Access to configuration gui (browser) after installation in Docker
  • Platform information:
    • Hardware: Raspberry Pi 4 (with 4GB RAM)
    • OS: Raspian (Docker installation)
    • openHAB version: openhab/openhab:latest (see Docker hub)
Hello everybody,
I´ve installed openhab in a docker.
Everything seems fine, but I have no access to the configuration site in browser.
Maybe somebody can help me?
Raspian code:
pi@raspberrypi:~ $ docker run --name openhab --restart always openhab/openhab:latest
++ test -t 0
++ echo false
  • interactive=false
  • set -euo pipefail
  • IFS=’
  • ‘[’ limited = unlimited ‘]’
  • rm -f /openhab/runtime/instances/instance.properties
  • rm -f /openhab/userdata/tmp/instances/instance.properties
    Starting with openhab user id: 9001 and group id: 9001
  • NEW_USER_ID=9001
  • NEW_GROUP_ID=9001
  • echo ‘Starting with openhab user id: 9001 and group id: 9001’
  • id -u openhab
    ++ getent group 9001
  • ‘[’ -z ‘’ ‘]’
  • echo ‘Create group openhab with id 9001’
  • groupadd -g 9001 openhab
    Create user openhab with id 9001
  • echo ‘Create user openhab with id 9001’
  • adduser -u 9001 --disabled-password --gecos ‘’ --home /openhab --gid 9001 openhab
    Warning: The home dir /openhab you specified already exists.
    Adding user openhab' ... Adding new user openhab’ (9001) with group openhab' ... adduser: Warning: The home directory /openhab’ does not belong to the user you are currently creating.
    The home directory /openhab' already exists. Not copying from /etc/skel’.
  • groupadd -g 14 uucp2
  • groupadd -g 16 dialout2
  • groupadd -g 18 dialout3
  • groupadd -g 32 uucp3
  • groupadd -g 997 gpio
  • adduser openhab dialout
    Adding user openhab' to group dialout’ …
    Adding user openhab to group dialout
    Done.
  • adduser openhab uucp
    Adding user openhab' to group uucp’ …
    Adding user openhab to group uucp
    Done.
  • adduser openhab uucp2
    Adding user openhab' to group uucp2’ …
    Adding user openhab to group uucp2
    Done.
  • adduser openhab dialout2
    Adding user openhab' to group dialout2’ …
    Adding user openhab to group dialout2
    Done.
  • adduser openhab dialout3
    Adding user openhab' to group dialout3’ …
    Adding user openhab to group dialout3
    Done.
  • adduser openhab uucp3
    Adding user openhab' to group uucp3’ …
    Adding user openhab to group uucp3
    Done.
  • adduser openhab gpio
    Adding user openhab' to group gpio’ …
    Adding user openhab to group gpio
    Done.
  • case ${OPENHAB_VERSION} in
  • initialize_volume /openhab/conf /openhab/dist/conf
  • volume=/openhab/conf
  • source=/openhab/dist/conf
    ++ ls -A /openhab/conf
  • ‘[’ -z ‘html
    icons
    items
    persistence
    rules
    scripts
    services
    sitemaps
    sounds
    things
    transform’ ‘]’
  • initialize_volume /openhab/userdata /openhab/dist/userdata
  • volume=/openhab/userdata
  • source=/openhab/dist/userdata
    ++ ls -A /openhab/userdata
  • ‘[’ -z ‘etc
    logs
    tmp’ ‘]’
    ++ cmp /openhab/userdata/etc/version.properties /openhab/dist/userdata/etc/version.properties
  • ‘[’ ‘!’ -z ‘]’
  • chown -R openhab:openhab /openhab
  • sync
  • ‘[’ -d /etc/cont-init.d ‘]’
  • sync
  • ‘[’ false == false ‘]’
    ++ IFS=’ ’
    ++ echo gosu openhab tini -s ./start.sh
  • ‘[’ ‘gosu openhab tini -s ./start.sh’ == ‘gosu openhab tini -s ./start.sh’ ‘]’
  • command=($@ server)
  • exec gosu openhab tini -s ./start.sh server
    Launching the openHAB runtime…
When I go to my webbrowser and type in: http://localhost:8080
I will see the error: Website is not available
Thank you very much!
Best regards
Fabian
Hi Fabian,
you need to map ports to be able to access websites inside your Docker container. You find these and other configuration options explained on the Docker Hub site for openHAB
You cannot blindly install something without RTFM. !!
Either from the openHAB website or from Docker Hub.
