I am used to use SSH tunnel to access my primary house openhab when I need, and use Telegram so house can send me alerts. Now I am installing a openhab in my secondary house where only available internet connection is over a 4G router, but I cannot connect through SSH (and it don’t answer ping, so I think it is a internet provider limitation). Ports are open, and dynamic DNS works.
I think that this is the best plan.
Most ISPs/Mobile Carriers will block many incoming ports (SSH,etc) towards mobile data endpoints, so you may have to initiate the VPN tunnel from the endpoint towards a remote VPN server.
Push your local ISP to deliver a cable based internet link to the new house
Once setup why would you need ssh on a regular basis?
Given the limitations maybe you could have your local openhab server. Look for a file on a remote server and enable vpn if that event happens. It could also publish the ip. This way the tunnel is not open all the time. Just an idea.
The VPN will use up some data while it is connected because you will probably need to set it up to keep connected which means the server and client will need to continuously ping each other to make sure they are still connected and keep the connection alive.
But the amount of bandwidth is relatively minor. It is hard to separate the exact amount though.
Assuming that the ISP is indeed blocking certain ports, maybe you can find one that it isn’t blocking and configure your sshd to listen on that. While port 22 is the standard port, you can run sshd on any port (case in point, the Karaf console ssh login).
I once searched for and posted a response to a topic of all sorts of remote administration solutions that one can use in a situation like this and I can’t find it now. Dataplicity is one that came up that might be useful for you. There are other similar products.
Just because they are listed for RPi I don’t think they are limited to working with RPis. This should let you get to your server without needing to connect to it directly taking any blocking by your ISP out of the picture.
