Hi all,
to be able to render the location map (https://github.com/openhab/openhab/wiki/GoogleMap ) also from remote in the native application I tried to access the location values via rest using https://user:password@my.openhab.org/rest … in the html; but it fails - I assume my.openHAB does not allow CORS (cross domain calls):
XMLHttpRequest cannot load https://my.openhab.org/rest/items/PatrikLocation/state/. No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'http://haus:8080' is therefore not allowed access. The response had HTTP status code 401.
Would it make sense to enable such requests, or is this too much of a security risk? Is there another way I can make the map work in the native apps (unfortunately there’s no location widget)?
with kind regards,
Patrik
rlkoshak
(Rich Koshak)
September 27, 2016, 7:01pm
2
That is correct
I’d have to think about it but my first inclination is this would be a pretty big security risk if not done really well. Jetty may not support it also, which would be technical challenge.
mathknop
(Mathias Knop)
January 8, 2018, 7:17pm
3
It seems that myopenhab doesn’t support CORS neither.
Using this code:
var request = $.ajax
type : "POST",
url : "https://mail%40mail.be:password@home.myopenhab.org/rest/items/Z1_001_Heater",
data : "ON",
contentType: 'text/plain',
headers : { 'Access-Control-Allow-Origin':'*' }
I get following error:
No ‘Access-Control-Allow-Origin’ header is present on the requested resource.
Do you know how to bypass this? When posting the request using Postman I have no problem at all but I must say I am not familiar with CORS yet.
Is there a solution to the issue?
I was also interessted into this use case and tested it. For me it worked fine to access openHAB via REST via myopenhab.
I tried two use cases:
Get the state of an item
Set the state of an item
Two ways of connection I tried:
My system setup:
openhabian on an Raspberry Pi connected via LAN
openhabian connected via openHAB cloud connector to the myopenhab cloud
I have one Thing with one Item (switch) set up via the Modbus binding
For testing REST I’m using the Mac App “Insomnia Core” (https://insomnia.rest/download/#mac )
My Insomnia Core setup for GET STATE:
My Insomnia Core setup for POST STATE:
This setup doesn’t work for me. Does anyone have any idea how I can access the REST api via myopenhab?
<html>
<head>
<script src="https://code.jquery.com/jquery-latest.min.js"></script>
</head>
<body>
<button id="ajax">ajax call</button>
<script type="text/javascript">
$('#ajax').click(function(){
$.ajax({
type: "GET",
username: "xxx@xxx.com",
password: "xxx",
url: "https://myopenhab.org:443/rest/items/Test_Item/state",
success: function(data){
console.log(data);
</script>
</body>
</html>
I get the same error as described in the first post. Is there any other way to access items from “outside”?
