).
@chris: After adding the xml to the binding manually, it worked for me.
I did the same yesterday with no luck, because I taught the xml will be updated immediately.
Do you know if it‘s possible to connect the smoke detector to a second or third one? would be nice when all detectors will ring if one of them detects smoke.
Is the smoke alarm switch one way, or is it possible to disable the alarm via z-wave? thx!
sometimes the smoke detectors were shown with state „offline - communication error“. a few hours later they appear normally.
can anybody say how to fix it?
thank you!
Do you know why this is happening? If not, that would be the first thing to work out. Generally I would suggest getting a debug log to see what is happening - normally this sort of issue is caused by the device not responding to messages, or not waking up as expected, but without knowing what’s going on, it’s hard to say how you can fix it.
